    PfSense 2.1 Floating rules for Multi Wan doesn't work.
    86 Posts 35 Posters 54.5k Views
      Smithes
      I setup Multi-WAN like shown in the official tutorial…. Works only for Connections without squid. And works very fine. But I also need squid. So I installed the squid 3.3-dev package from the package-list, because squid supports the "radom" command since 3.2.
      I know it is a dev-package, but I run it on a wlan-network with 5000 Users on peek and its runs very fine. Also with squidguard.
      I also know that there is no failover for squid, if one of the lines will be offline, but that is not important for me, because the two lines are from the same provider and come over the same cable. It’s a cable internet connection from unitymedia(Germany).
      I added these lines, for split the traffic to two lines. *1
      acl fiftyPercent random 0.5
      tcp_outgoing_address 192.0.2.1 fiftyPercent
      tcp_outgoing_address 192.0.2.2
      *1: The information’s found here: http://wiki.squid-cache.org/Features/AclRandom
      greets Smithes
        thanhk43
        i am using 2.1.5-RELEASE and squid 2.7.9 pkg v.4.3.4 and have the same issue, squid  only work with defaul gateway, anyone have any idea ?
          Kababayan
          Work around will be too easy if you are using virtual, in fact there are lot of ways with virtual setup.
            alxbob
            Does acl random provide failover if one gateway is down?
            • F Offline
              firatnemis
              If all the modems has got the same speed what should write custom options for equal speed ?
              @ruggero:
              first install squid3-dev  from available packages.
              ++++++in this way you can use configuration directive acl random .
              from squid doc :
              changes in 3.2 acl : random
              New type random. Pseudo-randomly match requests based on a configured probability .
              now you can do all the configuration you need for multiwan in Custom options - Custom setting of proxy server.
              in my situation ( 3 wan ) :
              acl venticinque random 1/4
              acl settantacinquediv2 random 0.5
              tcp_outgoing_address 192.168.4.254 venticinque
              tcp_outgoing_address 192.168.3.254  settantacinquediv2
              tcp_outgoing_address 192.168.2.254
              192.168.4.254 = ipv4 address wan 1
              192.168.3.254 = ipv4 address wan 2
              192.168.2.254 = ipv4 address wan 3
              random 1/4 = 25 % = wan1 25% of traffic
              random 0.5 = (100-25)/2 = wan2 37,5 % of traffic
              else = wan3 37,5 % of traffic
              i do this because my 3 wan are not equal.
              in case of 2 wan :
              acl cinquanta random 0.5
              tcp_outgoing_address 192.168.4.254 cinquanta
              you do not need extra rule on firewall ( floating rule ) .
              Also it bypass gateway groups.
                mesro09
                hello Everybody
                is there anyone to help with explanation about multiwan with squid 3.4 non transparent (working with wpad)
                many thanks
