    Resolving Red Screen Issue on pfSense Firewall When Accessing Integrated Management System (IMS)"
    14 Posts 4 Posters 1.5k Views 3 Watching
    • V Offline
      velbon
      Dear All,
      How can I resolve the issue of a pfSense firewall displaying a red screen when attempting to access the Integrated Management System (IMS)?
      Regards,
      Gerald
        johnpoz LAYER 8 Global Moderator @velbon
        @velbon and what does the red screen say, something about a rebind?
        • V Offline
          velbon
          Re: Resolving Red Screen Issue on pfSense Firewall When Accessing Integrated Management System (IMS)". It is showing Contact Integrated Management System
          • V Offline
            velbon @johnpoz
            @johnpoz Please contact the integrated management log for more details
              Gertjan @velbon
              @velbon said in Resolving Red Screen Issue on pfSense Firewall When Accessing Integrated Management System (IMS)":
              Can we see an image ?
              I'm not sure, but something tells me that this text "Contact Integrated Management System" doesn't exist on pfSense.
                @velbon I am not aware of any IMS part of pfsense.
                • V Offline
                  velbon @johnpoz
                  @johnpoz It is said! NMI detected!! Please contact the integrated management log for more details
                  ![IMG_8211.HEIC](Input file contains unsupported image format)
                  • V Offline
                    velbon @velbon
                      @velbon oh that is something to do with the PC.. Is it a DL380? The red screen of death most likely related to some hardware issue..
                      NMI = Non-maskable Interrupt
                      • V Offline
                        velbon @johnpoz
                        @johnpoz We did some cleaning of the server and then try to boot again but I am not now having this issue:
                        johnpozJ R 2 Replies Last reply Reply Quote 0
                          @velbon if me I would just do a clean install on that - did it ever boot pfsense? What version of pfsense?
                            rcoleman-netgate Netgate @velbon
                            @velbon As we noted for you elsewhere this is a hardware issue, not a pfSense software issue.
                            Ryan
                            Wireless: Aruba, Ubiquiti
                            • R rcoleman-netgate moved this topic from General pfSense Questions on
                            • V Offline
                              velbon @rcoleman-netgate
                              @rcoleman-netgate I had to replace the hard drive and perform a fresh OS installation. I can't help but wish I had a backup of the data from the previous drive before discarding it.
                                @velbon the only thing needed from pfsense is the config xml file.. Its very very small - do you not have a copy online with the pfsense ACB..
                                https://docs.netgate.com/pfsense/en/latest/backup/autoconfigbackup.html
                                You should prob set that up going forward.
