    [Solved] PROBLEMS WITH SERIAL CONSOLE
    14 Posts 5 Posters 4.0k Views 5 Watching
      jmv43
      Anyone having problems installing Prolific drivers in Windows 10 1803? Drivers are used to gain access to SG-1100.
        wkn
        Hi @jmv43 ,
        i used a Profilic 2303 a long time to access the serial console of my pfSense.
        But this also stopped working with Windows 10. On the driver download page http://www.prolific.com.tw/US/ShowProduct.aspx?p_id=225&pcid=41 there was an information about this. Maybe your Profilic used has same issue.
        I bought some cheap USB-toSerial adapter then and it works since.
        BR
        wkn
        J JKnottJ 2 Replies Last reply Reply Quote 0
          jmv43 @wkn
          I never had it installed, need it now to access serial console on the SG-1100 and can't install any of them. Can you be more specific on what you purchased?
          THANKS
          jmv
          • jimpJ Offline
            Which drivers are you installing?
            The console serial device in the SG-1100 is a pl2303
            T:  Bus=03 Lev=03 Prnt=10 Port=03 Cnt=04 Dev#= 14 Spd=12  MxCh= 0
            D:  Ver= 1.10 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs=  1
            P:  Vendor=067b ProdID=2303 Rev=04.00
            S:  Manufacturer=Prolific Technology Inc.
            S:  Product=USB-Serial Controller D
            C:  #Ifs= 1 Cfg#= 1 Atr=a0 MxPwr=100mA
            I:  If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=pl2303
            The SG-1100 manual contains a link to the drivers at https://prolificusa.com/product/pl2303hx-rev-d-usb-serial-uart-bridge-controller/ -- It's the last driver in the list, labeled Windows Driver Installer Setup Program
            Do not Chat/PM for help!
              jmv43
              Thanks for your response. I have tried that one also with no results. I have opted for downgrading Windows to 1703 to see what happens.
              JMV
              • jimpJ Offline
                What do you mean exactly by "no results"?
                What shows up in device manager?
                • JKnottJ Offline
                  JKnott @wkn
                  @wkn said in PROBLEMS WITH SERIAL CONSOLE:
                  Hi @jmv43 ,
                  I also have one of those cheap adapters, which I bought several years ago. When I checked it in the Control Panel, there was an error message that said it couldn't start. After installing that driver, it now works.
                  BTW, I've never had a problem with that adapter in Linux. It just works.
                  UniFi AC-Lite access point
                    jmv43 @jimp
                    No results means that the results you were expecting are not there. Nothing has shown up in the device manager.
                    JMV
                    • jimpJ Offline
                      @jmv43 said in PROBLEMS WITH SERIAL CONSOLE:
                      That is still very ambiguous.
                      That, however, is a real clue.
                      If nothing shows up in device manager, perhaps it is not making a good physical connection. Even if you are using the included USB cable, try another one.
                        jmv43
                        I have tried several cables already as per the troubleshooting with support. I don't have the resources or the skills to perform this procedure. I guess I will be returning the box.
                        JMV
                          tim.mcmanus @jmv43
                          JMV
                          All kidding aside, find someone with a Mac and plug it into that. Follow these instructions:
                          https://docs.netgate.com/pfsense/en/latest/hardware/connecting-to-the-serial-console.html
                          It will "just work", or at least there's a high probability it will.
                            jmv43 @jimp
                            So how many cables should I try?
                            JMV
                              jmv43
                              Never mind got a cable, it is working.
                                jmv43
                                You can consider this problem solved.
