    How to connect to particular AP when many APs with same ssid
    2 Posts 2 Posters 2.8k Views
      pcatiprodotnet
      Is there a way to tell pfSense (as an AP client) to always connect to a particular AP, even though there are many APs nearby with the exact same SSID and channel?
      Thank you, -Pete
      • L Offline
        lsf
        This is not implemented in GUI, but you could use this parameter on command line, and possibly also hardcode it into /etc/inc/interfaces.inc
        bssid address
            Specify the MAC address of the access point to use when operating
            as a station in a BSS network.  This overrides any automatic
            selection done by the system.  To disable a previously selected
            access point, supply any, none, or - for the address.  This
            option is useful when more than one access points have the same
            SSID.  Another name for the bssid parameter is ap.
        This will tell the client to only associate to the AP with whatever mac address you specified.
        -lsf
