PfSense 2.3 LAN interface stops routing traffic - stops working after 2 or 3 day
I seen to be running in a very similar problem. 2.3 was running fine for days and yesterday evening everything was dead. Or so I believed. I restarted and everything was back. This morning: Internet dead again. Restarted, but still no change. Restarted, everything ok. I then upgraded to 2.3.1, restarted, everything dead. So I attached the serial console just to find that the system was up, WAN connected, responsive, LAN IP attached… Just no traffic on LAN.
I simply did ifconfig igb2 down and up and all was running.
Yes I have IPSEC (and I unfortunately need it). It is on an APU with 4 cores. What is puzzling me is why this is happening right after reboot?
I do nfs copies over ipsec between sites so we definitely send some udp traffic through the firewall. It is not a lot of traffic though so maybe that is why it only happened once so far on my system. Almost 4 days now. Initially it happened after 10 hours.
@cmb:
We've confirmed it's not specific to any particular NIC. Happens on em, igb, and re at a minimum, and probably anything.
It seems to be related to UDP traffic streams across IPsec. dd /dev/urandom to UDP netcat with a bouncer back on the other side, and it's replicable within a few minutes to a few hours. Faster CPUs seem to be less likely to hit the issue quickly.
It seems like it might be specific to SMP (>1 CPU core). I haven't been able to trigger it on an ALIX even beating it up much harder, relative to CPU speed, than faster systems where it is replicable.
If you're running on a VM and seeing this issue with >1 vCPU, try changing your VM to 1 vCPU.
If you're on a physical system, you can force the OS to disable additional cores. Take care when doing this, try it on a test system first if you're not comfortable with doing things along these lines.
dmesg | grep cputo find the apic. You'll have something like:
cpu0 (BSP): APIC ID: 0 cpu1 (AP): APIC ID: 2In /boot/loader.conf.local (create file if it doesn't exist), add:
hint.lapic.2.disabled=1where 2 is the APIC ID of the cpu1 CPU core to disable. Replace accordingly if yours isn't 2. Add more lines line that for each additional CPU to disable so you only have cpu0 left enabled. Reboot.
Then report back if it happens again. That might suffice as a temporary workaround, and will give us additional data points in finding the specific root cause.
AWESOME! Thank you! I will do this and report back. Question, if the system is a dual core with hyper-threading, do the hyper-threads show up as a core as well and do they also need to be disabled?
Someone tried to disable the hyper threading in the bios?
For tests only.
I always disable hyperthreading on firewalls so they are disabled on my systems when i had the
crashlost packets. -
We've confirmed that the problem no longer occurs after disabling all but one CPU core. So that looks to be a viable immediate workaround for most users. See instructions in my post here.
https://forum.pfsense.org/index.php?topic=110710.msg618388#msg618388I doubt if Hyperthreading is relevant either way. It happens in any SMP system including ones without HT. Any HT cores will also need to be disabled for the workaround, but not because they're HT, just additional cores.
I am having the same issue randomly stops routing traffic to all vlans. If i reboot it will be fine for a day or so then does it again
Add me to the list as well. I've got this happening on both a SUPERMICRO SYS-5018A-FTN4 1U Rackmount Server (C2758 8-core) as well as a SG-2440 pfSense appliance (C2358 2-core). Both have Intel igb x 4 interfaces on them. And they have IPSEC tunnels (required to reach the colo where our VOIP phone system is). However, what's interesting is it's NOT happening on my home system which is a AMD Athlon System (a dell I got for $250 from Best Buy 4+ years ago) which has dual intel em interfaces on it. I have the same IPSEC tunnels on it (so I have 4 total locations, 2 offices, my home, and a COLO, all 4 running pfSense (the COLO is still 2.2.6), and they're all connected to each other (so every location has 3 IPSEC tunnels)). This didn't start occurring until 2.3. I actually thought maybe this had something to do with AES-NI since the only systems I have AES-NI on are the ones affected..
I'm going to try the single core trick to see if that helps for now, though I'm concerned with speed issues (as I have the 8-core C2758 in a location that has Gigabit because the C2358 maxed out around 600Mbit).. NOTE: I guess it's not the number of cores that cause the C2758 to be able to handle gigabit, but rather the faster clock speed.. Even with 1 core it's still able to handle the full gigabit.. So that's good..
@cmb:
Disabled all but one core. I will let you know if I continue to have issues. Please let me know when there is a more permanent fix.
Hello add me + as well, recently upgraded hardware from an ALIX to a SuperMicro SBE200-9B with 4 IGB NICs, I am getting the watchdog timeout error as well on the new hardware (not on the ALIX) as the LAN IGB1 will drop randomly every few days:
https://dl.dropboxusercontent.com/u/42296/SuperMicroPfsense.JPG
Doing some research prior to finding this thread I found:
https://doc.pfsense.org/index.php/Disable_ACPI
Now reading this I can try to disable the other cores for now. Hoping there is a solution soon.
Love PFsense for many years, cant say that enough!
I'm getting this as well. Most of my pfSense are virtual machines running on VMWare ESXi.
I use pfSense for building site-to-site IPSEC tunnels (Blowfish encryption).
In my case it's happening when I see heavy loads across the IPSEC tunnel (this is normally at night, for running backups).
It appears traffic stops completely on the LAN interface. If I look on the console, I see "em0: Watchdog timeout – resetting" or something to that effect (where em1 is my LAN interface).
For encryption, I use Blowfish 256 bit with a SHA512 Hash Algorithm. DH Group Phase 1 - 8192 bit.
For phase 2, I use ESP with Blowfish 256 bit with a SHA512 Hash Algorithm. PFS key group 18 - 8192 bit.
After reducing the DH Key Group + PFS Key Group to to 14 - 2018 bit I have noted an increase in stability (it hasn't locked in about a week). I've just applied this "workaround" on a few other machines I manage, I will report back on this.
I am afraid this did not do the trick. It happened again yesterday evening. So I disabled Cores 1,2,3 with
hint.lapic.1.disabled=1
hint.lapic.3.disabled=1and rebooted. This morning: LAN was dead once again. I logged in on the serial console, did
ifconfig igb2 down
ifconfig igb2 upand 5-10 seconds later everything else was back online. I noticed tons of
ifa_add_loopback_route: insertion failed: 17
cpu (AP): APIC ID: 1 (disabled)
cpu (AP): APIC ID: 2 (disabled)
cpu (AP): APIC ID: 3 (disabled)So I assume the cores ARE disabled! Something else going on? What do you pfsense gurus want me to do/debug the next time it happens?
Regards,
JP -
ifconfig igb2 down
That all looks correct. The only really solid confirmation I have that it fixes it is with em and re NICs. They're single-queue, where igb is multi-queue, so it's possible there's more to it in the igb case. igb's num_queues could be set to 1, but that has a pretty significant impact on achievable top end throughput.
an ifconfig down and up of the interfaces with SMP doesn't do anything that I've seen, the fact the network comes back with that suggests it's "better" than before. Not that dead is any better than dead.
Only that the ifconfig down/up stuff even worked before I disabled the cores… :-)
I now have a cronjob that checks the LAN interface every minute and if it cannot ping internal systems restarts the interface and logs it to system.log. If you need me to run additional debugs: Go ahead please! :-)
Regards,
JP -
Thank you for this workaround!
Disabling the CPUs seems to solve my problems for the moment.
On my Supermicro MBD-X7SPA-HF with Quad em pcie card, using multiple vlans and ipsec tunnels:
- Traffic on vlan Interfaces dead after some time. From 15min up to a few hours at most.
- Wan and pfsense still responding
- Reboot solves the problem (multiple times a day)
Same behaviour with a replacement asrock Q1900M and Quad em card.
Other observations:
Old alix 2d13 runs fine with the same vlan/ipsec setup (very slow, but ok as backup).
2 boxes with a gigabyte j1900n-d3v also run fine without disabling the cores:
- using the onboard re interfaces
- they also have some ipsec tunnels
- they do not have vlan interfaces
Regards,
JPhey jp, could you share the script for that cron job?
in my case alix apu box stays up, no problems with it. sg2440 locked up once and soekris 6501 locks every couple days. -
Sure..
#!/usr/local/bin/perl use Net::Ping; use Sys::Syslog; $server_to_ping="192.168.1.1"; $server_to_ping2="192.168.1.2"; sub check_ping_server { $host_alive=1; $ping=Net::Ping->new('icmp'); if( $ping->ping($_[0]) ) { $host_alive=1;} else {$host_alive=0;} return $host_alive; } if(!check_ping_server($server_to_ping) && !check_ping_server($server_to_ping2)) { system("ifconfig igb2 down"); system("sleep 2"); system("ifconfig igb2 up"); system("sleep 5"); openlog("checkigb2", "ndelay", LOG_USER); syslog('notice', 'IP check failed, igb2 restarted'); closelog(); } else { openlog("checkigb2", "ndelay", LOG_USER); syslog('notice', 'IP check ok'); closelog(); } exit;Not the best piece of coding but it seems to do the trick.
Regards,
JP -
Hi been tracking the bug (thanks CMB!):
https://redmine.pfsense.org/issues/6296
A comment on the bug tracker had this link:
https://forum.pfsense.org/index.php?topic=107471.msg602590#msg602590
This user disabled the following in System/ Advanced / Networking:
I had all enabled:
Disable hardware checksum offload
Disable hardware TCP segmentation offload
Disable hardware large receive offloadCan anyone else here confirm if this helps if they are experiencing the issue (I am working to get this hardware back online soon to test myself)
Not trying to muddy any waters, but hoping for a fast resolution.
I had these options disabled even before the upgrade to 2.3.
Only disabling the CPU cores solves the issue for me. -
I'm having the same issue. Disable CPU cores, still under monitoring.
Hopefully the fix release asap.Update:
It does not work for me, the issue just happen again.
