    Traverse Viking ADSL-2+ Card Problem
    44 Posts 4 Posters 10.9k Views
      Nonsense
      O.K., so I finally got the LinITX card working!
      I switched the jumpers to enable the Ethernet port and configured the modem in bridge mode after I disabled DCHP on its LAN (when I discovered it conflicted with my router).  I went through the settings and hooked up the card to my DSL line to make sure it was connecting properly.  I then switched the jumpers back to PCI mode and configured pfSense to work with the card (which, for some reasons, it still identifies as having a REL 8139 chip, even though it does not–must be the BSD rl0 driver).
      Some initial observations about the LinITX card: it is not made as solid, with attention to detail, as the Viking card; the five jumpers in the same row were difficult to remove after they were set for Ethernet mode, as there is little room to grab them with a pair of long-nose pliers; most importantly, however, the LinITX card does not use a standard (i.e., U.S. Bell System standard) RJ11 jack--I had to push the line plug upward, once it was inserted in the jack, to establish a good connection--I'll have to find a fix for this issue.
      I'll be testing the LinITX card over the next week and report back as to its performance and stability.
      Thanks all!
        jonesr
        however, the LinITX card does not use a standard (i.e., U.S. Bell System standard) RJ11 jack–I had to push the line plug upward, once it was inserted in the jack, to establish a good connection
        Really? Interesting, I don't recall having any problem except the time I managed to wedge mine in the wrong way round.
        Bluetack? I'm going to have to have another look at mine when I get home.
        Glad to hear you got it working, and I hope it is stable for you.
        pfSense AMD64 VGA - Assume latest version.
        Suricata, pfBlockerNG, SquidGuard, squid3.
          Nonsense
          So I have had my LinITX card running for over a day now with no freezes/reboots required.  I, however, am getting a lot of WAN disconnects, to wit:
          Aug 16 07:23:49 apinger: alarm canceled: WAN(12.8.72.1) *** down ***
          Aug 16 07:23:49 apinger: ALARM: WAN(12.8.72.1) *** down ***
          I have had these WAN disconnects before with other modems, perhaps not as often; the log, however, shows no PPPoE disconnects.  I have my apinger frequency set to every 5 seconds when the disconnects occur.    I reset my apinger frequency back to once every second and the log now shows no more WAN disconnects, but now I show a lot more packet loss on my WAN (see image below).  I suppose it is possible that the loose-fitting rj11 connector may be causing the problem.  Any suggestions otherwise?
          status_rrd_graph_img.php.png_thumb
            jonesr
            I'm sorry I never experienced anything like that.
              Nonsense
              Yup, it looks like it might be a bad connection at the jack, as the packet loss increased after I jiggled the plug at ca. 1:30 pm.  I'll have to try a new line cord when I can get around to moving all of the boxes under the table on which my router sits so I can have access to my wall jack.  I might also clean the contacts with some Caig Deoxit.  I first became aware of this kind of problem about 14 years ago when I first had DSL: although my modem was in sync, I could not establish a reliable connection.  My ISP asked me if I was using the line cord that came with the modem.  I was not.  It seems that, at high frequencies, a line cord plug or jack that is slightly out of spec (i.e., too small or too large, respectively) will not allow its conductors to make a good, solid connection–the modem will sync, but the signal will be subject to constant drop outs.  The problem is not so noticeable when using a telephone at voice frequencies.
                Can you get line stats from the modem?
                  Nonsense
                  A little Caig Deoxit on a Q-tip does wonders for oxidation on electrical contacts.  I have not, as yet, replaced my line cord, but I used Deoxit once to clean the RJ11 contacts on the LinITX modem card–I'm not quite where I want to be, likely because I still had to jiggle the RJ11 plug to achieve sync, but as you can see looking at the graph below, things have improved somewhat--I'll have to try a second cleaning.  The modem card probably sat on the shelf at the dealer for several years and there was no silica gel (to prevent oxidation) in its package when I received it.
                  The LinITX modem stats (checked when I initially configured the card) are similar to those achieved by my prior modem, with ca. 17.5Mb/s/1.0Mb/s speed and 11.5/11 dB S/N--the only difference being the downstream attenuation, which was ca. 33 dB instead of ca. 27 dB--the difference may have been due to the oxidized RJ11 contacts (although it has been my experience that different DSL modems sometimes report different stats).  I have not tried accessing the stats via pfSense as yet--that will come after I find a complete solution for my line cord problem.  My little secret, however, is that I actually work for my ISP in the town in which I live, so I can look at my stats by accessing the DSLAM at my workplace.  I'll keep you updated on my progress.
                    @Nonsense:
                    Ah, well that would help.  ;)
                    Thanks for the tip on Deoxit I've not tried it. Could be a US only product?
                    Can you access the modem via telnet/ssh? Are there further line stats or error rates etc there? Could be useful for anyone who doesn't have access to their DSLAM.  :)
                      Nonsense
                      So now I've cleaned both ends of my RJ11 cable plugs and jacks with Deoxit, however, I still have some residual packet loss.  I don't think it is the cable, as I experimented with various ones a couple of years back when I also replaced my NID (yes, I did it myself–so I know it was done right), installed a Tii ADSL2+/POTS splitter in the NID, and re-terminated all my phone and DSL wiring (cat 5e) in my house inside a sealed box with punch-down blocks.  The residual packet loss problem, therefore, is likely in my ISP's wiring outdoors.  I can try lowering my DSL speed, but I somehow don't think that will solve the problem.  I likely have the most tweaked DSL line in town, but I'll try to get on my ISP's case about finding a bad splice outdoors.
                      The major telephone companies here in the Colonies, as you may already be aware, have in recent years shifted their focus entirely from copper landlines to wireless services.  The copper is left to degrade on the poles--some of the lines are as old as 70 years (as in the lead cable my ISP recently retired in my town)!  The companies just won't spend money to replace their aging copper plants.  My ISP has an excellent FTTH service, but it has not deployed it in my town and has halted deploying the service in areas in which it has not already done so in favor of spending all of its money on wireless projects--it is really a rather pitiful situation that our government tolerates in the name of Capitalism.
                      The DSLAM shows occasional CBC and UBC errors on my line--most often when my telephone rings.  I'll keep you posted on my progress.
                      Oh, and I discovered that I had not fully seated my RJ11 plug in my LinITX modem's RJ11 jack--it's now fully seated and it fits o.k.--sorry for my mistake jonesr!
                      Here follows a graph of my remaining residual packet loss as it stands this morning:
                        Nonsense
                        I lowered my DSL download speed this morning at ca. 9:08 am from ca. 15 Mbs to ca. 10 Mb/s to see if it would reduce my packet loss, however, the speed change had the opposite effect–it significantly increased my packet loss (by over an average factor of two)!  I wonder what could cause this increase when the speed change served to increase my S/N by ca. 6 dB?  Perhaps the source of my packet loss is not my telephone line after all?
                          It could be an issue with apinger itself. Quite a few people have reported that though mostly with ridiculous figures like >100% packet loss!
                          Do you see packet loss if you just run a ping test?
                            Nonsense
                            I'm still collecting data, then I'll try the ping test.  Here is a graph of when I lowered my download speed to ca. 5 mb/s, attaining a ca. 21.5 dB S/N.  Note the continued increase in packet loss as I lower the speed and thereby raise the S/N.
                              Nonsense
                              Steve:
                              Doing repeated simple pings to my DSLAM (IP address changed below to disguised it) I get no packet loss:
                              PING 12.9.74.1 (12.9.74.1): 56 data bytes
                              64 bytes from 12.9.74.1: icmp_seq=0 ttl=127 time=16.261 ms
                              64 bytes from 12.9.74.1: icmp_seq=1 ttl=127 time=16.658 ms
                              64 bytes from 12.9.74.1: icmp_seq=2 ttl=127 time=16.686 ms
                              –- 12.9.74.1 ping statistics ---
                              round-trip min/avg/max/stddev = 16.261/16.535/16.686/0.194 ms
                                Nonsense
                                Back to ca. 15 Mb/s with increased power and S/N, both downstream and upstream; this can't be right–it's got to be an apinger problem.  Yup, restarting apinger tames its readout:
                                status.restart_rrd_graph_img.php.png_thumb
                                  Try setting apinger to use a different remote address. Preferably something close to you.
                                    Nonsense
                                    I tried a different IP address in apinger and basically got the same packet loss results.  On the other hand, I tried running the ping tests at dslreports.com and saw no packet loss.  Also, all ISP tests on my DSL line indicate it is stable.  I am trying another, off site, ping test to my IP address and will report back on it when I obtain the data.
                                      Nonsense
                                      A 24-hour Ping Test (via dslreports.com) shows zero packet loss in tabulated data and graph (notch down in graph shows transition from Interleaved mode to Fastpath mode):
                                      PLG.gif_thumb
                                      • 8 Offline
                                        8ayM
                                        I'll go home and check, I'm not sure if you'd be interested trying a different PCI ADSL modem as I have a case of ones that I use to sell and get a pretty penny for on eBay. I actually just fig them out planning on selling them again for some extra dough. I'll post the model and if your interested cover shipping and one is yours.
                                        • 8 Offline
                                          8ayM
                                          The card I've got is a Songoma S518 ADSL Card 2005  Rev. C (low profile model with full size bracket), about 3 years ago I was getting over $100 each for them. Your welcome to one if you want to try a different adapter, just cover S&H.
                                            The Sangoma S518 is a real modem, rather than a router/modem on a PCI card. As such it requires a specific driver and I'm not sure one exists for FreeBSD. There is a Linux driver though so it may have been ported.
                                            Edit: Not listed on the main support site but there is a FreeBSD driver: ftp://ftp.sangoma.com/FreeBSD/wanpipe/
                                            Not sure if anything newer than FreeBSD 6 exists though.
