    Varnish help on setting up for multiple internal webservers
    66 Posts 10 Posters 31.4k Views
    • marcellocM Offline
      marcelloc
      can you try to access backend test url?
      http://10.0.0.50/index.php
      Also, what you get on dashboard varnish widget?
      • L Offline
        Landmine
        The URL works get when I'm at home and here is a pic of what the widget looks like.
        Thank you for taking the time to help me.
          marcelloc
          Varnish could not get this url from your web server.
          Can you try an static html, a full http request or something else?
          • L Offline
            Landmine
            So far so good. Now if I wanted to add more servers to the list, I'd basically copy the settings and just change the Backend name, IP and Mapping?
              marcelloc
              Yes.  :)
              Just don't forget to check backend status on Dashboard.
                normtodd
                im having a strange issue that im sure is something easy that im not doing - im pretty sure everthing is working vis a vis varnish, but i am not getting any data on the varnish widget except that the backend is up and running - everything else (cache hits, cache hits pass, cache missed, conn accepted, req. received, and uptime) are empty.  ive attached a picture of the widget from the dashboard to illustrate.
                right now i only have one machine (an atmail mail server) behind pfsense/varnish and want to confirm that everything is working before i deploy more machines behind pfsense.
                here is my varnish config -
                # Varnish configuration file
                # Automatically generated by the pfSense package system
                # This file is located in /var/etc/default.vcl
                sub vcl_error {
                		if (obj.status == 503 && req.restarts < 1) {
                			return(restart);
                	set obj.http.Content-Type = "text/html; charset=utf-8";
                	synthetic {"
                "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
                <title>"} + obj.status + " " + obj.response + {"</title>
                # Error "} + obj.status + " " + obj.response + {"
                "} + obj.response + {"
                ### Guru Meditation:
                XID: "} + req.xid + {"
                Varnish cache server
                138	"};
                	return(deliver);
                backend atmailBACKEND {
                	# used in catch_all
                	.host = "192.168.20.5";
                	.port = "80";
                	.first_byte_timeout = 300s;
                	.connect_timeout = 25s;
                	.probe = {
                		.url = "/";
                		.interval = 5s;
                		.timeout = 1s;
                		.window = 5;
                		.threshold = 3;
                sub vcl_recv {
                	#BASIC VCL RULES SETTING
                	#Fix gzip compression
                	if (req.http.Accept-Encoding) {
                	if (req.url ~ "\.(gif|jpg|jpeg|bmp|png|ico|img|tga|wmf|gz|tgz|bz2|tbz|mp3|ogg)$") {
                		unset req.http.Accept-Encoding;
                	else if (req.http.Accept-Encoding ~ "gzip") {
                		set req.http.Accept-Encoding = "gzip";
                	else if (req.http.Accept-Encoding ~ "deflate") {
                		set req.http.Accept-Encoding = "deflate";
                	else	{
                	#set client balance identity
                	set client.identity = client.ip;
                	#set X-forward
                	set req.http.X-Forwarded-Varnish = client.ip;
                	if (req.http.host == "www.coldhardmath.com") {
                		set req.backend = atmailBACKEND;
                	#respect client wish to refresh the page
                	if (req.http.Pragma ~ "no-cache")
                		return(pass);
                	#BASIC VCL RULES ACTIONS
                	#Disable post cache
                	if (req.request == "POST") {
                		return(pass);
                	#Disable session cache
                	if (req.http.Cookie && req.http.Cookie ~ "(PHPSESSID|phpsessid)") {
                		return(pass);
                	if (req.http.Cookie && req.http.Cookie ~ "(JSESSION|jsession)") {
                		return(pass);
                	if (req.http.X-Requested-With == "XMLHttpRequest" || req.url ~ "nocache") {
                		return(pass);
                	#Enable static cache
                	if (req.request=="GET" && req.url ~ "\.(css|js|txt|zip|pdf|rtf|flv|swf|html|htm)$") {
                		unset req.http.cookie;
                		return(lookup);
                	if (req.request=="GET" && req.url ~ "\.(gif|jpg|jpeg|bmp|png|ico|img|tga|wmf|mp3|ogg)$") {
                		return(lookup);
                	#Be rfc2616 compliant
                	if (req.request ~ "^(GET|HEAD|PUT|POST|TRACE|OPTIONS|DELETE)$") {
                		return(lookup);
                	else	{
                		return(pipe);
                	return(lookup);
                sub vcl_pipe {
                	# If we don't set the Connection: close header, any following
                	# requests from the client will also be piped through and
                	# left untouched by varnish. We don't want that.
                	set req.http.connection = "close";
                	# Note: no "pipe" action here - we'll fall back to the default
                	# pipe method so that when any changes are made there, we
                	# still inherit them.
                sub vcl_hit {
                	return (deliver);
                sub vcl_miss {
                	return (fetch);
                sub vcl_fetch {
                	set beresp.do_stream = true;
                	#Disable cache when backend is starting a session
                	if (beresp.http.Set-Cookie && beresp.http.Set-Cookie ~ "(PHPSESSID|phpsessid)") {
                		return(hit_for_pass);
                	if (beresp.http.Set-Cookie && beresp.http.Set-Cookie ~ "(JSESSION|jsession)") {
                	if (beresp.http.X-Requested-With == "XMLHttpRequest" || req.url ~ "nocache") {
                	# Varnish respects the wishes of the backend application.
                	if (beresp.http.Pragma ~ "no-cache" || beresp.http.Cache-Control ~ "(no-cache|no-store|private)") {
                    ## If the request to the backend returns a code other than 200, restart the loop
                    ## If the number of restarts reaches the value of the parameter max_restarts,
                    ## the request will be error'ed.  max_restarts defaults to 4.  This prevents
                    ## an eternal loop in the event that, e.g., the object does not exist at all.
                    if (beresp.status != 200 && beresp.status != 403 && beresp.status != 404 &&
                    	beresp.status != 303 && beresp.status != 302 && beresp.status != 301 && beresp.status != 401 ) {
                		return(restart);
                	set beresp.grace = 60s;
                		return(deliver);
                sub vcl_deliver {
                	##set resp.http.X-Served-By = server.hostname;
                  	if (obj.hits > 0) {
                    	set resp.http.X-Cache = "HIT";
                    	set resp.http.X-Cache-Hits = obj.hits;
                  	} else {
                    	set resp.http.X-Cache = "MISS";
                	return(deliver);
                sub vcl_init {
                	return (ok);
                sub vcl_fini {
                	return (ok);
                im sure there is something very simple that im missing and ive been staring at this so long im missing the forest staring at the trees.
                anyone have any ideas?
                all the best and thanks in advance
                NT
                ![Screen Shot 2012-04-13 at 2.53.37 PM.jpg](/public/imported_attachments/1/Screen Shot 2012-04-13 at 2.53.37 PM.jpg)
                ![Screen Shot 2012-04-13 at 2.53.37 PM.jpg_thumb](/public/imported_attachments/1/Screen Shot 2012-04-13 at 2.53.37 PM.jpg_thumb)
                  marcelloc
                  Are you sure you do not have any nat or pfsense gui on port 80?
                    normtodd
                    thanks marcelloc for responding and for all of your wonderful work on pfsense
                    pfsense gui is on :81 and i removed the nat forwarding to port 80, just adding a rule on the wan opening port 80 (toward varnish)
                      marcelloc
                      @normtodd:
                      Without this rule, varnish will get no traffic.  :)
                        normtodd
                        i apologize - i think im getting mixed up ! :)
                        per this thread, i removed the nat rule (which i previously had configured prior to installing varnish) for port 80
                        in order to have port 80 open (in order for traffic to reach varnish), i added a firewall rule on the wan for port 80 to be open
                        isnt this the correct config? :)
                        all the best and thanks for all
                          marcelloc
                          Yes, the setup is this way.
                          Are you sure it's working through varnish?
                            normtodd
                            i assume that varnish listens on port 80 and the wan firewall rule would allow access?
                            how would i confirm that its working through varnish?
                              marcelloc
                              Well, widget should show it to you but you can try to stop varnish and see if you can access internal server or if publishing has stopped.
                                normtodd
                                per your suggestion i stopped varnish which made the website unreachable/not accessible
                                is this the expected result?
                                original problem of nonupdating widget remained when i restarted varnish (in case you were curious)
                                  marcelloc
                                  @normtodd:
                                  Yes.
                                  @normtodd:
                                  I have no idea how to help you right now.
                                    normtodd
                                    as a last ditch i uninstalled and resinstalled varnish.
                                    this is the part where i hang my head in shame for not doing proper troubleshooting before posting.
                                    [shame]
                                    i had installed and was working from the varnish3 package.  that was the package that was not populating the widget.  i uninstalled varnish3, installed varnish and it works great, which the widget updating as it should.
                                    [/shame]
                                    so that was the issue.
                                    thank you marcelloc for all of your work
                                    best
                                    BT
                                      marcelloc
                                      @normtodd:
                                      I uninstalled varnish3, installed varnish and it works great, which the widget updating as it should.
                                      Thanks for the feedback. I'll check if varnish3 changed something that widget can't read.
                                        rajbps
                                        Hiya,
                                        I had install varnish on pfsense and everything was working fine.
                                        I had to rebuild my firewall and now my websites are down.
                                        I followed this:
                                        First be sure your pfsense gui is not listening on port 80 (system-> advanced)
                                        mine is on https and port 441
                                        Varnish config begins with backend configuration
                                        Each backend means a webserver
                                        inside each configuration, you must provide:
                                        Backend name = test
                                            Ip Address = 192.168.2.10
                                            Port= 80
                                            Probe URL= http://www.mywebsiteaddress.com
                                            Probe Interval (5)
                                            Probe Timeout (1)
                                            Probe window (5)
                                            Probe Threshold (3)
                                        on backend mapping, you could choose
                                        map=host
                                        match=equal
                                        expression=www.mydomain.com (for first web server)
                                        save backend config
                                        on settings
                                        Listen port=80
                                            Managment interface=127.0.0.1:85
                                            storage type=memory
                                            cache storage size=1024
                                        on General VCL settings, check all options  # checked all options
                                        all other options on settings could be in default value
                                        When I go to the website, I get a :
                                        It works!
                                        This is the default web page for this server.
                                        The web server software is running but no content has been added, yet.
                                        I think this is coming from pfsense and not getting redirected.
                                        I have varnish 3 installed.
                                        Hope someone could show me my mistake.
                                        On the wan I have this rule:
                                        TCP * * WAN address 80 (HTTP) * none
                                        I have rebooted the firewall a few times
                                        Cheers,
                                        Raj
                                          marcelloc
                                          try to replace http://www.mywebsiteaddress.com probe url to a full url like http://www.mywebsiteaddress.com/index.html
                                            rajbps
                                            did and no joy
                                            the only way I got one of the website to work was this :
                                            host equal www.mywebsite.com
                                            and
                                            host equal mywebsite.com
                                            previously i do not remember having it like that as I have screenshot of varnish setting from before.
