    Problem DNS - LAN
    39 Posts 5 Posters 7.1k Views
      phil.davis
      In DHCP Server, you need to remove 8.8.8.8 from DNS Servers.
      At the moment, your clients are getting 8.8.8.8 as their DNS server - so they are going straight to Google for DNS. They need to go to pfSense DNS Forwarder, then they will get the facebook.com restriction.
        gio79
        Hello can you tell me how you can be bet all the clients on the LAN to the DNS Forwarder in pfSense?
        Hello and thank you very much
          "all the clients on the LAN to the DNS Forwarder in pfSense?"
          This is the default configuration of pfsense dhcp server - to point to itself as dns.  So what do you mean how would you do it?  Leave the dns servers boxes in your dhcp server setup blank
          NOTE: leave blank to use the system default DNS servers - this interface's IP if DNS forwarder is enabled, otherwise the servers configured on the General page.
          Bing Bang zoom all dhcp clients of pfsense point to pfsense for dns.  If your talking about them manually putting in something else - then just create a firewall rule that prevents outbound on 53 udp/tcp and only allows it to pfsense IP.  Or create a forward that forwards dns to pfsense IP.
          Generally speaking whatever you hand out in dhcp is what your users should be using - why would they not use what the dhcp server sends them?
            gio79
            Hello and thanks to all
            I make a list of the various settings to be made for pfSense is used as a DNS Forwarder
            • In the DHCP Server to enable the DHCP server on the LAN and set the DNS
            • In DNS Forwarder and turn it on, put in the domains of the block to facebook
            • In the General Setup does not put any value in the DNS
            • After creating the two rules on the firewall
            Now I have a doubt whether in the General Setup I have set some parameters that you can see in the picture?
            Thanks to all
            Immagine.jpg_thumb
              phil.davis
              If you have DHCP on WAN then check "Allow DNS server list to be overridden by DHCP/PPP on WAN" - then pfSense will get upstream DNS from the ISP DNS server/s.
              If you have static IP on WAN, then put DNS server/s in the boxes in General Setup. Use the IP addresses of your ISP DNS servers, or some public DNS (Google, OpenDNS…) Then pfSense will get upstream DNS from these.
              In all the above, the LAN clients will still get the pfSense LAN IP (DNS Forwarder)as their DNS server, which is what you want.
                gio79
                Hello
                I have a Static IP on the WAN, I set the DNS values ​​in the General Setup page and I have not set any value in the boxes below (you can see in the picture)
                Each client on the LAN has not set no value on relished ethernet card, if I go to Windows DOS I see that DHCP assigns an IP address and DNS as it gives me the address on the LAN to pfSense
                But I can not navigate sites
                Hello and thank you
                Immagine0.jpg_thumb
                Immagine11.jpg_thumb
                  Is the dns forwarder running?  Can pfsense query dns using 8.8.8.8 ?
                  From diag, dns lookup
                  testpfsensedns.png_thumb
                    gio79
                    Hello I have the DNS Forwarder active
                    I did the test with DNS LOOKUP and you can see the result in the image
                    I do not know what to do to run pfSense
                    Hello and thank you
                    Immagine1.jpg_thumb
                      Well from that way that looks, no dns forwarder is not running. Or does not know where to forward too.  Or you have it not listening on the interfaces you need it to listen on, etc.
                      Since you got no response from 127.0.0.1 – notice mine got a response.
                      Post screen of dns forwarder page
                      dnsforwarder.png_thumb
                        gio79
                        Hello thanks for the help but it does not work
                        On the DNS Forwarder I set the same values ​​that you have set
                        On the General Setup what should I set?
                        I have to make the rules on the firewall?
                        Hello
                          Out of the box the default rules would be any any for the first lan interface.. If you add an OPT1 interface - say this 192.168.99 segment.. Then you would have to create rules on that interface to allow the traffic you want.
                          So in the attached you will see the firewall rules for my dmz segment.  192.168.3.0/24 in my case - this would be sim to your 192.168.99 segment
                          In my rules I allow traffic from the dmz segment to talk to my ntp server on my lan segment 192.168.1.0/24.. I allow traffic to my pfsense interface in that segment - in my case 192.168.3.253 for dns.  And I allow traffic not going to the local networks, ie my lan and wlan segments..
                          What are you firewall rules on your segment?  And validate that pfsense is listening on that interfaces IP for dns forwarding.  Simple netstat should show it.
                          [2.1.2-RELEASE][root@pfsense.local.lan]/root(3): netstat -an | grep .53
                          tcp6      0      0 *.53                  .                    LISTEN
                          tcp4      0      0 *.53                  .                    LISTEN
                          udp6      0      0 *.53                  .
                          udp4      0      0 *.53                  .
                          So you can see *.53 here this means its listening on ALL IPs that pfsense has..
                          So you can see a computer on that network can query pfsense for dns - which in turn goes and asks the dns server setup on it.
                          dnsquery.png_thumb
                          firewallrules.png_thumb
                            sali147
                            hello guys
                            I have problem with DNS, I have DHCP server on pfsense and my domain users can obtain from it,I have configured DNS server on DC also Microsoft Radius server for captive portal and DNS forwarder configured on pf,but now users when enter URL (e.g www.google.com) dns problem occur ,but when they enter 8.8.8.8 in Address Bar it opens the captive portal logon page and after authentication it brings the page.
                            any suggestion?
                              gio79
                              Hello johnpoz
                              I tried to run the command
                              netstat-an | grep .53
                              but with the keyboard that I can not seem to do |
                              I do not know how to fix this DNS?
                              I did the command NSLOOKUP from a client on the LAN and I have results similar to yours except that there 's IP address of my pfSense
                              help help
                                If you did a nslookup and get the results like mine - then your dns is working..
                                So what exactly do you think is not working?  And what kind of keyboard does not do |  – normal keyboard it would same key as \ above your enter/return key -- and you don't really need to do that part - thats just so you don't get a full listing.. You could do just netstat -an
                                You know you could of just copied and pasted my command, etc.  Did you fall off the turnip truck yesterday?
                                kbqwerty.png_thumb
                                  gio79
                                  Hello I decided to reset the machine pfSense and start from scratch to figure out where the problem is
                                    So that was 30 minutes ago.. You should be up and running already, it takes all of like 5 minutes to get pfsense up and running from scratch..  Unless your dicking with something - the default settings would have you up and running with dns, dhcp bing bang zoom.
                                      gio79
                                      Hello I have noticed one thing on my LAN, excluding pfSense I have this situation:
                                      • If I put a PC in DHCP and DNS worthless router assigns me an IP address because the DHCP is enabled on the router and DNS as I 212 216 112 112 who are my ISP's DNS, and in this situation I go on the internet no problem
                                      • If I put a pc and I go to set the IP address without DNS but I do not surf on the internet
                                      Now I'm redoing the pfSense machine and reboot from scratch and slowly we see that the problems I
                                        "- If I put a pc and I go to set the IP address without DNS but I do not surf on the internet"
                                        How exactly do you think you can surf the internet without dns?? So duh!!  if you don't set dns internet wouldn't work.
                                          gio79
                                          Hello
                                          I installed pfSense from scratch and I saw that there was a mistake when I went to set the LAN card on pfSense, in fact, put the Gateway, and it would not let me run anything …. in fact if I went on Status - Gateway I Gateway is the the WAN to the LAN, the LAN I deleted that everything works now via DNS Forwarder can block facebook
