    2100 LED question
    30 Posts 5 Posters 2.8k Views 4 Watching
    • JonathanLeeJ Offline
      JonathanLee
      Something maybe like this
      #!/bin/sh
      pfctl -vvss | grep ', rule 79' >/dev/null
      res=$?
      if [ $res = 0 ]; then
        sysctl -q dev.gpio.2.led.2.pwm=1
        gpioctl -f /dev/gpioc2 6 duty 1 >/dev/null
      fi
      Or...
      #!/bin/sh
      str="$(pfctl -vvss | grep ', rule 79')"
      if [ -z "$str" ]; then
      fi
      Ref Researching:
      https://forums.freebsd.org/threads/bin-sh-how-to-save-a-shell-command-output-into-a-string-variable.90088/
      Make sure to upvote
      • stephenw10S Online
        The problem there is that the rule number an change if you add or remove rules. I was hoping you might be able to see tags on rules in the states but I don't see a way to do that. Yet...
        JonathanLeeJ 2 Replies Last reply Reply Quote 1
          JonathanLee @stephenw10
          @stephenw10 It works if you don't adjust the rules I have it going now.
          Make sure to upvote
            JonathanLee
            /root/deviceonlinenight
            #!/bin/sh
            res=$?
            if [ $res = 0 ];
            then
              sysctl -q dev.gpio.2.led.0.pwm=1
              gpioctl -f /dev/gpioc2 0 duty 200 >/dev/null
              sysctl -q dev.gpio.2.led.1.pwm=1
              gpioctl -f /dev/gpioc2 3 duty 200 >/dev/null
              gpioctl -f /dev/gpioc2 6 duty 200 >/dev/null
            else
              gpioctl -f /dev/gpioc2 0 duty 0 >/dev/null
              gpioctl -f /dev/gpioc2 1 duty 0 >/dev/null
              gpioctl -f /dev/gpioc2 2 duty 0 >/dev/null
              gpioctl -f /dev/gpioc2 3 duty 0 >/dev/null
              gpioctl -f /dev/gpioc2 4 duty 0 >/dev/null
              gpioctl -f /dev/gpioc2 5 duty 0 >/dev/null
              gpioctl -f /dev/gpioc2 6 duty 0 >/dev/null
              gpioctl -f /dev/gpioc2 7 duty 0 >/dev/null
              gpioctl -f /dev/gpioc2 8 duty 0 >/dev/null
            fi
            /root/deviceonlineday
            #!/bin/sh
            res=$?
            if [ $res = 0 ];
            then
              gpioctl -f /dev/gpioc2 3 duty 100 >/dev/null
              gpioctl -f /dev/gpioc2 6 duty 100 >/dev/null
            else
              gpioctl -f /dev/gpioc2 7 duty 100 >/dev/null
            fi
            Make sure to upvote
              pfctl -vvss| grep '192.168.1.11' would work great too as it would be IP address based not rule based
              also
              pfctl -vvss| grep -e 192.168.1.18 -e 192.168.1.11
              Make sure to upvote
                Nice!
                  JonathanLee
                  Kind of amazing looking when testing the deviceonlinenight.sh
                  It looks like the CM-5
                  The 90s Connection Machine
                  Make sure to upvote
                    JonathanLee
                    #!/bin/sh
                    res=$?
                    if [ $res = 0 ];
                    then
                      gpioctl -f /dev/gpioc2 8 duty 100 >/dev/null
                    else
                      gpioctl -f /dev/gpioc2 7 duty 7 >/dev/null
                    fi
                    This will have purple and red :)
                    Make sure to upvote
                      JonathanLee
                      Another way to do this now you can run the pfctl command once and use the case command to iterate over the variable I named state
                      #!/bin/sh
                      state=$( pfctl -vvss )
                      res=1
                      resb=1
                      case "$state" in
                        *, rule 79*)
                          res=0
                      esac
                      case "$state" in
                        *192.168.1.11*)
                          resb=0
                      esac
                      if [ $res = 0 ] && [ $resb = 0 ];
                      then
                        gpioctl -f /dev/gpioc2 3 duty 50 >/dev/null
                        gpioctl -f /dev/gpioc2 6 duty 50 >/dev/null
                      elif [ $res = 0 ];
                      then
                      elif [ $resb = 0 ];
                      then
                      else
                        gpioctl -f /dev/gpioc2 7 duty 50 >/dev/null
                      fi
                      Make sure to upvote
                        JonathanLee
                        Here is a version with 3 conditional LED adaptions.
                        #!/bin/sh
                        check_current_states=$( pfctl -vvss | grep -e ', rule 84' -e '192.168.1.11' -e '192.168.1.15' )
                        res=1
                        resb=1
                        resc=1
                        case "$check_current_states" in
                          *", rule 79"* ) res=0 ;;
                        esac
                          *192.168.1.11* ) resb=0 ;;
                        esac
                          *192.168.1.15* ) resc=0 ;;
                        esac
                        then
                        elif [ $res = 0 ];
                        then
                        elif [ $resb = 0 ];
                        then
                        else
                        fi
                        if [ $resc = 0 ];
                        then
                          gpioctl -f /dev/gpioc2 2 duty 50 >/dev/null
                        else
                        fi
                        Make sure to upvote
