    Upgrade Pfsense system 23 july For Multi WAN + MULTI LAN (Open vpn, Wireless)
    45 Posts 13 Posters 31.1k Views
      gladizxx
      Don't worry be happy with Pfsense…...  :)
        wonslung
        is the local dns working?
        (dnsmasq)
          gladizxx
          @wonslung:
          (dnsmasq)
          yes .. (dnsmasq) local dns running well, even when we HigHT setting priorities at the beginning of the dns settings Shaper traffic, the performance to access the internet to become more aggressive. Of course this relates to setting the general traffic in the Shaper.
            wonslung
            i've been using a snapshot from march 17t…i finally got it working perfectly, even have squid working in shaping thanks to a very helpful post http://forum.pfsense.org/index.php/topic,14436.0.html
            and these changes to /boot/loader.conf
            #kern.ipc.nmbclusters="0"
            kern.ipc.nmbclusters="32768"
            kern.maxfiles="65536"
            kern.maxfilesperproc="32768"
            net.inet.ip.portrange.last="65535"
            i guess it wouldn't be too hard to revert back to my old install if something went wrong.
              gladizxx
              Truly amazing performance pfsense april 12 update 2009 .. cpu performance more efficient and lightweight than ever before.
              Indeed rightly pfsense what our users have to say many thanks to the team pfsense.
              Multi Wan running well once. normal running load balancing, wirelless ok. VPN normal.
              Once again I strongly recommend the use pfsense on your company.
              Regard.
              gladizxx - INA
              • valnarV Offline
                valnar
                I'll take the hit….and hope I don't get flamed too hard.
                How soon on the 1.23 release?  I need to deploy a couple ALIX boards in the field and since a remote upgrade of the embedded build is not an option, I'd like it to be fully baked.
                  gladizxx
                  A case, which I never do is upgrade from version 1.2.2 to 1.2.3 on 12 april 2009, in general, not much change the system.
                  There are only a few changes in its package. because the system must update the package again and again .. need settings
                    gladizxx
                    In general update 16 april 2009 almost no difference with the update 13 april 2009.
                    But I kept update .. 16 april response more aggressive than before.
                    Package is installed before it can run as normal.
                      brenix
                      Just upgraded from the Apr 7th build and wow! The WebGUI is a lot faster as well as my net speed. Great job Devs!
                        jits
                        I have to second that.
                        HTTPS access via internet is much better and OPENVPN config pages loads much faster.
                        Ping times over VPN have also been improved going from double digit MS response times to single digit majority response times.
                        Thank you again.
                          gladizxx
                          Update pfsense 18 april 2009 - 0925 performance the better, Compared with the previous date.
                          Performance of the cpu the more aggressive and efficient, Filter reload faster and more aggressive, VPN normal, dhcp normal, daskboard normal, Multi Wan the good performance. Traffic sharper the reponsif. Until this stage in my personal value to pfsense = 99.5. if the best standards = 100
                            gladizxx
                            Load Balance is excellent. Just when we update from previous versions.
                            Reload load balance will take approximately 40 minutes. Then run the normal and very aggressive.
                            Gladizxx - INA
                              gladizxx
                              Very extraordinary Update pfsense on 20 april 2009 - 1033.
                              There was a significant increase in performance compared with the previous update.
                              Multi wan normal, dhcp, dns, VPN, pppoe, wirelless all running normally.
                              Reload filter is very aggressive. I give the value of 99.7 if the best standard = 100.
                              I strongly recommend the use Pfsense your company. And do not forget Pfsense grateful to the Team has provided many contributions to the success of this project.
                              regard.
                              Gladizxx - Indonesia
                                gladizxx
                                Although the filters do not reload as quickly as upadate before.
                                The occurrence of delay, I think because the system changes aimed at increasing response and agrsifitas's performance.
                                However, do not affect the performance in general are efisient.
                                Thus in Update 23 april 2009 - 0918 I feel more stable performance.
                                regard
                                  gladizxx
                                  Although the filter is a bit reload takes time. But this does not disrupt the performance in general.
                                  But we will feel as though we are not running settings, such as sharper traffic, load balance, and so forth.
                                  Thus I felt the updated version 24 april 2009 1047 general this system is more stable, stable, load balance, traffic Shaper, multi wan also more stable.
                                  does not believe? …...Please try it out .. :)
                                    wonslung
                                    I've been following this post….mainly because it makes me laugh every time.....i agree that it's awesome but you're so excited that it makes ME excited
                                      scottnguyen
                                      ;D LOL…the fella is overly gitty isn't he?!!  hahaha...good thing pfSense is.  ;D
                                        gladizxx
                                        "" I think, every person is free to give opinions about things. And also other people's opinions. regardless of like or dislike."
                                          gladizxx
                                          Don't worry be happy with Pfsense.. :)
                                            wonslung
                                            i meant no disrespect brother.
                                            I love pfsense.
                                            your posts are dead on, they are just funny.
