    PfSense 2.3 LAN interface stops routing traffic - stops working after 2 or 3 day
    88 Posts 31 Posters 47.3k Views
      byusinger84
      Hey guys. I saw that 2.3.1 is out, but I tried to switch from development to stable and when I refresh the update page it wants me to go to 2.3.2asomethingsomething instead of 2.3.1. Am I out of luck until 2.3.2 is out now?
        cmb
        when you were on development versions it shows 2.3.2a, but actually takes you to 2.3.1 if you're set back to the stable branch. If you stay on development, it'll take you to 2.3.2, though 2.3.2 at this instant at least is the same as 2.3.1 (granted that will start changing).
          afreaken
          On 2.3.1 factory image now, update took a little longer than anticipated, had to leave the office. Logged in remotely later and all was good. Happy again. Thanks guys.
          EDIT: 4 Days 16 Hours uptime since updating to 2.3.1, seems to be working flawlessly for me again. Thanks.
            drodrigues
            I migrated from ZYWALL usg 200 to an Intel NUC I7
            I had the same problem! Randomly firewall stopped working.
            In my case I disabled hyper threading in BIOS. The probelma kept. I disabled the the multicore and I was only one active core.
            Pfsense works good.
            My system:
            Version 2.3.2-DEVELOPMENT (amd64)
            built on Wed May 18 04:39:03 CDT 2016
            FreeBSD 10.3-RELEASE-p3
            The system is on the latest version.
            Platform pfSense
            CPU Type Intel(R) Core(TM) i7-5557U CPU @ 3.10GHz
            Uptime 03 Hours 58 Minutes 00 Seconds Current date/time
            Thu May 19 14:44:43 UTC 2016
              kim9700
              This thread seemed to die as the update went live .. I for one have been following this (started in another thread) and did the update immediately… For the 3-4 out of 8 systems affected in my network it did the trick.. Re-enabled extra cores and still going strong ...
              My issue was exactly as stated above that ipsec traffic seemed to kill the LAN interface at random times (but most likely depending on the amount of ipsec traffic).
              Would like to thank the hard working people of PFsense for their patience with not always grateful people using it .. You're doing a great job with a great product .. Thumbs up from Denmark ... :-)
              • O Offline
                OLBaID
                Just wanted to reply to the thread, got my RMA back and updated and have not had the issue for over 24 hours. wanted to share the notes so anyone that has a supermicro has some help if needed
                https://dl.dropboxusercontent.com/u/42296/SuperMicro%20RMA%20notes.PDF
                And just to point to the solution that was most likely the issue:
                https://redmine.pfsense.org/issues/6296
                  murmur
                  Crap. I have upgraded to 2.3.1_1 last Sunday and the pfsense has locked up twice since. Everything is fine after a reboot but after roughly 2 days LAN just locks up. Hardware ran without problems prior to this upgrade.
                    cmb
                    The issue here is 100% confirmed fixed by at least dozens of people across hundreds of systems. I'm locking this thread to prevent further hijacking. Please start your own thread if you're having an issue, as it isn't the same as this one.
