    Varnish help on setting up for multiple internal webservers
    66 Posts 10 Posters 32.3k Views
      rajbps
      is there any logs to see why even though varnish is working pfsense is not redirecting properly pls?
      Cheers,
      Raj
      • marcellocM Offline
        marcelloc
        the widget will show backend status and to see varnish logs, you can use varnishlog from console
          serangku
          Thanks @marcelloc for this topic
          after a week to re read also re read to other post …
          it's configure with success to serve multiple server behind 1 ip public
          great package
            skipmed
            @marcelloc:
            Hi Marcello, I have the same problem with my pfsense:
            2.0.2-RELEASE (amd64)
            built on Fri Dec 7 22:39:43 EST 2012
            FreeBSD 8.1-RELEASE-p13
            and Varnish 3.0.2 pkg v.0.1
            I tried all suggestion you gave but nothing solve my problem: when I call the Varnish on litening port (8082 in my case), only the firt defined backend is returned, no change if I call www.call1.com or www.call2.com (both domains point to public ip of pfsense of course).
            this is the configuration:
            backend crmBACKEND {
            used in catch_all
            .host = "10.8.0.1";
            .port = "51231";
            .first_byte_timeout = 100s;
            .connect_timeout = 100s;
            .probe = {
            .request =
            "GET /diagnostico.asp HTTP/1.1"
            "Accept: text/*"
            "User-Agent: Varnish"
            "Host: www.site1.com"
            "Connection: Close";
            .interval = 10s;
            .timeout = 100s;
            .window = 1;
            .threshold = 1;
            backend wwwBACKEND {
            used in catch_all
            .host = "192.168.1.2";
            .port = "80";
            .probe = {
            .url = "www.site2.com";
            .interval = 10s;
            .timeout = 100s;
            .window = 1;
            .threshold = 1;
            sub vcl_recv {
            #BASIC VCL RULES SETTING
            #set client balance identity
            set client.identity = req.http.user-agent;
            #set X-forward
            set req.http.X-Forwarded-For = client.ip;
            if (req.http.host == "www.call1.com") {
            set req.backend = crmBACKEND;
            set req.grace=1s;
            else if (req.http.host == "www.call2.com") {
            set req.backend = wwwBACKEND;
            set req.grace=1s;
            #respect client wish to refresh the page
            if (req.http.Pragma ~ "no-cache")
            return(pass);
            #BASIC VCL RULES ACTIONS
            #Disable session cache
            if (req.http.Cookie && req.http.Cookie ~ "(PHPSESSID|phpsessid)") {
            return(pass);
            if (req.http.Cookie && req.http.Cookie ~ "(JSESSION|jsession)") {
            return(pass);
            if (req.http.X-Requested-With == "XMLHttpRequest" || req.url ~ "nocache") {
            return(pass);
            #Enable static cache
            if (req.request=="GET" && req.url ~ ".(css|js|txt|zip|pdf|rtf|flv|swf|html|htm)$") {
            unset req.http.cookie;
            return(lookup);
            if (req.request=="GET" && req.url ~ ".(gif|jpg|jpeg|bmp|png|ico|img|tga|wmf|mp3|ogg)$") {
            return(lookup);
            if (req.request != "GET" && req.request != "HEAD") {return(pipe);}
            return(lookup);
            sub vcl_pipe {
            If we don't set the Connection: close header, any following
            requests from the client will also be piped through and
            left untouched by varnish. We don't want that.
            set req.http.connection = "close";
            Note: no "pipe" action here - we'll fall back to the default
            pipe method so that when any changes are made there, we
            still inherit them.
            sub vcl_hit {
            return (deliver);
            sub vcl_miss {
            return (fetch);
            sub vcl_fetch {
            #Disable cache when backend is starting a session
            if (beresp.http.Set-Cookie && beresp.http.Set-Cookie ~ "(PHPSESSID|phpsessid)") {
            return(hit_for_pass);
            if (beresp.http.Set-Cookie && beresp.http.Set-Cookie ~ "(JSESSION|jsession)") {
            if (beresp.http.X-Requested-With == "XMLHttpRequest" || req.url ~ "nocache") {
            Varnish respects the wishes of the backend application.
            if (beresp.http.Pragma ~ "no-cache" || beresp.http.Cache-Control ~ "(no-cache|no-store|private)") {
                ## If the request to the backend returns a code other than 200, restart the loop
                ## If the number of restarts reaches the value of the parameter max_restarts,
                ## the request will be error'ed.  max_restarts defaults to 4.  This prevents
                ## an eternal loop in the event that, e.g., the object does not exist at all.
                if (beresp.status != 200 && beresp.status != 403 && beresp.status != 404 &&
                beresp.status != 303 && beresp.status != 302 && beresp.status != 301 && beresp.status != 401 ) {
            set beresp.saintmode = 60s;
            return(restart);
            set beresp.grace = 30m;
            return(deliver);
            sub vcl_deliver {
            ##set resp.http.X-Served-By = server.hostname;
              if (obj.hits > 0) {
                set resp.http.X-Cache = "HIT";
                set resp.http.X-Cache-Hits = obj.hits;
              } else {
                set resp.http.X-Cache = "MISS";
            return(deliver);
            sub vcl_init {
            return (ok);
            sub vcl_fini {
            return (ok);
            what is wrong? thanks in advance
              marcelloc
              @skipmed:
              what backend status you get on dashboard varnish widget?
                skipmed
                @marcelloc:
                @skipmed:
                both up with green arrow
                no other value is shown in the fields "cache hits" etc., just shows the two backends with status
                thanks
