    Varnish help on setting up for multiple internal webservers
    66 Posts 10 Posters 32.6k Views
    • marcellocM Offline
      marcelloc
      The conf looks fine. Are you still unable to start varnish?
      What files do you have on /usr/local/etc/rc.d ?
        kegler
        @marcelloc:
        varnish.sh
        varnishd
        varnishlog
        varnishncsa
        clamd
          marcelloc
          The file is there and package is installed, it should work.  ???
          Just to check, see if varnish package is installed with pkg_info on console.
          ps ax | grep varnish will show if there is any varnish process running.
            kegler
            @marcelloc:
            18796  0  S+    0:00.00 grep varnish
            looks like not running?
              marcelloc
              What about pkg_info cmd?
              What does returns /usr/local/etc/rc.d/varnish.sh start
                kegler
                @marcelloc:
                sorry what is the cmd to check the above ?
                  kegler
                  [2.0-RELEASE][admin@kegpfs.kegnet.com]/usr/local/etc/rc.d(6): varnish.sh start
                  varnish.sh: Command not found.
                  seems something not installed ?
                    marcelloc
                    Do not chdir to rc.d, Run varnish.sh with full path
                      kegler
                      @marcelloc:
                      kern.ipc.nmbclusters: 65536
                      sysctl: kern.ipc.nmbclusters: Invalid argument
                      kern.ipc.somaxconn: 16384 -> 16384
                      kern.maxfiles: 131072 -> 131072
                      kern.maxfilesperproc: 104856 -> 104856
                      kern.threads.max_threads_per_proc: 4096 -> 4096
                      wondering could it be due to my domain is host by no-ip.com?
                        kegler
                        php: /pkg_edit.php: The command '/usr/local/etc/rc.d/varnish.sh' returned exit code '2', the output was 'kern.ipc.nmbclusters: 65536 sysctl: kern.ipc.nmbclusters: Invalid argument kern.ipc.somaxconn: 16384 -> 16384 kern.maxfiles: 131072 -> 131072 kern.maxfilesperproc: 104856 -> 104856 kern.threads.max_threads_per_proc: 4096 -> 4096 storage_malloc: max size 1024 MB. Message from VCC-compiler: Expected ';' got '/' (program line 369), at (input Line 28 Pos 26) .url = ""/""; –-----------------------#--- In backend specification starting at: (input Line 21 Pos 1) backend kegapp33BACKEND { #######------------------ Running VCC-compiler failed, exit 1 VCL compilation failed'
                        saw this in my log… but i dont quite understand what went wrong
                        and i kvm into my pfsense and saw this on the screen.... seems like its stucked at the loading of varnish....
                        i think i messed up the pfsense somewhere
                          marcelloc
                          Remove quotes from your backend Test url
                          .url = ""/"";
                            kegler
                            omg…it worked now...thank you very much....
                              canefield
                              @marcelloc:
                              Each backend means a webserver
                              inside each configuration, you must provide:
                              • Backend name = WindowsServer
                              • Ip Address = 192.168.1.4
                              • Port = 80 <– Q
                              • Probe URL = "/"(if your server has a valid page on "/")
                              • Probe Interval = 5
                              • Probe Timeout = 1
                              • Probe window = 5
                              • Probe Threshold = 3
                              Q:
                              Can I enter multiple listening ports e.g. port: "80, 443"? Or should I configure that host several times according to how many ports it is listening on?
                              Thanks,
                              Canefield
                                marcelloc
                                I think you need one port for each config as varnish is going to check backend health as well send traffic based on this port.
                                Keep in mind That varnish implemets http balance/cache only. If you what to balance https as well, haproxy can do this.
                                Pound and relayd can do client/firewall ssl comunication and then forward client request to varnish, but there is no gui options for this yet.
                                • L Offline
                                  Landmine
                                  Hate to jump on someone else's thread, but I've gone threw all the same motions, but still no results.
                                  web1.domain.com
                                  web2.domain.com
                                  All end up pointing to the pfSense login, so my question is simply this… What IP do you point the Rule to? the pfSense box that host Varnish?
                                    marcelloc
                                    Did you changed  pfsense gui port?
                                    This current varnish gui implementation listens deamon on all interfaces.
                                    • L Offline
                                      Landmine
                                      I did now and it works!
                                      Guess next time I need to slow down and read all the helpful text.
                                      Thank you
                                      • L Offline
                                        Landmine
                                        Correction, it was working. I didnt change anything and I'm getting the 503 errors again  :(
                                        –---------- Update ------------
                                        I only get the 503 error on 1 of the 2 domains.
                                        ------------ Update ------------
                                        Removing the Backend mapping with the http:// on it seemed to fix the issue.
                                        Down again after about 30 seconds.  >:(
                                          marcelloc
                                          That's probably a backend health url check problem.
                                          Add varnish widget to dashboard to see backend status.
                                          The 503 error means could not find any available backend.
                                          Also try to see backend configuration file on view configuration.
                                          • L Offline
                                            Landmine
                                            Here is my config
                                            # Varnish configuration file
                                            # Automatically generated by the pfSense package system
                                            # This file is located in /var/etc/default.vcl
                                            sub vcl_error {
                                            		if (obj.status == 503 && req.restarts < 1) {
                                            			restart;
                                            	set obj.http.Content-Type = "text/html; charset=utf-8";
                                            	synthetic {"
                                            "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
                                            <title>"} obj.status " " obj.response {"</title>
                                             **We are very sorry but an error occurred during this request.**
                                            Please press refresh in your browser to try again.
                                            Varnish Error "} obj.status " " obj.response {"
                                            "} obj.response {"
                                            ### Guru Meditation:
                                            XID: "} req.xid {"
                                            	return(deliver);
                                            backend MinecraftBACKEND {
                                            	# used in catch_all
                                            	.host = "10.0.0.50";
                                            	.port = "80";
                                            	.first_byte_timeout = 300s;
                                            	.connect_timeout = 25s;
                                            	.probe = {
                                            		.url = "/index.php";
                                            		.interval = 5s;
                                            		.timeout = 3s;
                                            		.window = 5;
                                            		.threshold = 3;
                                            sub vcl_recv {
                                            	#BASIC VCL RULES SETTING
                                            	#Fix gzip compression
                                            	if (req.http.Accept-Encoding) {
                                            	if (req.url ~ "\.(gif|jpg|jpeg|bmp|png|ico|img|tga|wmf|gz|tgz|bz2|tbz|mp3|ogg)$") {
                                            		unset req.http.Accept-Encoding;
                                            	else if (req.http.Accept-Encoding ~ "gzip") {
                                            		set req.http.Accept-Encoding = "gzip";
                                            	else if (req.http.Accept-Encoding ~ "deflate") {
                                            		set req.http.Accept-Encoding = "deflate";
                                            	else	{
                                            	#set client balance identity
                                            	set client.identity = client.ip;
                                            	#set X-forward
                                            	set req.http.X-Forwarded-For = client.ip;
                                            	if (req.http.host == "minecraft.domain.com") {
                                            		set req.backend = MinecraftBACKEND;
                                            	#respect client wish to refresh the page
                                            	if (req.http.Pragma ~ "no-cache")
                                            		return(pass);
                                            	#BASIC VCL RULES ACTIONS
                                            	#Disable post cache
                                            	if (req.request == "POST") {
                                            		return(pass);
                                            	#Enable static cache
                                            	if (req.request=="GET" && req.url ~ "\.(css|js|txt|zip|rtf|flv|swf|html|htm)$") {
                                            		return(pass);
                                            	if (req.request=="GET" && req.url ~ "\.(gif|jpg|jpeg|bmp|png|ico|img|tga|wmf|mp3|ogg)$") {
                                            		return(pass);
                                            	#Disable session cache
                                            	if (req.http.Cookie && req.http.Cookie ~ "(PHPSESSID|phpsessid)") {
                                            		return(pass);
                                            	if (req.http.Cookie && req.http.Cookie ~ "(JSESSION|jsession)") {
                                            		return(pass);
                                            	if (req.http.X-Requested-With == "XMLHttpRequest" || req.url ~ "nocache") {
                                            		return(pass);
                                            	#Be rfc2616 compliant
                                            	if (req.request ~ "^(GET|HEAD|PUT|POST|TRACE|OPTIONS|DELETE)$") {
                                            		return(lookup);
                                            	else	{
                                            		return(pipe);
                                            	return(lookup);
                                            sub vcl_pipe {
                                            	# If we don't set the Connection: close header, any following
                                            	# requests from the client will also be piped through and
                                            	# left untouched by varnish. We don't want that.
                                            	set req.http.connection = "close";
                                            	# Note: no "pipe" action here - we'll fall back to the default
                                            	# pipe method so that when any changes are made there, we
                                            	# still inherit them.
                                            sub vcl_fetch {
                                            	#Disable cache when backend is starting a session
                                            	if (beresp.http.Set-Cookie && beresp.http.Set-Cookie ~ "(PHPSESSID|phpsessid)") {
                                            		return(pass);
                                            	if (beresp.http.Set-Cookie && beresp.http.Set-Cookie ~ "(JSESSION|jsession)") {
                                            		return(pass);
                                            	if (beresp.http.X-Requested-With == "XMLHttpRequest" || req.url ~ "nocache") {
                                            		return(pass);
                                            	# Varnish respects the wishes of the backend application.
                                            	if (beresp.http.Pragma ~ "no-cache" || beresp.http.Cache-Control ~ "(no-cache|no-store|private)") {
                                            	return(pass);
                                                ## If the request to the backend returns a code other than 200, restart the loop
                                                ## If the number of restarts reaches the value of the parameter max_restarts,
                                                ## the request will be error'ed.  max_restarts defaults to 4.  This prevents
                                                ## an eternal loop in the event that, e.g., the object does not exist at all.
                                                if (beresp.status != 200 && beresp.status != 403 && beresp.status != 404 &&
                                                	beresp.status != 303 && beresp.status != 302 && beresp.status != 301 && beresp.status != 401 ) {
                                            		restart;
                                            	return(deliver);
                                            sub vcl_deliver {
                                            	##set resp.http.X-Served-By = server.hostname;
                                              	if (obj.hits > 0) {
                                                	set resp.http.X-Cache = "HIT";
                                                	set resp.http.X-Cache-Hits = obj.hits;
                                              	} else {
                                                	set resp.http.X-Cache = "MISS";
                                            	return(deliver);
