    Problem with two lan networks and access to ap
    100 Posts 5 Posters 35.0k Views
      kejianshi
      Personally, I think he should have all his connections on the LAN ports on that AP and that he should put tape over his WAN port.
      • F Offline
        firefox
        Good Morning
        I did a Hard Reset to AP
        And put everything to the initial state as if he were Router
        Then again I followed the guide to make it to AP
        And it works as AP
        Just the access its management interface is only when connecting Directly to him
        wired or wireless
        I do not know what to say
        I tried everything I know
        And all you know
        Just does not work
        I will stay with it how it is now
        There is internet access from wireless devices
        But not sharing files between computers on the wired network
        To computers on the wireless network
        Or reversed
        It would make me crazy in the near future
        So many thanks to everyone for the help
        If I find why this happens I promise to update
          Just because you can't access the AP webgui from the wired network that should not mean you can't access other wireless clients. That is some other issue. As long as you have the correct firewall rules in place in pfSense there should be access between the wired and wireless networks.
          • F Offline
            firefox
            Unfortunately it also does not work
            We have 5 laptops at home
            One currently running and is with me
            Has two shared folders
            They are accessible only if the computer is connected to the wired network
            Of course the same thing
            But the reverse
            No wireless devices access to the wired network shared directories
              Ok, a number of things could be happening here:
              pfSense is blocking the traffic. That's easy to check because it will appear in the firewall logs.
              There's a routing problem. This doesn't appear anywhere so it's harder to spot but we've just spent a good deal of time checking out the routing on your network and it looks good.
              Something is blocking the traffic locally. E.g. Windows firewall is blocking access because the traffic is coming from another subnet.
              Remind me, you are not able to ping between wired and wireless clients either?
              • F Offline
                firefox
                @stephenw10:
                Yes
                Specific computers that I am trying to access shared folders
                Are running Linux Ubuntu
                  Ah, er, yes you're not able to ping or yes you are able to ping?  ;)
                  If you plug a client into one of the other LAN ports on the wbr-3406 can you ping the wired clients (on 192.168.0.X) from there? That should exclude and wifi weirdness from the problem.
                  • F Offline
                    firefox
                    Yes there is ping
                    from wireless computer 192.168.2.8 to wired computer 192.168.0.2
                    and
                    from wired computer 192.168.0.2 to wireless computer 192.168.2.8
                      Ok so you can ping but not do file transfer? And this worked ok before?
                      This is probably because the machines are not on the same subnet so they are not directly discoverable by Windows (or whatever). Have you tried accessing the shared folder directly by its IP?
                        kejianshi
                        If you don't know how to access a share by IP, its easy in windows…
                        hit start > computer
                        on left side, click network
                        select your current computer in the list
                        now in that bar at top of file browser, put in \192.168.1.30  (or whatever the IP of the computer with the share is)
                        I'm slipping - I should have suggested this way way back but "shares" was never mentioned early on.
                        • F Offline
                          firefox
                          Just now I tried to access a network folder
                          Using ip number
                          It work
                          Why not see all computers when entering the network
                            kejianshi
                            File sharing uses broadcasts that don't cross subnets to advertise themselves.
                            So, when you have files and printers shared, the easy way to reach them across subnets is by IP since no broadcast is required that way.
                            Understand?
                            If I had known you had shares, I would have suggested it earlier.  Good thing stephenw10 did.
                              If you have a domain controller/WINS server that can register connected clients then you can span subnets I believe, not my area.
                              If you have enabled "Register DHCP leases in DNS forwarder" then you can access remote machines by their host name but they still won't be discoverable.
                              You may be able to get discovery to work across the subnets using the IGMP proxy, I've never tried that.
                              • F Offline
                                firefox
                                Can I assume that the problem
                                Related to the same reason that you can not access the management interface of the AP
                                I'm still trying to check why this is happening and fix it
                                But not urgent
                                As before
                                If I run into something on the way so I check and try
                                At least I have access to shared folders
                                As you have shown me
                                  It's two distinct problems:
                                  You can't access the wifi router because it's not possible to give it a route back to the LAN side subnet.
                                  You can't see the wifi clients from the wired network because because the protocol Windows uses to discover network shares doesn't span subnets.
                                  I would try adding the route again to the access point. I should do nothing or fix it. The fact that it killed everything last time you tried it implies something wasn't right.
                                  • F Offline
                                    firefox
                                    @stephenw10:
                                    in My work
                                    There were about 2000 computers connected
                                    Over 50 different networks
                                    I tap the icon "Network" on the computer
                                    I see all the networks
                                    Then click on the network icon
                                    And see all the computers on the network
                                    I guess strains because they are connected to servers
                                    So I guess the server tells computers where they are at,
                                    Is there something similar to pfsense
                                    @stephenw10:
                                    I prepare a file with all the screenshots of this router
                                    I will attach it to the next post
                                    See what I did there
                                    What should be done
                                    @stephenw10:
                                    I use Linux not Windows
                                    How can you upload here a presentation weighs 2.8 MB
                                    Or upload more images in a single message
                                    • F Offline
                                      firefox
                                      Here is a link to download the pdf file
                                      With a screenshot of the router's management interface
                                      http://www.fileswap.com/dl/R6JzKxPLhV/ap.pdf.html
                                        @firefox:
                                        So I guess the server tells computers where they are at.
                                        Exactly.
                                        @firefox:
                                        Is there something similar to pfsense?
                                        No. (I assume you mean for pfSense)
                                        You are probably using the Windows SMB protocol for file shares in Linux, though there are others, so the same applies. You need a domain controller to register the available shares across all subnets and distribute that information. This isn't my forte though.  ;)
                                        Here is a useful thread: http://forum.pfsense.org/index.php?topic=22064.0
                                        I would try adding the route I described earlier into the AP routing table again. I can't see how it could possibly break anything. It may not work but it should cause any harm.
                                        • F Offline
                                          firefox
                                          Is the Avahi package can fit
                                          I read in this thread
                                          About a similar problem
                                          http://forum.pfsense.org/index.php?topic=60967.5
                                          When I read the thread you gave a link for it
                                          It said it is related to DNS
                                            Avahi does what you want but only for the mDNS protocol. This is used primarily by Apple but also by various media streamers, NAS boxes etc. Apples Bonjour file sharing service uses it. Reading that wiki page I see that it also supports Linux's nss so you might be able to use that. I've never tried, I would have to do a lot more reading before attempting it!  ;)
