    No connection with PPPoE and VLan connection
    25 Posts 2 Posters 3.2k Views 2 Watching
      Airone 0
      Solved MAC spoofing problem. I've printed you a picture of my dashboard in case you see anything strange. I'm about to give up, I don't know what to do anymore.
        So how it that connected right now?
        What's working or not working?
        The gateway passed by PPPoE may not respond to ping so you might want to set an external monitoring IP like 8.8.8.8.
        https://docs.netgate.com/pfsense/en/latest/routing/gateway-configure.html#advanced-gateway-settings
          Airone 0
          Hello @stephenw10 ,
          now the 4100 is connected to the ISP's modem/Ont again, that's the only way it works even though I have limited upload speed. I also saw that there are problems with the gateway, but I can't figure out where to make changes to fix it.
          However, everything seems to work without problems, I don't see where the above problem could affect.
            stephenw10 Netgate Administrator @Airone 0
            Set a different monitor IP in System > Routing > Gateways > Edit the WAN_PPPoE gateway.
              Airone 0
              Already done, thanks. But now I will try to unlock the Modem/ONT in order to read its settings or I will look for a compatible SFP module to use the same 4100 as ONT. I don't see other possibilities. If you have any other ideas, welcome.
              Thanks anyway for the assistance you have provided me.
