    I just got my pfs router running and need help with pppoe settings
    7 Posts 4 Posters 1.7k Views
      killstreak1597
      I just got my pfsense router running and it is connected to my att 2wire modem/router .
      what i am planning is to switch the 2wire to bridged mode so I can manage everything with the pfsense router.
      But here's the catch. I'm not sure how I authenticate my pppoe account with att after I switch off pppoe on the 2wire.
      when I tried the first time I switched the 2wire router to bridged and typed my pppoe username and password into the pfsense router.
      after saving the configuration of both and restarting I had no internet connection. The modem dsl connection light is on but the internet light is dark. Is all the pppoe settings done with the pfsense router or am I missing something else?
      Sorry I'm not sure if i know what I'm talking about. But I hope someone can help
        podilarius
        I don't run ATT DSL at home, but I run one another ISP. Once in bridge mode, pfSense should handle the authentication. You might need a service name or not.
        Did you do something like: http://www.dslreports.com/faq/15835
        The internet light will not work in bridge mode it looks like. It does look like these particular modems are a bit harder than most to work with anything else. That just seems to be the norm with ATT internet.
          killstreak1597
          @podilarius:
          Ok, i followed those instructions and I'm going to give it  another try I'll reply with the results.
          P.S. what would the service name be if I needed one
            podilarius
            Looks like you don't need one with ATT.
              killstreak1597
              wow att is really a pain for authentication.
              I switched the router into bridged mode and then switched the connection type on the pfsense router to pppoe and I still got nothing.
              I think I'm going to get a different modem because switching isp's isn't an option right now.  :-\
              Do you have a good DSL modem you would recommend?
              • L Offline
                Legion
                I use a Draytek Vigor 120 in bridge mode, works great. I got it mainly due to its popularity on these forums.
                  Scoundrel
                  Check the PPP log to see how authentication is going; Status/System Logs then select the PPP tab.
                  I use a Cisco 857 in bridge mode.
