PPPOE wan will not connect -
@biggsy said in PPPOE wan will not connect -:
I'm also surprised that you were able to connect the USG and Edgerouter to the NBN through the switch and get two public IPs.
I agree, that's surprising. But if it works....
ok so followed the guide for NBN on IINEt. which I might add is exactly how we had it connected.
Sadly to say, seems like same issuehere is log
Sep 13 23:30:31 ppp 55591 [wan] IPV6CP: Close event Sep 13 23:30:31 php-fpm 436 /rc.linkup: calling interface_dhcpv6_configure. Sep 13 23:30:31 php-fpm 436 /rc.linkup: Accept router advertisements on interface em0.2 Sep 13 23:30:31 php-fpm 436 /rc.linkup: Killing running rtsold process Sep 13 23:30:32 ppp 94456 waiting for process 55591 to die... Sep 13 23:30:33 ppp 94456 waiting for process 55591 to die... Sep 13 23:30:33 php-fpm 436 /rc.linkup: Starting rtsold process Sep 13 23:30:33 ppp 55591 [wan] Bundle: Shutdown Sep 13 23:30:33 ppp 55591 [wan_link0] Link: Shutdown Sep 13 23:30:33 ppp 55591 process 55591 terminated Sep 13 23:30:34 ppp 94456 web: web is not running Sep 13 23:30:34 ppp 94456 [wan] Bundle: Interface ng0 created Sep 13 23:30:34 ppp 94456 [wan_link0] Link: OPEN event Sep 13 23:30:34 kernel ng0: changing name to 'pppoe0' Sep 13 23:30:34 ppp 94456 [wan_link0] LCP: Open event Sep 13 23:30:34 ppp 94456 [wan_link0] LCP: state change Initial --> Starting Sep 13 23:30:34 ppp 94456 [wan_link0] LCP: LayerStart Sep 13 23:30:34 ppp 94456 [wan_link0] PPPoE: Connecting to '' Sep 13 23:30:35 php-fpm 436 /rc.linkup: Gateway, none 'available' for inet, use the first one configured. 'WAN_PPPOE' Sep 13 23:30:35 php-fpm 436 /rc.linkup: Gateway, none 'available' for inet6, use the first one configured. 'WAN_DHCP6' Sep 13 23:30:35 check_reload_status 374 Restarting ipsec tunnels Sep 13 23:30:39 check_reload_status 374 updating dyndns wan Sep 13 23:30:39 check_reload_status 374 Reloading filter Sep 13 23:30:39 ppp 20014 Multi-link PPP daemon for FreeBSD Sep 13 23:30:39 ppp 20014 process 20014 started, version 5.9 Sep 13 23:30:39 ppp 20014 waiting for process 94456 to die... Sep 13 23:30:39 ppp 94456 caught fatal signal TERM Sep 13 23:30:39 ppp 94456 [wan] IFACE: Close event Sep 13 23:30:39 ppp 94456 [wan] IPCP: Close event Sep 13 23:30:39 ppp 94456 [wan] IPV6CP: Close event Sep 13 23:30:39 php-fpm 42735 /rc.linkup: calling interface_dhcpv6_configure. Sep 13 23:30:39 php-fpm 42735 /rc.linkup: Accept router advertisements on interface em0.2 Sep 13 23:30:39 php-fpm 42735 /rc.linkup: Killing running rtsold process Sep 13 23:30:40 ppp 20014 waiting for process 94456 to die... Sep 13 23:30:41 ppp 94456 [wan] Bundle: Shutdown Sep 13 23:30:41 ppp 94456 [wan_link0] Link: Shutdown Sep 13 23:30:41 ppp 94456 process 94456 terminated Sep 13 23:30:41 ppp 20014 web: web is not running Sep 13 23:30:41 ppp 20014 [wan] Bundle: Interface ng0 created Sep 13 23:30:41 ppp 20014 [wan_link0] Link: OPEN event Sep 13 23:30:41 kernel ng0: changing name to 'pppoe0' Sep 13 23:30:41 ppp 20014 [wan_link0] LCP: Open event Sep 13 23:30:41 ppp 20014 [wan_link0] LCP: state change Initial --> Starting Sep 13 23:30:41 ppp 20014 [wan_link0] LCP: LayerStart Sep 13 23:30:41 ppp 20014 [wan_link0] PPPoE: Connecting to '' Sep 13 23:30:41 php-fpm 42735 /rc.linkup: Starting rtsold process Sep 13 23:30:43 php-fpm 42735 /rc.linkup: Gateway, none 'available' for inet, use the first one configured. 'WAN_PPPOE' Sep 13 23:30:43 php-fpm 42735 /rc.linkup: Gateway, none 'available' for inet6, use the first one configured. 'WAN_DHCP6' Sep 13 23:30:43 check_reload_status 374 Restarting ipsec tunnels Sep 13 23:30:46 check_reload_status 374 updating dyndns wan Sep 13 23:30:46 check_reload_status 374 Reloading filter Sep 13 23:30:46 ppp 43300 Multi-link PPP daemon for FreeBSD Sep 13 23:30:46 ppp 43300 process 43300 started, version 5.9 Sep 13 23:30:46 ppp 43300 waiting for process 20014 to die... Sep 13 23:30:46 ppp 20014 caught fatal signal TERM Sep 13 23:30:46 ppp 20014 [wan] IFACE: Close event Sep 13 23:30:46 ppp 20014 [wan] IPCP: Close event Sep 13 23:30:46 ppp 20014 [wan] IPV6CP: Close event Sep 13 23:30:46 php-fpm 75400 /rc.linkup: calling interface_dhcpv6_configure. Sep 13 23:30:46 php-fpm 75400 /rc.linkup: Accept router advertisements on interface em0.2 Sep 13 23:30:46 php-fpm 75400 /rc.linkup: Killing running rtsold process Sep 13 23:30:47 ppp 20014 PPPoE: rec'd ACNAME "bri-apt-wic-bras206" Sep 13 23:30:47 ppp 43300 waiting for process 20014 to die... Sep 13 23:30:48 ppp 20014 [wan] Bundle: Shutdown Sep 13 23:30:48 ppp 20014 [wan_link0] Link: Shutdown Sep 13 23:30:48 ppp 20014 process 20014 terminated Sep 13 23:30:48 ppp 43300 web: web is not running Sep 13 23:30:48 ppp 43300 [wan] Bundle: Interface ng0 created Sep 13 23:30:48 ppp 43300 [wan_link0] Link: OPEN event Sep 13 23:30:48 kernel ng0: changing name to 'pppoe0' Sep 13 23:30:48 ppp 43300 [wan_link0] LCP: Open event Sep 13 23:30:48 ppp 43300 [wan_link0] LCP: state change Initial --> Starting Sep 13 23:30:48 ppp 43300 [wan_link0] LCP: LayerStart Sep 13 23:30:48 ppp 43300 [wan_link0] PPPoE: Connecting to '' Sep 13 23:30:48 php-fpm 75400 /rc.linkup: Starting rtsold process Sep 13 23:30:50 ppp 43300 PPPoE: rec'd ACNAME "bri-apt-wic-bras207" Sep 13 23:30:51 php-fpm 75400 /rc.linkup: Gateway, none 'available' for inet, use the first one configured. 'WAN_PPPOE' Sep 13 23:30:51 php-fpm 75400 /rc.linkup: Gateway, none 'available' for inet6, use the first one configured. 'WAN_DHCP6' Sep 13 23:30:51 check_reload_status 374 Restarting ipsec tunnels Sep 13 23:30:54 check_reload_status 374 updating dyndns wan Sep 13 23:30:54 check_reload_status 374 Reloading filter Sep 13 23:30:54 ppp 69826 Multi-link PPP daemon for FreeBSD Sep 13 23:30:54 ppp 69826 process 69826 started, version 5.9 Sep 13 23:30:54 ppp 69826 waiting for process 43300 to die... Sep 13 23:30:54 ppp 43300 caught fatal signal TERM Sep 13 23:30:54 ppp 43300 [wan] IFACE: Close event Sep 13 23:30:54 ppp 43300 [wan] IPCP: Close event Sep 13 23:30:54 ppp 43300 [wan] IPV6CP: Close event Sep 13 23:30:54 php-fpm 68095 /rc.linkup: calling interface_dhcpv6_configure. Sep 13 23:30:54 php-fpm 68095 /rc.linkup: Accept router advertisements on interface em0.2 Sep 13 23:30:54 php-fpm 68095 /rc.linkup: Killing running rtsold process Sep 13 23:30:55 ppp 69826 waiting for process 43300 to die... Sep 13 23:30:56 ppp 43300 [wan] Bundle: Shutdown Sep 13 23:30:56 ppp 69826 waiting for process 43300 to die... Sep 13 23:30:56 ppp 43300 [wan_link0] Link: Shutdown Sep 13 23:30:56 ppp 43300 process 43300 terminated Sep 13 23:30:56 php-fpm 68095 /rc.linkup: Starting rtsold process Sep 13 23:30:57 ppp 69826 web: web is not running Sep 13 23:30:57 ppp 69826 [wan] Bundle: Interface ng0 created Sep 13 23:30:57 ppp 69826 [wan_link0] Link: OPEN event Sep 13 23:30:57 kernel ng0: changing name to 'pppoe0' Sep 13 23:30:57 ppp 69826 [wan_link0] LCP: Open event Sep 13 23:30:57 ppp 69826 [wan_link0] LCP: state change Initial --> Starting Sep 13 23:30:57 ppp 69826 [wan_link0] LCP: LayerStart Sep 13 23:30:57 ppp 69826 [wan_link0] PPPoE: Connecting to '' Sep 13 23:30:58 php-fpm 68095 /rc.linkup: Gateway, none 'available' for inet, use the first one configured. 'WAN_PPPOE' Sep 13 23:30:58 php-fpm 68095 /rc.linkup: Gateway, none 'available' for inet6, use the first one configured. 'WAN_DHCP6' Sep 13 23:30:58 check_reload_status 374 Restarting ipsec tunnels Sep 13 23:31:01 check_reload_status 374 updating dyndns wan Sep 13 23:31:01 check_reload_status 374 Reloading filter Sep 13 23:31:01 ppp 96412 Multi-link PPP daemon for FreeBSD Sep 13 23:31:01 ppp 96412 process 96412 started, version 5.9 Sep 13 23:31:01 ppp 96412 waiting for process 69826 to die... Sep 13 23:31:01 ppp 69826 caught fatal signal TERM Sep 13 23:31:01 ppp 69826 [wan] IFACE: Close event Sep 13 23:31:01 ppp 69826 [wan] IPCP: Close event Sep 13 23:31:01 ppp 69826 [wan] IPV6CP: Close event Sep 13 23:31:01 php-fpm 33476 /rc.linkup: calling interface_dhcpv6_configure. Sep 13 23:31:01 php-fpm 33476 /rc.linkup: Accept router advertisements on interface em0.2 Sep 13 23:31:01 php-fpm 33476 /rc.linkup: Killing running rtsold process Sep 13 23:31:02 ppp 96412 waiting for process 69826 to die... Sep 13 23:31:03 ppp 69826 [wan] Bundle: Shutdown Sep 13 23:31:03 ppp 96412 waiting for process 69826 to die... Sep 13 23:31:03 ppp 69826 [wan_link0] Link: Shutdown Sep 13 23:31:03 ppp 69826 process 69826 terminated Sep 13 23:31:03 php-fpm 33476 /rc.linkup: Starting rtsold process Sep 13 23:31:04 ppp 96412 web: web is not running Sep 13 23:31:04 ppp 96412 [wan] Bundle: Interface ng0 created Sep 13 23:31:04 ppp 96412 [wan_link0] Link: OPEN event Sep 13 23:31:05 kernel ng0: changing name to 'pppoe0' Sep 13 23:31:04 ppp 96412 [wan_link0] LCP: Open event Sep 13 23:31:04 ppp 96412 [wan_link0] LCP: state change Initial --> Starting Sep 13 23:31:04 ppp 96412 [wan_link0] LCP: LayerStart Sep 13 23:31:05 ppp 96412 [wan_link0] PPPoE: Connecting to '' Sep 13 23:31:06 php-fpm 33476 /rc.linkup: Gateway, none 'available' for inet, use the first one configured. 'WAN_PPPOE' Sep 13 23:31:06 php-fpm 33476 /rc.linkup: Gateway, none 'available' for inet6, use the first one configured. 'WAN_DHCP6' Sep 13 23:31:06 check_reload_status 374 Restarting ipsec tunnels Sep 13 23:31:09 check_reload_status 374 updating dyndns wan Sep 13 23:31:09 check_reload_status 374 Reloading filter Sep 13 23:31:09 ppp 21672 Multi-link PPP daemon for FreeBSD Sep 13 23:31:09 ppp 21672 process 21672 started, version 5.9 Sep 13 23:31:09 ppp 21672 waiting for process 96412 to die... Sep 13 23:31:09 ppp 96412 caught fatal signal TERM Sep 13 23:31:09 ppp 96412 [wan] IFACE: Close event Sep 13 23:31:09 ppp 96412 [wan] IPCP: Close event Sep 13 23:31:09 ppp 96412 [wan] IPV6CP: Close event Sep 13 23:31:09 php-fpm 24661 /rc.linkup: calling interface_dhcpv6_configure. Sep 13 23:31:09 php-fpm 24661 /rc.linkup: Accept router advertisements on interface em0.2 Sep 13 23:31:09 php-fpm 24661 /rc.linkup: Killing running rtsold process Sep 13 23:31:10 ppp 21672 waiting for process 96412 to die... Sep 13 23:31:11 ppp 96412 [wan] Bundle: Shutdown Sep 13 23:31:11 ppp 21672 waiting for process 96412 to die... Sep 13 23:31:11 ppp 96412 [wan_link0] Link: Shutdown Sep 13 23:31:11 ppp 96412 process 96412 terminated Sep 13 23:31:11 php-fpm 24661 /rc.linkup: Starting rtsold process Sep 13 23:31:12 ppp 21672 web: web is not running Sep 13 23:31:12 ppp 21672 [wan] Bundle: Interface ng0 created Sep 13 23:31:12 ppp 21672 [wan_link0] Link: OPEN event Sep 13 23:31:12 kernel ng0: changing name to 'pppoe0' Sep 13 23:31:12 ppp 21672 [wan_link0] LCP: Open event Sep 13 23:31:12 ppp 21672 [wan_link0] LCP: state change Initial --> Starting Sep 13 23:31:12 ppp 21672 [wan_link0] LCP: LayerStart Sep 13 23:31:12 ppp 21672 [wan_link0] PPPoE: Connecting to '' Sep 13 23:31:13 php-fpm 24661 /rc.linkup: Gateway, none 'available' for inet, use the first one configured. 'WAN_PPPOE' Sep 13 23:31:13 php-fpm 24661 /rc.linkup: Gateway, none 'available' for inet6, use the first one configured. 'WAN_DHCP6' Sep 13 23:31:13 check_reload_status 374 Restarting ipsec tunnels Sep 13 23:31:17 check_reload_status 374 updating dyndns wan Sep 13 23:31:17 check_reload_status 374 Reloading filter Sep 13 23:31:17 ppp 45971 Multi-link PPP daemon for FreeBSD Sep 13 23:31:17 ppp 45971 process 45971 started, version 5.9 Sep 13 23:31:17 ppp 45971 waiting for process 21672 to die... Sep 13 23:31:17 ppp 21672 caught fatal signal TERM Sep 13 23:31:17 ppp 21672 [wan] IFACE: Close event Sep 13 23:31:17 ppp 21672 [wan] IPCP: Close event Sep 13 23:31:17 ppp 21672 [wan] IPV6CP: Close event Sep 13 23:31:17 php-fpm 27394 /rc.linkup: calling interface_dhcpv6_configure. Sep 13 23:31:17 php-fpm 27394 /rc.linkup: Accept router advertisements on interface em0.2 Sep 13 23:31:17 php-fpm 27394 /rc.linkup: Killing running rtsold process Sep 13 23:31:18 ppp 45971 waiting for process 21672 to die... Sep 13 23:31:19 ppp 21672 [wan] Bundle: Shutdown Sep 13 23:31:19 ppp 45971 waiting for process 21672 to die... Sep 13 23:31:19 ppp 21672 [wan_link0] Link: Shutdown Sep 13 23:31:19 ppp 21672 process 21672 terminated Sep 13 23:31:19 php-fpm 27394 /rc.linkup: Starting rtsold process Sep 13 23:31:20 ppp 45971 web: web is not running Sep 13 23:31:20 ppp 45971 [wan] Bundle: Interface ng0 created Sep 13 23:31:20 ppp 45971 [wan_link0] Link: OPEN event Sep 13 23:31:20 kernel ng0: changing name to 'pppoe0' Sep 13 23:31:20 ppp 45971 [wan_link0] LCP: Open event Sep 13 23:31:20 ppp 45971 [wan_link0] LCP: state change Initial --> Starting Sep 13 23:31:20 ppp 45971 [wan_link0] LCP: LayerStart Sep 13 23:31:20 ppp 45971 [wan_link0] PPPoE: Connecting to '' Sep 13 23:31:21 php-fpm 27394 /rc.linkup: Gateway, none 'available' for inet, use the first one configured. 'WAN_PPPOE' Sep 13 23:31:21 php-fpm 27394 /rc.linkup: Gateway, none 'available' for inet6, use the first one configured. 'WAN_DHCP6' Sep 13 23:31:21 check_reload_status 374 Restarting ipsec tunnels Sep 13 23:31:24 check_reload_status 374 updating dyndns wan Sep 13 23:31:24 check_reload_status 374 Reloading filter Sep 13 23:31:24 ppp 68962 Multi-link PPP daemon for FreeBSD Sep 13 23:31:24 ppp 68962 process 68962 started, version 5.9 Sep 13 23:31:24 ppp 68962 waiting for process 45971 to die... Sep 13 23:31:24 ppp 45971 caught fatal signal TERM Sep 13 23:31:24 ppp 45971 [wan] IFACE: Close event Sep 13 23:31:24 ppp 45971 [wan] IPCP: Close event Sep 13 23:31:24 ppp 45971 [wan] IPV6CP: Close event Sep 13 23:31:24 php-fpm 22306 /rc.linkup: calling interface_dhcpv6_configure. Sep 13 23:31:24 php-fpm 22306 /rc.linkup: Accept router advertisements on interface em0.2 Sep 13 23:31:24 php-fpm 22306 /rc.linkup: Killing running rtsold process Sep 13 23:31:25 ppp 68962 waiting for process 45971 to die... Sep 13 23:31:26 ppp 45971 [wan] Bundle: Shutdown Sep 13 23:31:26 ppp 68962 waiting for process 45971 to die... Sep 13 23:31:26 php-fpm 22306 /rc.linkup: Starting rtsold process Sep 13 23:31:26 ppp 45971 [wan_link0] Link: Shutdown Sep 13 23:31:26 ppp 45971 process 45971 terminated Sep 13 23:31:27 ppp 68962 web: web is not running Sep 13 23:31:27 ppp 68962 [wan] Bundle: Interface ng0 created Sep 13 23:31:27 ppp 68962 [wan_link0] Link: OPEN event Sep 13 23:31:27 kernel ng0: changing name to 'pppoe0' Sep 13 23:31:27 ppp 68962 [wan_link0] LCP: Open event Sep 13 23:31:27 ppp 68962 [wan_link0] LCP: state change Initial --> Starting Sep 13 23:31:27 ppp 68962 [wan_link0] LCP: LayerStart Sep 13 23:31:27 ppp 68962 [wan_link0] PPPoE: Connecting to '' Sep 13 23:31:28 php-fpm 22306 /rc.linkup: Gateway, none 'available' for inet, use the first one configured. 'WAN_PPPOE' Sep 13 23:31:28 php-fpm 22306 /rc.linkup: Gateway, none 'available' for inet6, use the first one configured. 'WAN_DHCP6' Sep 13 23:31:28 check_reload_status 374 Restarting ipsec tunnels Sep 13 23:31:32 check_reload_status 374 updating dyndns wan Sep 13 23:31:32 check_reload_status 374 Reloading filter Sep 13 23:31:32 check_reload_status 374 Reloading filter Sep 13 23:31:32 ppp 13470 Multi-link PPP daemon for FreeBSD Sep 13 23:31:32 ppp 13470 process 13470 started, version 5.9 Sep 13 23:31:32 ppp 13470 waiting for process 68962 to die... Sep 13 23:31:32 ppp 68962 caught fatal signal TERM Sep 13 23:31:32 ppp 68962 [wan] IFACE: Close event Sep 13 23:31:32 ppp 68962 [wan] IPCP: Close event Sep 13 23:31:32 ppp 68962 [wan] IPV6CP: Close event Sep 13 23:31:32 php-fpm 436 /rc.linkup: calling interface_dhcpv6_configure. Sep 13 23:31:32 php-fpm 436 /rc.linkup: Accept router advertisements on interface em0.2 Sep 13 23:31:32 php-fpm 436 /rc.linkup: Killing running rtsold process Sep 13 23:31:33 ppp 13470 waiting for process 68962 to die... Sep 13 23:31:34 ppp 68962 [wan] Bundle: Shutdown Sep 13 23:31:34 ppp 68962 [wan_link0] Link: Shutdown Sep 13 23:31:34 ppp 68962 process 68962 terminated Sep 13 23:31:34 php-fpm 436 /rc.linkup: Starting rtsold process Sep 13 23:31:34 ppp 13470 web: web is not running Sep 13 23:31:34 ppp 13470 [wan] Bundle: Interface ng0 created Sep 13 23:31:34 ppp 13470 [wan_link0] Link: OPEN event Sep 13 23:31:34 kernel ng0: changing name to 'pppoe0' Sep 13 23:31:34 ppp 13470 [wan_link0] LCP: Open event Sep 13 23:31:34 ppp 13470 [wan_link0] LCP: state change Initial --> Starting Sep 13 23:31:34 ppp 13470 [wan_link0] LCP: LayerStart Sep 13 23:31:34 ppp 13470 [wan_link0] PPPoE: Connecting to '' Sep 13 23:31:36 php-fpm 436 /rc.linkup: Gateway, none 'available' for inet, use the first one configured. 'WAN_PPPOE' Sep 13 23:31:36 php-fpm 436 /rc.linkup: Gateway, none 'available' for inet6, use the first one configured. 'WAN_DHCP6' Sep 13 23:31:36 check_reload_status 374 Restarting ipsec tunnels Sep 13 23:31:39 check_reload_status 374 updating dyndns wan Sep 13 23:31:39 check_reload_status 374 Reloading filter Sep 13 23:31:39 check_reload_status 374 Reloading filter Sep 13 23:31:39 ppp 58995 Multi-link PPP daemon for FreeBSD Sep 13 23:31:39 ppp 58995 process 58995 started, version 5.9 Sep 13 23:31:39 ppp 58995 waiting for process 13470 to die... Sep 13 23:31:39 ppp 13470 caught fatal signal TERM Sep 13 23:31:39 ppp 13470 [wan] IFACE: Close event Sep 13 23:31:39 ppp 13470 [wan] IPCP: Close event Sep 13 23:31:39 ppp 13470 [wan] IPV6CP: Close event Sep 13 23:31:39 php-fpm 42735 /rc.linkup: calling interface_dhcpv6_configure. Sep 13 23:31:39 php-fpm 42735 /rc.linkup: Accept router advertisements on interface em0.2 Sep 13 23:31:39 php-fpm 42735 /rc.linkup: Killing running rtsold process Sep 13 23:31:40 ppp 58995 waiting for process 13470 to die... Sep 13 23:31:41 ppp 13470 [wan] Bundle: Shutdown Sep 13 23:31:41 ppp 58995 waiting for process 13470 to die... Sep 13 23:31:41 ppp 13470 [wan_link0] Link: Shutdown Sep 13 23:31:41 ppp 13470 process 13470 terminated Sep 13 23:31:41 php-fpm 42735 /rc.linkup: Starting rtsold process Sep 13 23:31:42 ppp 58995 web: web is not running Sep 13 23:31:42 ppp 58995 [wan] Bundle: Interface ng0 created Sep 13 23:31:42 ppp 58995 [wan_link0] Link: OPEN event Sep 13 23:31:42 kernel ng0: changing name to 'pppoe0' Sep 13 23:31:42 ppp 58995 [wan_link0] LCP: Open event Sep 13 23:31:42 ppp 58995 [wan_link0] LCP: state change Initial --> Starting Sep 13 23:31:42 ppp 58995 [wan_link0] LCP: LayerStart Sep 13 23:31:42 ppp 58995 [wan_link0] PPPoE: Connecting to '' Sep 13 23:31:43 php-fpm 42735 /rc.linkup: Gateway, none 'available' for inet, use the first one configured. 'WAN_PPPOE' Sep 13 23:31:43 php-fpm 42735 /rc.linkup: Gateway, none 'available' for inet6, use the first one configured. 'WAN_DHCP6' Sep 13 23:31:43 check_reload_status 374 Restarting ipsec tunnels Sep 13 23:31:47 check_reload_status 374 updating dyndns wan Sep 13 23:31:47 check_reload_status 374 Reloading filter Sep 13 23:31:47 check_reload_status 374 Reloading filter Sep 13 23:31:47 ppp 3455 Multi-link PPP daemon for FreeBSD Sep 13 23:31:47 ppp 3455 process 3455 started, version 5.9 Sep 13 23:31:47 ppp 3455 waiting for process 58995 to die... Sep 13 23:31:47 ppp 58995 caught fatal signal TERM Sep 13 23:31:47 ppp 58995 [wan] IFACE: Close event Sep 13 23:31:47 ppp 58995 [wan] IPCP: Close event Sep 13 23:31:47 ppp 58995 [wan] IPV6CP: Close event Sep 13 23:31:47 php-fpm 75400 /rc.linkup: calling interface_dhcpv6_configure. Sep 13 23:31:47 php-fpm 75400 /rc.linkup: Accept router advertisements on interface em0.2 Sep 13 23:31:47 php-fpm 75400 /rc.linkup: Killing running rtsold process Sep 13 23:31:48 ppp 3455 waiting for process 58995 to die... Sep 13 23:31:49 ppp 58995 [wan] Bundle: Shutdown Sep 13 23:31:49 ppp 3455 waiting for process 58995 to die... Sep 13 23:31:49 php-fpm 75400 /rc.linkup: Starting rtsold process Sep 13 23:31:49 ppp 58995 [wan_link0] Link: Shutdown Sep 13 23:31:49 ppp 58995 process 58995 terminated Sep 13 23:31:50 ppp 3455 web: web is not running Sep 13 23:31:50 ppp 3455 [wan] Bundle: Interface ng0 created Sep 13 23:31:50 ppp 3455 [wan_link0] Link: OPEN event Sep 13 23:31:50 kernel ng0: changing name to 'pppoe0' Sep 13 23:31:50 ppp 3455 [wan_link0] LCP: Open event Sep 13 23:31:50 ppp 3455 [wan_link0] LCP: state change Initial --> Starting Sep 13 23:31:50 ppp 3455 [wan_link0] LCP: LayerStart Sep 13 23:31:50 ppp 3455 [wan_link0] PPPoE: Connecting to '' Sep 13 23:31:51 php-fpm 75400 /rc.linkup: Gateway, none 'available' for inet, use the first one configured. 'WAN_PPPOE' Sep 13 23:31:51 php-fpm 75400 /rc.linkup: Gateway, none 'available' for inet6, use the first one configured. 'WAN_DHCP6' Sep 13 23:31:51 check_reload_status 374 Restarting ipsec tunnels Sep 13 23:31:54 check_reload_status 374 updating dyndns wan Sep 13 23:31:54 check_reload_status 374 Reloading filter Sep 13 23:31:59 ppp 3455 [wan_link0] PPPoE connection timeout after 9 seconds Sep 13 23:31:59 ppp 3455 [wan_link0] Link: DOWN event Sep 13 23:31:59 ppp 3455 [wan_link0] LCP: Down event Sep 13 23:31:59 ppp 3455 [wan_link0] Link: reconnection attempt 1 in 2 seconds Sep 13 23:32:01 ppp 3455 [wan_link0] Link: reconnection attempt 1 Sep 13 23:32:01 ppp 3455 [wan_link0] PPPoE: Connecting to '' Sep 13 23:32:10 ppp 3455 [wan_link0] PPPoE connection timeout after 9 seconds Sep 13 23:32:10 ppp 3455 [wan_link0] Link: DOWN event Sep 13 23:32:10 ppp 3455 [wan_link0] LCP: Down event Sep 13 23:32:10 ppp 3455 [wan_link0] Link: reconnection attempt 2 in 3 seconds Sep 13 23:32:13 ppp 3455 [wan_link0] Link: reconnection attempt 2 Sep 13 23:32:13 ppp 3455 [wan_link0] PPPoE: Connecting to '' Sep 13 23:32:22 ppp 3455 [wan_link0] PPPoE connection timeout after 9 seconds Sep 13 23:32:22 ppp 3455 [wan_link0] Link: DOWN event Sep 13 23:32:22 ppp 3455 [wan_link0] LCP: Down event Sep 13 23:32:22 ppp 3455 [wan_link0] Link: reconnection attempt 3 in 2 seconds Sep 13 23:32:24 ppp 3455 [wan_link0] Link: reconnection attempt 3 Sep 13 23:32:24 ppp 3455 [wan_link0] PPPoE: Connecting to '' Sep 13 23:32:33 ppp 3455 [wan_link0] PPPoE connection timeout after 9 seconds Sep 13 23:32:33 ppp 3455 [wan_link0] Link: DOWN event Sep 13 23:32:33 ppp 3455 [wan_link0] LCP: Down event Sep 13 23:32:33 ppp 3455 [wan_link0] Link: reconnection attempt 4 in 4 seconds Sep 13 23:32:37 ppp 3455 [wan_link0] Link: reconnection attempt 4 Sep 13 23:32:37 ppp 3455 [wan_link0] PPPoE: Connecting to '' Sep 13 23:32:37 ppp 3455 PPPoE: rec'd ACNAME "bri-apt-wic-bras208" Sep 13 23:32:37 ppp 3455 [wan_link0] PPPoE: connection successful Sep 13 23:32:37 ppp 3455 [wan_link0] Link: UP event Sep 13 23:32:37 ppp 3455 [wan_link0] LCP: Up event Sep 13 23:32:37 ppp 3455 [wan_link0] LCP: state change Starting --> Req-Sent Sep 13 23:32:37 ppp 3455 [wan_link0] LCP: SendConfigReq #1 Sep 13 23:32:37 ppp 3455 [wan_link0] PROTOCOMP Sep 13 23:32:37 ppp 3455 [wan_link0] MRU 1492 Sep 13 23:32:37 ppp 3455 [wan_link0] MAGICNUM 0xb91304ee Sep 13 23:32:37 ppp 3455 [wan_link0] LCP: rec'd Configure Request #1 (Req-Sent) Sep 13 23:32:37 ppp 3455 [wan_link0] MRU 1492 Sep 13 23:32:37 ppp 3455 [wan_link0] AUTHPROTO PAP Sep 13 23:32:37 ppp 3455 [wan_link0] MAGICNUM 0x02e3e245 Sep 13 23:32:37 ppp 3455 [wan_link0] LCP: SendConfigAck #1 Sep 13 23:32:37 ppp 3455 [wan_link0] MRU 1492 Sep 13 23:32:37 ppp 3455 [wan_link0] AUTHPROTO PAP Sep 13 23:32:37 ppp 3455 [wan_link0] MAGICNUM 0x02e3e245 Sep 13 23:32:37 ppp 3455 [wan_link0] LCP: state change Req-Sent --> Ack-Sent Sep 13 23:32:37 ppp 3455 [wan_link0] LCP: rec'd Configure Ack #1 (Ack-Sent) Sep 13 23:32:37 ppp 3455 [wan_link0] PROTOCOMP Sep 13 23:32:37 ppp 3455 [wan_link0] MRU 1492 Sep 13 23:32:37 ppp 3455 [wan_link0] MAGICNUM 0xb91304ee Sep 13 23:32:37 ppp 3455 [wan_link0] LCP: state change Ack-Sent --> Opened Sep 13 23:32:37 ppp 3455 [wan_link0] LCP: auth: peer wants PAP, I want nothing Sep 13 23:32:37 ppp 3455 [wan_link0] PAP: using authname "davidjcartledge" Sep 13 23:32:37 ppp 3455 [wan_link0] PAP: sending REQUEST #1 len: 29 Sep 13 23:32:37 ppp 3455 [wan_link0] LCP: LayerUp Sep 13 23:32:39 ppp 3455 [wan_link0] PAP: using authname "davidjcartledge" Sep 13 23:32:39 ppp 3455 [wan_link0] PAP: sending REQUEST #2 len: 29 Sep 13 23:32:41 ppp 3455 [wan_link0] PAP: using authname "davidjcartledge" Sep 13 23:32:41 ppp 3455 [wan_link0] PAP: sending REQUEST #3 len: 29 Sep 13 23:32:41 ppp 3455 [wan_link0] rec'd proto IPCP during authenticate phase Sep 13 23:32:43 ppp 3455 [wan_link0] PAP: using authname "davidjcartledge" Sep 13 23:32:43 ppp 3455 [wan_link0] PAP: sending REQUEST #4 len: 29 Sep 13 23:32:45 ppp 3455 [wan_link0] PAP: using authname "davidjcartledge" Sep 13 23:32:45 ppp 3455 [wan_link0] PAP: sending REQUEST #5 len: 29 Sep 13 23:33:17 ppp 3455 [wan_link0] LCP: authorization timer expired Sep 13 23:33:17 ppp 3455 [wan_link0] LCP: authorization failed Sep 13 23:33:17 ppp 3455 [wan_link0] LCP: parameter negotiation failed Sep 13 23:33:17 ppp 3455 [wan_link0] LCP: state change Opened --> Stopping Sep 13 23:33:17 ppp 3455 [wan_link0] LCP: SendTerminateReq #2 Sep 13 23:33:17 ppp 3455 [wan_link0] LCP: LayerDown Sep 13 23:33:19 ppp 3455 [wan_link0] LCP: SendTerminateReq #3 Sep 13 23:33:21 ppp 3455 [wan_link0] LCP: state change Stopping --> Stopped Sep 13 23:33:21 ppp 3455 [wan_link0] LCP: LayerFinish Sep 13 23:33:21 ppp 3455 [wan_link0] PPPoE: connection closed Sep 13 23:33:21 ppp 3455 [wan_link0] Link: DOWN event Sep 13 23:33:21 ppp 3455 [wan_link0] LCP: Down event Sep 13 23:33:21 ppp 3455 [wan_link0] LCP: state change Stopped --> Starting Sep 13 23:33:21 ppp 3455 [wan_link0] LCP: LayerStart Sep 13 23:33:21 ppp 3455 [wan_link0] Link: reconnection attempt 5 in 4 seconds Sep 13 23:33:25 ppp 3455 [wan_link0] Link: reconnection attempt 5 Sep 13 23:33:25 ppp 3455 [wan_link0] PPPoE: Connecting to '' Sep 13 23:33:34 ppp 3455 [wan_link0] PPPoE connection timeout after 9 seconds Sep 13 23:33:34 ppp 3455 [wan_link0] Link: DOWN event Sep 13 23:33:34 ppp 3455 [wan_link0] LCP: Down event Sep 13 23:33:34 ppp 3455 [wan_link0] Link: reconnection attempt 6 in 3 seconds Sep 13 23:33:37 ppp 3455 [wan_link0] Link: reconnection attempt 6 Sep 13 23:33:37 ppp 3455 [wan_link0] PPPoE: Connecting to '' Sep 13 23:33:46 ppp 3455 [wan_link0] PPPoE connection timeout after 9 seconds Sep 13 23:33:46 ppp 3455 [wan_link0] Link: DOWN event Sep 13 23:33:46 ppp 3455 [wan_link0] LCP: Down event Sep 13 23:33:46 ppp 3455 [wan_link0] Link: reconnection attempt 7 in 2 seconds Sep 13 23:33:48 ppp 3455 [wan_link0] Link: reconnection attempt 7 Sep 13 23:33:48 ppp 3455 [wan_link0] PPPoE: Connecting to '' Sep 13 23:33:57 ppp 3455 [wan_link0] PPPoE connection timeout after 9 seconds Sep 13 23:33:57 ppp 3455 [wan_link0] Link: DOWN event Sep 13 23:33:57 ppp 3455 [wan_link0] LCP: Down event Sep 13 23:33:57 ppp 3455 [wan_link0] Link: reconnection attempt 8 in 3 seconds Sep 13 23:34:00 ppp 3455 [wan_link0] Link: reconnection attempt 8 Sep 13 23:34:00 ppp 3455 [wan_link0] PPPoE: Connecting to '' Sep 13 23:34:09 ppp 3455 [wan_link0] PPPoE connection timeout after 9 seconds Sep 13 23:34:09 ppp 3455 [wan_link0] Link: DOWN event Sep 13 23:34:09 ppp 3455 [wan_link0] LCP: Down event Sep 13 23:34:09 ppp 3455 [wan_link0] Link: reconnection attempt 9 in 1 seconds Sep 13 23:34:10 ppp 3455 [wan_link0] Link: reconnection attempt 9 Sep 13 23:34:10 ppp 3455 [wan_link0] PPPoE: Connecting to '' Sep 13 23:34:19 ppp 3455 [wan_link0] PPPoE connection timeout after 9 seconds Sep 13 23:34:19 ppp 3455 [wan_link0] Link: DOWN event Sep 13 23:34:19 ppp 3455 [wan_link0] LCP: Down event Sep 13 23:34:19 ppp 3455 [wan_link0] Link: reconnection attempt 10 in 2 seconds Sep 13 23:34:21 ppp 3455 [wan_link0] Link: reconnection attempt 10 Sep 13 23:34:21 ppp 3455 [wan_link0] PPPoE: Connecting to '' Sep 13 23:34:30 ppp 3455 [wan_link0] PPPoE connection timeout after 9 seconds Sep 13 23:34:30 ppp 3455 [wan_link0] Link: DOWN event Sep 13 23:34:30 ppp 3455 [wan_link0] LCP: Down event Sep 13 23:34:30 ppp 3455 [wan_link0] Link: reconnection attempt 11 in 1 seconds Sep 13 23:34:31 ppp 3455 [wan_link0] Link: reconnection attempt 11 Sep 13 23:34:31 ppp 3455 [wan_link0] PPPoE: Connecting to '' Sep 13 23:34:37 ppp 3455 PPPoE: rec'd ACNAME "bri-apt-wic-bras205" Sep 13 23:34:37 ppp 3455 [wan_link0] PPPoE: connection successful Sep 13 23:34:37 ppp 3455 [wan_link0] Link: UP event Sep 13 23:34:37 ppp 3455 [wan_link0] LCP: Up event Sep 13 23:34:37 ppp 3455 [wan_link0] LCP: state change Starting --> Req-Sent Sep 13 23:34:37 ppp 3455 [wan_link0] LCP: SendConfigReq #4 Sep 13 23:34:37 ppp 3455 [wan_link0] PROTOCOMP Sep 13 23:34:37 ppp 3455 [wan_link0] MRU 1492 Sep 13 23:34:37 ppp 3455 [wan_link0] MAGICNUM 0xa943c5d0 Sep 13 23:34:39 ppp 3455 [wan_link0] LCP: SendConfigReq #5 Sep 13 23:34:39 ppp 3455 [wan_link0] PROTOCOMP Sep 13 23:34:39 ppp 3455 [wan_link0] MRU 1492 Sep 13 23:34:39 ppp 3455 [wan_link0] MAGICNUM 0xa943c5d0 Sep 13 23:34:41 ppp 3455 [wan_link0] LCP: SendConfigReq #6 Sep 13 23:34:41 ppp 3455 [wan_link0] PROTOCOMP Sep 13 23:34:41 ppp 3455 [wan_link0] MRU 1492 Sep 13 23:34:41 ppp 3455 [wan_link0] MAGICNUM 0xa943c5d0 Sep 13 23:34:43 ppp 3455 [wan_link0] LCP: SendConfigReq #7 Sep 13 23:34:43 ppp 3455 [wan_link0] PROTOCOMP Sep 13 23:34:43 ppp 3455 [wan_link0] MRU 1492 Sep 13 23:34:43 ppp 3455 [wan_link0] MAGICNUM 0xa943c5d0 Sep 13 23:34:45 ppp 3455 [wan_link0] LCP: SendConfigReq #8 Sep 13 23:34:45 ppp 3455 [wan_link0] PROTOCOMP Sep 13 23:34:45 ppp 3455 [wan_link0] MRU 1492 Sep 13 23:34:45 ppp 3455 [wan_link0] MAGICNUM 0xa943c5d0 Sep 13 23:34:45 ppp 3455 [wan_link0] LCP: rec'd Configure Request #5 (Req-Sent) Sep 13 23:34:45 ppp 3455 [wan_link0] MRU 1492 Sep 13 23:34:45 ppp 3455 [wan_link0] AUTHPROTO PAP Sep 13 23:34:45 ppp 3455 [wan_link0] MAGICNUM 0x6f91857f Sep 13 23:34:45 ppp 3455 [wan_link0] LCP: SendConfigAck #5 Sep 13 23:34:45 ppp 3455 [wan_link0] MRU 1492 Sep 13 23:34:45 ppp 3455 [wan_link0] AUTHPROTO PAP Sep 13 23:34:45 ppp 3455 [wan_link0] MAGICNUM 0x6f91857f Sep 13 23:34:45 ppp 3455 [wan_link0] LCP: state change Req-Sent --> Ack-Sent Sep 13 23:34:47 ppp 3455 [wan_link0] LCP: SendConfigReq #9 Sep 13 23:34:47 ppp 3455 [wan_link0] PROTOCOMP Sep 13 23:34:47 ppp 3455 [wan_link0] MRU 1492 Sep 13 23:34:47 ppp 3455 [wan_link0] MAGICNUM 0xa943c5d0 Sep 13 23:34:49 ppp 3455 [wan_link0] LCP: SendConfigReq #10 Sep 13 23:34:49 ppp 3455 [wan_link0] PROTOCOMP Sep 13 23:34:49 ppp 3455 [wan_link0] MRU 1492 Sep 13 23:34:49 ppp 3455 [wan_link0] MAGICNUM 0xa943c5d0 Sep 13 23:34:51 ppp 3455 [wan_link0] LCP: SendConfigReq #11 Sep 13 23:34:51 ppp 3455 [wan_link0] PROTOCOMP Sep 13 23:34:51 ppp 3455 [wan_link0] MRU 1492 Sep 13 23:34:51 ppp 3455 [wan_link0] MAGICNUM 0xa943c5d0 Sep 13 23:34:53 ppp 3455 [wan_link0] LCP: SendConfigReq #12 Sep 13 23:34:53 ppp 3455 [wan_link0] PROTOCOMP Sep 13 23:34:53 ppp 3455 [wan_link0] MRU 1492 Sep 13 23:34:53 ppp 3455 [wan_link0] MAGICNUM 0xa943c5d0 Sep 13 23:34:55 ppp 3455 [wan_link0] LCP: SendConfigReq #13 Sep 13 23:34:55 ppp 3455 [wan_link0] PROTOCOMP Sep 13 23:34:55 ppp 3455 [wan_link0] MRU 1492 Sep 13 23:34:55 ppp 3455 [wan_link0] MAGICNUM 0xa943c5d0 Sep 13 23:34:57 ppp 3455 [wan_link0] LCP: parameter negotiation failed Sep 13 23:34:57 ppp 3455 [wan_link0] LCP: state change Ack-Sent --> Stopped Sep 13 23:34:57 ppp 3455 [wan_link0] LCP: LayerFinish Sep 13 23:34:57 ppp 3455 [wan_link0] PPPoE: connection closed Sep 13 23:34:57 ppp 3455 [wan_link0] Link: DOWN event Sep 13 23:34:57 ppp 3455 [wan_link0] LCP: Down event Sep 13 23:34:57 ppp 3455 [wan_link0] LCP: state change Stopped --> Starting Sep 13 23:34:57 ppp 3455 [wan_link0] LCP: LayerStart Sep 13 23:34:57 ppp 3455 [wan_link0] Link: reconnection attempt 12 in 4 seconds Sep 13 23:35:01 ppp 3455 [wan_link0] Link: reconnection attempt 12 Sep 13 23:35:01 ppp 3455 [wan_link0] PPPoE: Connecting to '' Sep 13 23:35:07 ppp 3455 PPPoE: rec'd ACNAME "bri-apt-wic-bras205" Sep 13 23:35:10 ppp 3455 [wan_link0] PPPoE connection timeout after 9 seconds Sep 13 23:35:10 ppp 3455 [wan_link0] Link: DOWN event Sep 13 23:35:10 ppp 3455 [wan_link0] LCP: Down event Sep 13 23:35:10 ppp 3455 [wan_link0] Link: reconnection attempt 13 in 1 seconds Sep 13 23:35:11 ppp 3455 [wan_link0] Link: reconnection attempt 13 Sep 13 23:35:11 ppp 3455 [wan_link0] PPPoE: Connecting to '' -
@gerryatric said in PPPOE wan will not connect -:
Sep 13 23:34:57 ppp 3455 [wan_link0] LCP: parameter negotiation failedIs there a "special" Parameter that your ISP wants?
Just guessing ... -
@fireodo Sorry Fireodo
No special parameter at all apart from Vlan ID
This just makes no sense as it works on all my other routers.
/just not Pfsense -
It connects to the ISP Broadband Remote Access Server (BRAS)
... but cannot establish a connection ... WHY?
Hmmmmm ...
Something IPv6 causing a delay that time's out something else?
Your WAN is still set for DHCPv6 which normally rides over the PPPoE once it's connected and isn't an issue but.....
Check the ppp logs in the ER or any other router that does connect. Make sure there isn't something fundamentally different happening. Like the wrong auth type maybe.
Don't you need to provide your full username (username@iinet.net.au) for PPPoE?
I only see the left-hand side "davidj*********" in the log.
@biggsy
No. the difference between IINET NBN and IINET fibre. you do need full username for NBN VDSL but not for NBN fibre.
IINET is owned by TPG -
The fibre is owned by NBN too. Should be no difference.
https://help.iinet.net.au/o/iinet-broadband-settings-list#NBNFTTP
Give it a try.
@biggsy
I did that already. it doesn't work. I had this discussion with tech support and their advice when it wasn't connecting on the USG was to remove the rest of the address. since then it has been good.
I tried the full address on PFSENSE and it doesn't work
This is not a username or password issue. I have been through all this way at the top of this forum subject a few times.
The issue seems to be that PFSENSE needs to send something that the USG does automatically.
hence the failure
Or the PFSENSe is sending something that the IINET Fibre doesn't want.
I can't see that clearly in the logs. -
@gerryatric ok I have installed a Syslog server to monitor PFSENSE. It is showing different messaging compared to the inbuilt log viewer.
might help.
see attached syslog pfsense.txt -
Strange that all the PPP stuff is doubled-up in the syslog.
Could you post up screenshots of your current:
Interfaces > WAN
Interfaces > Assignments > WAN
Interfaces > Assignments > VLANs
Interfaces > Assignments > PPPs -
Sorry, copy/paste mistake. Not "Interfaces > Assignments > WAN"
The "Interfaces > Assignments" screen.
Was that Service Name an experiment? Shouldn't be needed.
@gerryatric
It keeps blocking my uploads. Akismet spam warning
Yeah, I was getting that Akismet warning while trying to paste the iiNet link before.
Was the Service Name under PPP config part of an experiment? Shouldn't be needed.
Apart from that I can't see anything that looks odd in your config. Maybe a clean install is needed to clear out something that's been left hanging around from earlier attempts.
@biggsy Hi. yeh I did know that. At this stage I was trying everything.
A clean install was done yesterday. sadly nothing changed.
I think this might beat me
