    How pfSense utilize multicore processors and multi-CPU systems ?
    hardwaremulti coremulti cpusetuptuning
    23 Posts 6 Posters 21.8k Views 8 Watching
    • Sergei_ShablovskyS Offline
      Sergei_Shablovsky
      At the first let me say BIG THANKS for briefly but “all that you need” answer!
      And for patience, because I thinking this is one of the most asking question on that forum (and on FreeBSD.org also). :) Take my respect!
      @andyrh said in How pfSense utilize multicore processors and multi-CPU systems ?:
      @sergei_shablovsky Your question from 2/2021 is slightly flawed. The CPU package count is not relevant. Cores (threads) and frequency are relevant.
      Because most of all rack servers are 2xCPU packaged, this is something like default for users that prefer own rackmounted hardware.
      But for Netgate original brand firewalls - may be this is not true default because most of their Motherboards (I remember NetGate using LANNER MB in early models, but after switch to SuperMicro, is this still true using SuperMicro?) are 1 x CPU package. And in this case there are only one ability to increasing performance when You bandwidth grow - more speedy processor with a large Cache 3 level.
      For tasks that are single threaded frequency is what you want, for tasks that are multi threaded you want enough threads to allow the concurrency you need.
      So, may be great idea for NetGate create some reference table for users that prefer own hardware, in which some characteristics (single/multithreaded, requirements of CPU frequency, memory) linked to main services and additional packages (like Snort, Suricata, etc...) that require much system resources?
      To help choose right NICs and server platform.
      Reasonable ?
      The result is a balance based on your goals. If single threaded tasks are your number one concern, you will lean to frequency at the expense of cores. However if you have several packages and many NICs, you will lean to core count at the expense of frequency because you will have many threads needing to execute at the same time and it is more efficient for the computer to have many threads vs having to share.
      The initial question in this topic combine inside two:
      • how FreeBSD core manage threads between CPU packages in multi-CPU packages systems (2, 4), because bus between CPUs packages involved, NUMA/non-NUMA/chipkill memory configuration in BIOS, etc...;
      • how different packages/services in pfSense depends on NICs configuration and tuning, CPUs packages numbers and frequencies;
      I hope that helps.
      Really, thank You.
      CLOSE SKY FOR UKRAINE https://youtu.be/_tU1i8VAdCo !
      Help Ukraine to resist, save civilians people’s lives !
      (Take an active part in public protests, push on Your country’s politics, congressmans, mass media, leaders of opinion.)
        greedj
        What system is better for network-related operation (i.e. firewall, load balancing, gate, proxy, media stream,...):
        a) 1 CPU with 4-10 cores, hi-frequency
        b) 2-4 CPU with 4-6 cores, mid-frequency
        Single CPU with more cores is usually better than multiple sockets with the same/less cores with networking gear. This is especially true when running on a hypervisor platform.
        If the hypervisor hardware has multiple physical CPU sockets, see if the VM can be pinned to cores on CPU0 (Or whatever CPU the bus for the physical NIC is attached, usually CPU0)
        If the physical hardware NICs are attached to the BUS on CPU0 but the VM is running on CPU1 or higher, there can be issues in high traffic situations. This is usually seen as: Everything works perfectly until a certain threshold of network traffic is hit and when that happens, you may start to see packet drop/loss/re-transmits.
        Non network gear is usually not affected, this is mainly for virtualized switches/proxies/scalers/routers/etc.
        Sergei_ShablovskyS 1 Reply Last reply Reply Quote 2
          Sergei_Shablovsky @greedj
          @greedj Thank You!
          Primary I mean running pfSense only on bare metal servers w/ 2 CPUs. No any reason to run virtualization because of highloading, even more: better to make HA cluster of pfSense (with two(2) independent online-interactive UPS - each to one of server’s power supply, and more than 2 uplinks to power provider).
