    PPPOE wan will not connect -
    113 Posts 9 Posters 33.1k Views 11 Watching
      gerryatric @biggsy
      @biggsy Hi Phil
      I have no idea where that is coming from. It isn't there immediately.
      I have no gear on the local lan producing a 10.20.26.0 range at all
      I am running ZeroTier SD Wan software on some of my nodes but that is machine dependent. must have a client installed. and it is not in that range anyway.
      I do not know where that is coming from
        biggsy @gerryatric
        @gerryatric
        I think we need to find what's handing out that RFC1918 address. That looks like it's totally confusing PPPoE on your WAN.
        Maybe a port mirror on the SR2024 and packet capture would tell us. I can't help with the Cisco stuff, unfortunately.
        Maybe not. Seems the SR2024 is unmanaged.
          gerryatric @biggsy
          @biggsy yes it is just an unmanaged switch used to split the nbn signal is all. has the usg and the edgerouter connected to it
          • stephenw10S Online
            Having a private IP as the gateway for PPPoE is not that unusual and works fine. Both of mine are like that. Is that public IP in a range you expect?
            I still find it odd that you are able to connect more that one client at a time though. Especially in a setup where it appears the password is not checked.
              Patch @stephenw10
              @stephenw10 said in PPPOE wan will not connect -:
              Agree
              Would suggest connecting just one pfsense client as a test.
                gerryatric @Patch
                @patch Ho
                have done that many times. directly to the wan port from the fibre box. no luck
                P G 2 Replies Last reply Reply Quote 0
                  Patch @gerryatric
                  @gerryatric
                  Why is it that you are using a vlan again?
                  You do have to connect to the correct physical lan port on the NBN fibre to the home modem/router
                  https://help.iinet.net.au/set-ftth
                  but vlan is not a prominent requirement on my reading of it.
                  Also when changing your router, how long did you wait for NBN to accept your new router. Aussie Broadband enables the user to kick the connection to accelerate this process, not sure how to do this with iiNet.
                    gerryatric @gerryatric
                    @gerryatric No as per the many above messages. IINET NBN fibre require their connections to use a vlan id.
                    so we have to use it. it is working on the USG and the edgerouter. just not Pfsense.
                    I don't need to kick any connection or wait for it to timeout as I can run multiple wan connections at same time.
                      Patch @gerryatric
                      @gerryatric I'm aware you believe that is the case however it is not working as you believe it should, so perhaps that is not how it works.
                      The NBN fibre to the home NTD has several "LAN" ports. NBN only activate the ports you pay for. Those ports are your WAN ports despite the label written on them.
                      You connect your router to the NBN "Wan" port (their box with the port labeled "LAN"). From YOUR routers Lan ports you can connect as many devices as you like. eg
                      NBN NTD lan1 -> wan port, Edge router, Lan ports -> USG, Wifi A, wired computer etc
                      or
                      NBN NTD lan1 -> wan port, pfsense router, Lan ports -> USG, Wifi A, wired computer etc
                      Possibly Ubiquiti has been doing this transparently for you
                      Personally I would configure it as per https://help.iinet.net.au/set-ftth including leaving it for over the 15min specified after changing routers.
                        gerryatric @Patch
                        @patch What I Believe?
                        seriously. I have been on this forum subject for over a week.
                        What I actually have running on this system is actually a USG pro 4 router running from the same switch as the PFSENSE box. an Edgerouter X SFP running on the same switch as the PFSEnse box.
                        So the 2 ubiquiti devices work fine together. that is a fact.
                        so yes I have disconnected both of those and setup the Pfsense by itself. and yes it has been connected for more than 15 mins. that also is a fact.
                        Sorry, but this is not my first rodeo. I am well versed in IT stuff, 35 years worth. This is however my first PFSense box and yes I understand that it should just work. but after reading through hundreds of posts over the last week or so and I am not the only person having issues with PPPOE ok.
                        So please be a little more helpful to a newbie to the forum and PFSENSE than starting a conversation with " I am aware you believe that this is the case. however """"" so perhaps that is not how it works."
                        I have tried every suggestion so far, some made sense and some were ridiculous.
                        I am grateful for every bit of advice so far from the many positive contributors.
                        It pains me to let this beat me.
                          Were you able to get a connection log from either UBNT device?
                          That might well have the clue that we need. Some different default setting.
                          Other than that I would be pcap'ing the connection from a working device to see exactly what it is sending at this point.
                            Patch @gerryatric
                            @gerryatric a diagram showing all physical connections, switches, routers and RFC1918 IP address would help. Both for the configuration that works and doesn’t work.
                            I wonder if ubiquiti links their component (via their configuration ap) hiding some details which have to be done manually in a mixed environment.
                            Edit
                            The easiest way exclude ubiquiti automatic configuration preventing another router (pfsense) maintaining a wan connection would be to temporary power off the ubiquiti routers.
                              CajunSands
                              Read thru most however I have a protectli PFSENSE ( 2.5..2 ) box behind my ISP fiber modem.
                              In the setup i just put in my PPPOE username and password and it set it up and just works.
                              My ISP here in Dubai requires my wan to be connected on a certain port on the modem ( ONT4)
                              Otherr than that it just works and I am not a real technical guy.
