    PfSense 2.1 Floating rules for Multi Wan doesn't work.
    86 Posts 35 Posters 54.5k Views
      hyrol
      Still configure the same as pfSense 2.0.3 Squid Package Multi Wan, only changes to the Floating Rules to Interface Group.
      ![Lan Rules.jpg_thumb](/public/imported_attachments/1/Lan Rules.jpg_thumb)
      ![Lan Rules.jpg](/public/imported_attachments/1/Lan Rules.jpg)
      Groups.jpg_thumb
      Gateways.jpg_thumb
        SaFi
        @hyrol
        Thank you ..
        I wondering what's squid version you talking about 2.7 or 3.8 or it doesn't matter?
        secondly where you use interface named "internet" I saw it has no rules, will you be more detailed
        regards
        SaFi
          hyrol
          Under the Menu=> Interface, you can see Interface Group.
          Interface.jpg_thumb
            niebla
            Created the interface group. Squid uses the default gateway only with 2.1.
              hyrol
              @SaFi:
              @hyrol
              Thank you ..
              regards
              SaFi
              • Im try for squid 2.7, you can try for squid 3.8 you can tell me later for the result.
              • If you expert configure for inbound/outbound for WANs under Interface Group.. Actually that use for WANs rules not for LANs rules.
                niebla
                The problem is squid is using the default route and does not care about interface groups. What am I missing?
                  hyrol
                  Actually this is not Load-Balance Round Robin, this is Load-Balance Bandwith Agreggation and you can see all the WANs its working.
                  It is worth it from nothing.
                  Load-Balance.jpg_thumb
                    niebla
                    How does Squid know to use the interface group instead of the default gateway?
                      hyrol
                      I do not know how Squid works, most importantly it works.  ;)
                        niebla
                        Squid works with multi-wan on 2.0.3 by using floating rules. Users have reported that it is not working with 2.1 with multi-wan even when using floating rules.
                        Many users are looking for a way to use multi-wan and squid using 2.1.
                        When this is solved many of us who have squid and multi wan will be able to use 2.1, and be grateful to the person who provides the solution.
                          basitkhan
                          @hyrol:
                          Finally, after a long time trying pfSense Squid Package + Multi Wan and I have managed to find its way in a deadlock.
                          pfSense 2.1 Squid Package + Multi Wan, no longer using the Floating Rules, but using the Interface Groups.
                          Good Luck Everyone.
                          I have followed the same steps but all in vain,
                          squid still uses only default gateway :( does not work with Interface Group
                          still waiting to fix it…
                            hyrol
                            If you check whatmyip you can see only default WAN, but you can see all the WANs work together.
                            Note: This Load-Balance Bandwith Agreggation not Load-Balance Round Robin.
                              niebla
                              My tests show that squid is only using the default gateway. I understand and have the interface group. It can be used by rules but is not being used by squid, which has a large majority of our traffic.
                                hyrol
                                pfSense 2.1.1 soon be out, hoping the problem will be solved.
                                  afrugone
                                  I'm not sure if 2.1.1 wil fix something abaout this, JIMP answer that they don't now the problem, https://forum.pfsense.org/index.php/topic,71546.msg391065.html#msg391065, perhaps any you that have a better understanding than me about this problem can add bug ticket.
                                    SaFi
                                    I don't think it's an issue or bug in pfsense 2.1 multi-wans and proxy (squid), but it's seems that there is a mess-configuration in squid  to does not use multi-wan and still sticking using default gateway.
                                    http://wiki.squid-cache.org/SquidFaq/NetworkOptimizations
                                      javerleo
                                      Bottom line: There is no solution for this issue so far. We have to keep pfSense 2.0.3 until somebody comes with a final solution. Hope the gurus to figure this out.
                                      Thanks.
                                      God is my best friend
                                      • jimpJ Offline
                                        compare /tmp/rules.debug on 2.0.3 where it works and on 2.1 where it doesn't, the answer may lie there. The config would have to be identical for it to be a valid comparison.
                                        Do not Chat/PM for help!
                                          Kababayan
                                          Got it working!!! Using Openvpn as Wan2 with Unofficial Lusca proxy. Should work with squid.
                                            hyrol
                                            Great and congrats .. Actually pfSense 2.1 is not stable for me sometimes it works, after reboot it does not work, a few hours later it works, sometimes it do not work.  :'( :'(
