    Incomming connection issue when using openvpn
    17 Posts 3 Posters 4.1k Views
      armsby
      im having a strange issue that I can't seam to solve, so I hope that someone here can help
      I have setup openvpn connection and it is working for out going connections, but incomming connection are going out over the wrong interface, they are going out over the default gateway not the openvpn interface.
      I have created nat for the port I expect the data on, and I see the data getting to the computer, but the reponse is not getting routed correct,
      I have setup outbound nat for the openvpn interface
      outbound nat rules
      nat on $VPN  from 10.0.80.0/24 to any port 500 -> 10.103.1.6/32  static-port
      nat on $VPN  from 10.0.80.0/24 to any -> 10.103.1.6/32 port 1024:65535
      nat on $VPN  from 127.0.0.0/8 to any -> 10.103.1.6/32 port 1024:65535
      nat inbound
      rdr on ovpnc3 proto { tcp udp } from any to 10.103.1.6 port 49534 -> 10.0.80.24
      Reflection redirects
      rdr on { lagg0_vlan1 lagg0_vlan102 l2tp enc0 openvpn } proto { tcp udp } from any to 10.103.1.6 port 49534 tag PFREFLECT -> 127.0.0.1 port 19000
      pass  in  quick  on $VPN reply-to ( ovpnc3 10.103.1.5 ) inet proto { tcp udp }  from any to 10.0.80.24 port 49534 tracker 1416425303 keep state  label "USER_RULE: NAT Torrent"
      if I read the line above correct it says that it should reply back to the ovpnc3 interface, but it does not the replay goes over default gw
      • DerelictD Offline
        Derelict LAYER 8 Netgate
        Are there pass rules on the OpenVPN tab that also match the traffic?  If so, I believe that will match first and break reply to.  I usually delete all the rules on the OpenVPN tab when I use assigned interfaces.
        Chattanooga, Tennessee, USA
          armsby
          there is only that one rule there
          rules from the openvpn there is only this
          | type | proto | Source | Port | Destination | Port | Gateway | Queue |
          | allow | IPv4 TCP/UDP | * | * | 10.0.80.24 | 49534 | * | none |
          rules from the lan interface that make is select the openvpn interface thise are the first rules there
          | allow | IPv4 * | 10.0.80.24 | * | ! owennet | * | VPN_VPNV4 | none |
          | allow | IPv4 * | 10.0.80.24 | * | owennet | * | * | none |
          | deny | IPv4 * | 10.0.80.24 | * | * | * | * | none |
          • DerelictD Offline
            I'd ditch that rule and put it on the assigned interface's firewall rule tab instead.
              armsby
              I have tried that, but pfsense still select the wrong interface for reply-to
              • DerelictD Offline
                This stuff works, man.  pfSense is only doing what you're telling it to do.
                Use the diagram in my sig to detail exactly what you're doing and I'll build it tonight.  Please be specific.
                  armsby
                  ok using you diagram
                  pfsense A
                  connected with 2 wan, 2 openvpns
                  connectes in/out works ok on wan
                  connection works fine from lan and opt1
                  connections going out from opt1 host A2 is redirected to ovpnc2 works fine
                  connections comming in from internet ocer ovpnc2 to host A2 does not work
                  port 53 is configured be redirected to host but packages are comming threre but reply is sent over wan
                  I just created that config on my firewall as the only config there and it  did not work
                  • DerelictD Offline
                    You can't NAT on the openvpn tab.  It has to be an assigned interface. I don't see ovpnc2 in that firewall output at all.
                      armsby
                      I have tried that today, assigned it to an interface, got teh interface up with the ip, still not possible to get traffic in only out, in comming traffic are still routed back over default route not the rule's reply-to
                      • DerelictD Offline
                        post screenshots of all your rules.
                          armsby
                          ok screen shots of all my interfaces and rules comming up
                          WAN interface default gateway
                          WAN2 interface, in use if first fails
                          openvpn client1
                          nothing forwarded here works, the reply is send back over default gw
                          openvpn client2
                          same as above
                          DMZ
                          NAT
                          interface assignment
                          This is the setup I like to have working and that was working with pfsense 2 but does not work with 2.2
                          • DerelictD Offline
                            Please post the rules on the OpenVPN tab.
                              armsby
                              openvpn tab
                              • DerelictD Offline
                                Get rid of that.  In order to have things like Reply-To working, the OpenVPN tab cannot match the traffic.  I would just not put any rules on OpenVPN tab.  Put them on the appropriate assigned interface instead.
                                • DerelictD Offline
                                  Note my first post on this thread.
                                    doktornotor Banned
                                    So, what's this?
                                    Your IPsec overlaps with OpenVPN. This will never work.
                                      armsby
                                      @Derelict:
                                      Thank you, I dont know how I missed that all the when ever I checked, that rule should of cause have a limited source address range, adding that it works perfect
                                      , thank you again
