    Syslog remote logging problem after reboot
    25 Posts 7 Posters 9.0k Views
      athurdent
      Anyone else having problems with remote syslogging after a reboot? My installation does not send any syslogs until I manually restart syslogd.
      I have tried to debug this, /var/etc/syslog.conf looks OK after a reboot, my . @192.168.1.100 is there. It's running OK with
      /usr/sbin/syslogd -s -c -c -l /var/dhcpd/var/run/log -f /var/etc/syslog.conf
      but it's not sending anything to my loghost.
      I ran tcpdump -nvvi <interface>port 514 on each of my interfaces/VLANs and also on lo0. Then I logged in via SSH which normally triggers a syslog entry to be sent. No traffic leaving the box though. Manually killing the PID and starting syslog again with the above parameters helps, it logs to my remote host instantly.
      Any idea?
      I am currently on
      2.1-BETA1 (i386)
      built on Tue Jan 29 16:42:56 EST 2013
      FreeBSD 8.3-RELEASE-p5</interface>
        mrzaz
        I'm running "2.1-BETA1 (i386) built on Wed Jan 30 04:20:11 EST 2013" after reboot upgrading
        to that version from previous snap and remote syslogging is working as expected. No problem there.
        Tested the ssh login and in came up OK in the syslog-server fine.
        //Dan Lundqvist, SWEDEN
          athurdent
          I also tried a reset to factory defaults now. After that I just disabled IPv6 on the LAN/WAN interface, set a DNS and went straight to the remote syslog settings, remote logging works. After a reboot it stops working. The first message in /var/log/system.log is:
          syslogd: sendto: Network is unreachable
          I'm getting this error on all my pfSense hosts: An ALIX board, a KVM and an old Dell Notebook.
          The config says:
          	 <syslog><nentries>50</nentries>
          		<remoteserver>192.168.1.100</remoteserver>
          		 <remoteserver2><remoteserver3><logall><enable></enable></logall></remoteserver3></remoteserver2></syslog>
          What am I doing wrong?
            mrzaz
            I am NOT seeing any "syslogd: sendto: Network is unreachable" in my system.log.
            And it works fine even after reboot.
            And my config looks like this:
            		<remoteserver>192.168.120.62</remoteserver>
            		 <remoteserver2><remoteserver3><enable><logall></logall></enable></remoteserver3></remoteserver2></syslog>
            //Dan
            • jimpJ Offline
              Where is 192.168.120.62? On your LAN? Across a VPN? Somewhere else? If it's local, what type of interface is it on? Captive portal enabled there?
              I've got a router on 2.1 just installed on Friday that does remote syslog across OpenVPN and it works fine after a reboot, no problems there at all.
              Remember: Upvote with the šŸ‘ button for any user/post you find to be helpful, informative, or deserving of recognition!
              Do not Chat/PM for help!
                athurdent
                My devices are all in the same LAN subnet, even on the same switch. I played a little with an ALIX Board, no VLANs, just plain vr interfaces. LAN static, WAN DHCP. No captive portal, just the freeradius2 package installed, OpenVPN and IPsec VPN enabled.
                Strangely logging works when I use my local IPv6 net. As that does not rely on ARP, I had a look at my switch configuration (Cisco SG300), but playing with ARP and MAC age settings did not help. Then I tried the hardware settings on the ALIX, but after enabling Device Polling it became unreachable after reboot. I have power cycle it tonight, I was doing the tests remote.
                Is it normal for dmesg printing those after reboot? I always get those…
                Trying to mount root from ufs:/dev/ufs/pfsense1
                vr1: link state changed to DOWN
                vr1: link state changed to UP
                vr0: link state changed to DOWN
                pflog0: promiscuous mode enabled
                vr0: link state changed to UP
                  mrzaz
                  @jimp:
                  Jimp: My system is working OK and the 192.168.120.62 is on the local LAN subnet and normal NIC interface. And not using captive portal.
                  It is "athurdent" who has problems. Ā Just briefing him that it is not generic problem with 2.1 but seems to be a local problem.
                  The reason to why I included my config was just to show him how my working one looks like.Ā  :)
                  //Dan
                    bardelot
                    @athurdent:
                    There is a fix that restarts syslog at the end of the booting process when an IPv6 address is being used. The reason for that fix was very similar to the problem you are experiencing, where syslog would not send logs over IPv6 at bootup. Here is that note http://redmine.pfsense.org/issues/2370#note-12.
                      athurdent
                      Thanks, I think I'll stick with IPv6 for now. I know it used to work after a reboot, I am using and updating my pfSense 2.1 KVM for approx. a year now. If I changed something relevant to that in my network, I cannot find it. As it works everywhere else, I'll keep on looking and report back when I find the cause. Thanks for the help so far!
                      • O Offline
                        Ocid
                        I have the same problem with my test server (built on Mon Feb 4 03:44:55 EST 2013), no entries in remote syslog.
                        	 <syslog><reverse><nentries>50</nentries>
                        		 <logall><nologdefaultblock><remoteserver>192.168.10.10</remoteserver>
                        		 <remoteserver2><remoteserver3><enable></enable></remoteserver3></remoteserver2></nologdefaultblock></logall></reverse></syslog>
                        Remote syslog server is in same LAN.
                        My "production" pfSense machine (built on Mon Jan 28 07:27:34 EST 2013 [not updated, before new Status Queues page works]) does sendĀ  events to remote syslog.
                        	 <syslog><nentries>100</nentries>
                        		 <reverse><remoteserver>192.168.10.10</remoteserver>
                        		 <remoteserver2><remoteserver3><enable><nologdefaultblock><dhcp><portalauth><vpn><apinger><relayd><hostapd></hostapd></relayd></apinger></vpn></portalauth></dhcp></nologdefaultblock></enable></remoteserver3></remoteserver2></reverse></syslog>
                          athurdent
                          Interesting, what is the first entry in /var/log/system.log?
                          • O Offline
                            Ocid
                            @athurdent:
                            Feb 5 11:25:06	kernel: Copyright (c) 1992-2012 The FreeBSD Project.
                            And because I don't think that that is enough, so here's a bit more:
                            Feb 5 11:25:06	kernel: Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
                            Feb 5 11:25:06	kernel: The Regents of the University of California. All rights reserved.
                            Feb 5 11:25:06	kernel: FreeBSD is a registered trademark of The FreeBSD Foundation.
                            Feb 5 11:25:06	kernel: FreeBSD 8.3-RELEASE-p5 #1: Mon Feb 4 04:12:41 EST 2013
                            Feb 5 11:25:06	kernel: root@snapshots-8_3-i386.builders.pfsense.org:/usr/obj./usr/pfSensesrc/src/sys/pfSense_SMP.8 i386
                            Feb 5 11:25:06	kernel: Timecounter "i8254" frequency 1193182 Hz quality 0
                            Feb 5 11:25:06	kernel: CPU: Intel(R) Core(TM)2 Duo CPU T7700 @ 2.40GHz (2488.27-MHz 686-class CPU)
                            Feb 5 11:25:06	kernel: Origin = "GenuineIntel" Id = 0x6fa Family = 6 Model = f Stepping = 10
                            Feb 5 11:25:06	kernel: Features=0xfa3fbff <fpu,vme,de,pse,tsc,msr,pae,mce,cx8,apic,sep,mtrr,pge,mca,cmov,pat,pse36,dts,mmx,fxsr,sse,sse2,ss>Feb 5 11:25:06	kernel: Features2=0x80202201 <sse3,ssse3,cx16,x2apic,hv>Feb 5 11:25:06	kernel: AMD Features=0x20100000 <nx,lm>Feb 5 11:25:06	kernel: AMD Features2=0x1 <lahf>Feb 5 11:25:06	kernel: TSC: P-state invariant
                            Feb 5 11:25:06	kernel: real memory = 268435456 (256 MB)
                            Feb 5 11:25:06	kernel: avail memory = 238817280 (227 MB)
                            Feb 5 11:25:06	kernel: ACPI APIC Table: <ptltd apic="">Feb 5 11:25:06	kernel: MADT: Forcing active-low polarity and level trigger for SCI
                            Feb 5 11:25:06	kernel: ioapic0 <version 1.1="">irqs 0-23 on motherboard
                            Feb 5 11:25:06	kernel: wlan: mac acl policy registered
                            Feb 5 11:25:06	kernel: ipw_bss: You need to read the LICENSE file in /usr/share/doc/legal/intel_ipw/.
                            Feb 5 11:25:06	kernel: ipw_bss: If you agree with the license, set legal.intel_ipw.license_ack=1 in /boot/loader.conf.
                            Feb 5 11:25:06	kernel: module_register_init: MOD_LOAD (ipw_bss_fw, 0xc07b9a10, 0) error 1
                            Feb 5 11:25:06	kernel: ipw_ibss: You need to read the LICENSE file in /usr/share/doc/legal/intel_ipw/.
                            Feb 5 11:25:06	kernel: ipw_ibss: If you agree with the license, set legal.intel_ipw.license_ack=1 in /boot/loader.conf.
                            Feb 5 11:25:06	kernel: module_register_init: MOD_LOAD (ipw_ibss_fw, 0xc07b9ab0, 0) error 1
                            Feb 5 11:25:06	kernel: ipw_monitor: You need to read the LICENSE file in /usr/share/doc/legal/intel_ipw/.
                            Feb 5 11:25:06	kernel: ipw_monitor: If you agree with the license, set legal.intel_ipw.license_ack=1 in /boot/loader.conf.
                            Feb 5 11:25:06	kernel: module_register_init: MOD_LOAD (ipw_monitor_fw, 0xc07b9b50, 0) error 1
                            Feb 5 11:25:06	kernel: kbd1 at kbdmux0
                            Feb 5 11:25:06	kernel: cryptosoft0: <software crypto="">on motherboard
                            Feb 5 11:25:06	kernel: padlock0: No ACE support.
                            Feb 5 11:25:06	kernel: acpi0: <intel 440bx="">on motherboard
                            Feb 5 11:25:06	kernel: acpi0: [ITHREAD]
                            Feb 5 11:25:06	kernel: acpi0: Power Button (fixed)
                            Feb 5 11:25:06	kernel: Timecounter "HPET" frequency 14318180 Hz quality 900
                            Feb 5 11:25:06	kernel: Timecounter "ACPI-fast" frequency 3579545 Hz quality 1000
                            Feb 5 11:25:06	kernel: acpi_timer0: <24-bit timer at 3.579545MHz> port 0x1008-0x100b on acpi0
                            Feb 5 11:25:06	kernel: cpu0: <acpi cpu="">on acpi0
                            Feb 5 11:25:06	kernel: pcib0: <acpi host-pci="" bridge="">port 0xcf8-0xcff on acpi0
                            Feb 5 11:25:06	kernel: pci0: <acpi pci="" bus="">on pcib0
                            Feb 5 11:25:06	kernel: pcib1: <acpi pci-pci="" bridge="">at device 1.0 on pci0
                            Feb 5 11:25:06	kernel: pci1: <acpi pci="" bus="">on pcib1
                            Feb 5 11:25:06	kernel: isab0: <pci-isa bridge="">at device 7.0 on pci0
                            Feb 5 11:25:06	kernel: isa0: <isa bus="">on isab0
                            Feb 5 11:25:06	kernel: atapci0: <intel piix4="" udma33="" controller="">port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0x10c0-0x10cf at device 7.1 on pci0
                            Feb 5 11:25:06	kernel: ata0: <ata channel="">at channel 0 on atapci0
                            Feb 5 11:25:06	kernel: ata0: [ITHREAD]
                            Feb 5 11:25:06	kernel: ata1: <ata channel="">at channel 1 on atapci0
                            Feb 5 11:25:06	kernel: ata1: [ITHREAD]
                            Feb 5 11:25:06	kernel: pci0: <bridge>at device 7.3 (no driver attached)
                            Feb 5 11:25:06	kernel: pci0: <base peripheral=""> at device 7.7 (no driver attached)
                            Feb 5 11:25:06	kernel: vgapci0: <vga-compatible display="">port 0x10d0-0x10df mem 0xd0000000-0xd7ffffff,0xc8800000-0xc8ffffff irq 16 at device 15.0 on pci0
                            Feb 5 11:25:06	kernel: pcib2: <acpi pci-pci="" bridge="">at device 17.0 on pci0
                            Feb 5 11:25:06	kernel: pci2: <acpi pci="" bus="">on pcib2
                            Feb 5 11:25:06	kernel: em0: <intel(r) 1000="" pro="" legacy="" network="" connection="" 1.0.4="">port 0x2000-0x203f mem 0xc9020000-0xc903ffff,0xc9000000-0xc900ffff irq 18 at device 0.0 on pci2
                            Feb 5 11:25:06	kernel: em0: Memory Access and/or Bus Master bits were not set!
                            Feb 5 11:25:06	kernel: em0: [FILTER]
                            Feb 5 11:25:06	kernel: em1: <intel(r) 1000="" pro="" legacy="" network="" connection="" 1.0.4="">port 0x2040-0x207f mem 0xc9040000-0xc905ffff,0xc9010000-0xc901ffff irq 19 at device 1.0 on pci2
                            Feb 5 11:25:06	kernel: em1: Memory Access and/or Bus Master bits were not set!
                            Feb 5 11:25:06	kernel: em1: [FILTER]
                            Feb 5 11:25:06	kernel: pcib3: <acpi pci-pci="" bridge="">at device 21.0 on pci0
                            Feb 5 11:25:06	kernel: pci3: <acpi pci="" bus="">on pcib3
                            Feb 5 11:25:06	kernel: pcib4: <acpi pci-pci="" bridge="">at device 21.1 on pci0
                            Feb 5 11:25:06	kernel: pci4: <acpi pci="" bus="">on pcib4
                            Feb 5 11:25:06	kernel: pcib5: <acpi pci-pci="" bridge="">at device 21.2 on pci0
                            Feb 5 11:25:06	kernel: pci5: <acpi pci="" bus="">on pcib5
                            Feb 5 11:25:06	kernel: pcib6: <acpi pci-pci="" bridge="">at device 21.3 on pci0
                            Feb 5 11:25:06	kernel: pci6: <acpi pci="" bus="">on pcib6
                            Feb 5 11:25:06	kernel: pcib7: <acpi pci-pci="" bridge="">at device 21.4 on pci0
                            Feb 5 11:25:06	kernel: pci7: <acpi pci="" bus="">on pcib7
                            Feb 5 11:25:06	kernel: pcib8: <acpi pci-pci="" bridge="">at device 21.5 on pci0
                            Feb 5 11:25:06	kernel: pci8: <acpi pci="" bus="">on pcib8
                            Feb 5 11:25:06	kernel: pcib9: <acpi pci-pci="" bridge="">at device 21.6 on pci0
                            Feb 5 11:25:06	kernel: pci9: <acpi pci="" bus="">on pcib9
                            Feb 5 11:25:06	kernel: pcib10: <acpi pci-pci="" bridge="">at device 21.7 on pci0
                            Feb 5 11:25:06	kernel: pci10: <acpi pci="" bus="">on pcib10
                            Feb 5 11:25:06	kernel: pcib11: <acpi pci-pci="" bridge="">at device 22.0 on pci0
                            Feb 5 11:25:06	kernel: pci11: <acpi pci="" bus="">on pcib11
                            Feb 5 11:25:06	kernel: pcib12: <acpi pci-pci="" bridge="">at device 22.1 on pci0
                            Feb 5 11:25:06	kernel: pci12: <acpi pci="" bus="">on pcib12
                            Feb 5 11:25:06	kernel: pcib13: <acpi pci-pci="" bridge="">at device 22.2 on pci0
                            Feb 5 11:25:06	kernel: pci13: <acpi pci="" bus="">on pcib13
                            Feb 5 11:25:06	kernel: pcib14: <acpi pci-pci="" bridge="">at device 22.3 on pci0
                            Feb 5 11:25:06	kernel: pci14: <acpi pci="" bus="">on pcib14
                            Feb 5 11:25:06	kernel: pcib15: <acpi pci-pci="" bridge="">at device 22.4 on pci0
                            Feb 5 11:25:06	kernel: pci15: <acpi pci="" bus="">on pcib15
                            Feb 5 11:25:06	kernel: pcib16: <acpi pci-pci="" bridge="">at device 22.5 on pci0
                            Feb 5 11:25:06	kernel: pci16: <acpi pci="" bus="">on pcib16
                            Feb 5 11:25:06	kernel: pcib17: <acpi pci-pci="" bridge="">at device 22.6 on pci0
                            Feb 5 11:25:06	kernel: pci17: <acpi pci="" bus="">on pcib17
                            Feb 5 11:25:06	kernel: pcib18: <acpi pci-pci="" bridge="">at device 22.7 on pci0
                            Feb 5 11:25:06	kernel: pci18: <acpi pci="" bus="">on pcib18
                            Feb 5 11:25:06	kernel: pcib19: <acpi pci-pci="" bridge="">at device 23.0 on pci0
                            Feb 5 11:25:06	kernel: pci19: <acpi pci="" bus="">on pcib19
                            Feb 5 11:25:06	kernel: pcib20: <acpi pci-pci="" bridge="">at device 23.1 on pci0
                            Feb 5 11:25:06	kernel: pci20: <acpi pci="" bus="">on pcib20
                            Feb 5 11:25:06	kernel: pcib21: <acpi pci-pci="" bridge="">at device 23.2 on pci0
                            Feb 5 11:25:06	kernel: pci21: <acpi pci="" bus="">on pcib21
                            Feb 5 11:25:06	kernel: pcib22: <acpi pci-pci="" bridge="">at device 23.3 on pci0
                            Feb 5 11:25:06	kernel: pci22: <acpi pci="" bus="">on pcib22
                            Feb 5 11:25:06	kernel: pcib23: <acpi pci-pci="" bridge="">at device 23.4 on pci0
                            Feb 5 11:25:06	kernel: pci23: <acpi pci="" bus="">on pcib23
                            Feb 5 11:25:06	kernel: pcib24: <acpi pci-pci="" bridge="">at device 23.5 on pci0
                            Feb 5 11:25:06	kernel: pci24: <acpi pci="" bus="">on pcib24
                            Feb 5 11:25:06	kernel: pcib25: <acpi pci-pci="" bridge="">at device 23.6 on pci0
                            Feb 5 11:25:06	kernel: pci25: <acpi pci="" bus="">on pcib25
                            Feb 5 11:25:06	kernel: pcib26: <acpi pci-pci="" bridge="">at device 23.7 on pci0
                            Feb 5 11:25:06	kernel: pci26: <acpi pci="" bus="">on pcib26
                            Feb 5 11:25:06	kernel: pcib27: <acpi pci-pci="" bridge="">at device 24.0 on pci0
                            Feb 5 11:25:06	kernel: pci27: <acpi pci="" bus="">on pcib27
                            Feb 5 11:25:06	kernel: pcib28: <acpi pci-pci="" bridge="">at device 24.1 on pci0
                            Feb 5 11:25:06	kernel: pci28: <acpi pci="" bus="">on pcib28
                            Feb 5 11:25:06	kernel: pcib29: <acpi pci-pci="" bridge="">at device 24.2 on pci0
                            Feb 5 11:25:06	kernel: pci29: <acpi pci="" bus="">on pcib29
                            Feb 5 11:25:06	kernel: pcib30: <acpi pci-pci="" bridge="">at device 24.3 on pci0
                            Feb 5 11:25:06	kernel: pci30: <acpi pci="" bus="">on pcib30
                            Feb 5 11:25:06	kernel: pcib31: <acpi pci-pci="" bridge="">at device 24.4 on pci0
                            Feb 5 11:25:06	kernel: pci31: <acpi pci="" bus="">on pcib31
                            Feb 5 11:25:06	kernel: pcib32: <acpi pci-pci="" bridge="">at device 24.5 on pci0
                            Feb 5 11:25:06	kernel: pci32: <acpi pci="" bus="">on pcib32
                            Feb 5 11:25:06	kernel: pcib33: <acpi pci-pci="" bridge="">at device 24.6 on pci0
                            Feb 5 11:25:06	kernel: pci33: <acpi pci="" bus="">on pcib33
                            Feb 5 11:25:06	kernel: pcib34: <acpi pci-pci="" bridge="">at device 24.7 on pci0
                            Feb 5 11:25:06	kernel: pci34: <acpi pci="" bus="">on pcib34
                            Feb 5 11:25:06	kernel: acpi_acad0: <ac adapter="">on acpi0
                            Feb 5 11:25:06	kernel: atrtc0: <at realtime="" clock="">port 0x70-0x71 irq 8 on acpi0
                            Feb 5 11:25:06	kernel: atkbdc0: <keyboard controller="" (i8042)="">port 0x60,0x64 irq 1 on acpi0
                            Feb 5 11:25:06	kernel: atkbd0: <at keyboard="">irq 1 on atkbdc0
                            Feb 5 11:25:06	kernel: kbd0 at atkbd0
                            Feb 5 11:25:06	kernel: atkbd0: [GIANT-LOCKED]
                            Feb 5 11:25:06	kernel: atkbd0: [ITHREAD]
                            Feb 5 11:25:06	kernel: psm0: <ps 2="" mouse="">irq 12 on atkbdc0
                            Feb 5 11:25:06	kernel: psm0: [GIANT-LOCKED]
                            Feb 5 11:25:06	kernel: psm0: [ITHREAD]
                            Feb 5 11:25:06	kernel: psm0: model IntelliMouse, device ID 3
                            Feb 5 11:25:06	kernel: ppc0: <parallel port="">port 0x378-0x37f irq 7 on acpi0
                            Feb 5 11:25:06	kernel: ppc0: Generic chipset (NIBBLE-only) in COMPATIBLE mode
                            Feb 5 11:25:06	kernel: ppc0: [ITHREAD]
                            Feb 5 11:25:06	kernel: ppbus0: <parallel port="" bus="">on ppc0
                            Feb 5 11:25:06	kernel: plip0: <plip network="" interface="">on ppbus0
                            Feb 5 11:25:06	kernel: plip0: [ITHREAD]
                            Feb 5 11:25:06	kernel: lpt0: <printer>on ppbus0
                            Feb 5 11:25:06	kernel: lpt0: [ITHREAD]
                            Feb 5 11:25:06	kernel: lpt0: Interrupt-driven port
                            Feb 5 11:25:06	kernel: ppi0: <parallel i="" o="">on ppbus0
                            Feb 5 11:25:06	kernel: uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
                            Feb 5 11:25:06	kernel: uart0: [FILTER]
                            Feb 5 11:25:06	kernel: uart1: <16550 or compatible> port 0x2f8-0x2ff irq 3 on acpi0
                            Feb 5 11:25:06	kernel: uart1: [FILTER]
                            Feb 5 11:25:06	kernel: fdc0: <floppy drive="" controller="">port 0x3f0-0x3f5,0x3f7 irq 6 drq 2 on acpi0
                            Feb 5 11:25:06	kernel: fdc0: [FILTER]
                            Feb 5 11:25:06	kernel: fd0: <1440-KB 3.5" drive> on fdc0 drive 0
                            Feb 5 11:25:06	kernel: pmtimer0 on isa0
                            Feb 5 11:25:06	kernel: orm0: <isa option="" roms="">at iomem 0xc0000-0xc7fff,0xc8000-0xc8fff,0xc9000-0xc9fff,0xdc000-0xdffff,0xe0000-0xe7fff pnpid ORM0000 on isa0
                            Feb 5 11:25:06	kernel: sc0: <system console="">at flags 0x100 on isa0
                            Feb 5 11:25:06	kernel: sc0: VGA <16 virtual consoles, flags=0x300>
                            Feb 5 11:25:06	kernel: vga0: <generic isa="" vga="">at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
                            Feb 5 11:25:06	kernel: acpi_throttle0: <acpi cpu="" throttling="">on cpu0
                            Feb 5 11:25:06	kernel: Timecounter "TSC" frequency 2488273863 Hz quality 800
                            Feb 5 11:25:06	kernel: Timecounters tick every 10.000 msec
                            Feb 5 11:25:06	kernel: IPsec: Initialized Security Association Processing.
                            Feb 5 11:25:06	kernel: ad0: 20480MB <vmware virtual="" ide="" hard="" drive="" 00000001="">at ata0-master UDMA33
                            Feb 5 11:25:06	kernel: acd0: DVDR <vmware virtual="" ide="" cdrom="" drive="" 00000001="">at ata1-master UDMA33
                            Feb 5 11:25:06	kernel: Trying to mount root from ufs:/dev/ad0s1a
                            Feb 5 11:25:06	kernel: ad0: FAILURE - SETFEATURES 0x85 status=41 <ready,error>error=4 <aborted>Feb 5 11:25:07	dhclient: PREINIT
                            Feb 5 11:25:07	dhclient: Starting delete_old_states()
                            Feb 5 11:25:07	dhclient: Comparing IPs: Old: New:
                            Feb 5 11:25:07	dhclient: Comparing Routers: Old: New:
                            Feb 5 11:25:07	dhclient[6557]: DHCPREQUEST on em0 to 255.255.255.255 port 67
                            Feb 5 11:25:07	dhclient[6557]: DHCPACK from 192.168.86.254
                            Feb 5 11:25:07	dhclient: REBOOT
                            Feb 5 11:25:07	dhclient: Comparing IPs: Old: New: 192.168.86.132
                            Feb 5 11:25:07	dhclient: Comparing Routers: Old: New: 192.168.86.2
                            Feb 5 11:25:07	dhclient: Removing states through old gateway '' (new gateway '192.168.86.2')
                            Feb 5 11:25:07	dhclient: Starting add_new_address()
                            Feb 5 11:25:08	dhclient: ifconfig em0 inet 192.168.86.132 netmask 255.255.255.0 broadcast 192.168.86.255
                            Feb 5 11:25:08	dhclient: New IP Address (em0): 192.168.86.132
                            Feb 5 11:25:08	dhclient: New Subnet Mask (em0): 255.255.255.0
                            Feb 5 11:25:08	dhclient: New Broadcast Address (em0): 192.168.86.255
                            Feb 5 11:25:08	dhclient: New Routers (em0): 192.168.86.2
                            Feb 5 11:25:08	dhclient: Adding new routes to interface: em0
                            Feb 5 11:25:08	dhclient: /sbin/route add default 192.168.86.2
                            Feb 5 11:25:08	dhclient: Creating resolv.conf
                            Feb 5 11:25:08	dhclient[6557]: bound to 192.168.86.132 -- renewal in 900 seconds.
                            Feb 5 11:25:08	php: : Accept router advertisements on interface em0
                            Feb 5 11:25:08	dhcp6c[14467]: dhcp6_ctl_authinit: failed to open /usr/local/etc/dhcp6cctlkey: No such file or directory
                            Feb 5 11:25:08	dhcp6c[14467]: client6_init: failed initialize control message authentication
                            Feb 5 11:25:08	dhcp6c[14467]: client6_init: skip opening control port
                            Feb 5 11:25:08	check_reload_status: rc.newwanip starting em0
                            Feb 5 11:25:09	dhcp6c[14558]: client6_send: transmit failed: Can't assign requested address
                            Feb 5 11:25:11	php: : rc.newwanip: Informational is starting em0.
                            Feb 5 11:25:11	php: : rc.newwanip: on (IP address: 192.168.86.132) (interface: wan) (real interface: em0).
                            Feb 5 11:25:11	php: : ROUTING: setting default route to 83.145.208.254
                            Feb 5 11:25:11	php: : The command '/sbin/route change -inet default '83.145.208.254'' returned exit code '1', the output was 'route: writing to routing socket: Network is unreachable route: writing to routing socket: Network is unreachable change net default: gateway 83.145.208.254: Network is unreachable'
                            Feb 5 11:25:12	check_reload_status: Reloading filter
                            Feb 5 11:25:15	kernel: pflog0: promiscuous mode enabled
                            Feb 5 11:25:18	php: : Resyncing OpenVPN instances for interface WAN.
                            Feb 5 11:25:18	kernel: tun1: changing name to 'ovpns1'
                            Feb 5 11:25:18	kernel: ovpns1: link state changed to UP
                            Feb 5 11:25:18	check_reload_status: rc.newwanip starting ovpns1
                            Feb 5 11:25:20	php: : Resyncing OpenVPN instances.
                            Feb 5 11:25:20	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such file or directory.
                            Feb 5 11:25:20	kernel: ovpns1: link state changed to DOWN
                            Feb 5 11:25:20	kernel: ovpns1: link state changed to UP
                            Feb 5 11:25:21	php: : rc.newwanip: Informational is starting ovpns1.
                            Feb 5 11:25:21	php: : rc.newwanip: on (IP address: 192.168.37.201) (interface: ) (real interface: ovpns1).
                            Feb 5 11:25:21	php: : pfSense package system has detected an ip change -> ... Restarting packages.
                            Feb 5 11:25:21	check_reload_status: Starting packages
                            Feb 5 11:25:23	php: : ROUTING: setting default route to 83.145.208.254
                            Feb 5 11:25:23	php: : The command '/sbin/route change -inet default '83.145.208.254'' returned exit code '1', the output was 'route: writing to routing socket: Network is unreachable route: writing to routing socket: Network is unreachable change net default: gateway 83.145.208.254: Network is unreachable'
                            Feb 5 11:25:23	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such file or directory.
                            Feb 5 11:25:23	dhcpleases: kqueue error: unkown
                            Feb 5 11:25:23	check_reload_status: Updating all dyndns
                            Feb 5 11:25:24	php: : Restarting/Starting all packages.
                            Feb 5 11:25:26	check_reload_status: Restarting ipsec tunnels
                            Feb 5 11:25:27	php: : The command '/usr/local/etc/rc.d/radiusd.sh stop' returned exit code '1', the output was 'radiusd not running?'
                            Feb 5 11:25:28	php: : Creating rrd update script
                            Feb 5 11:25:28	php: : miniupnpd: Starting service on interface: lan
                            Feb 5 11:25:28	miniupnpd[71662]: HTTP listening on port 2189
                            Feb 5 11:25:28	miniupnpd[71662]: Listening for NAT-PMP traffic on port 5351
                            Feb 5 11:25:29	php: : Restarting/Starting all packages.
                            Feb 5 11:25:29	php: : The command '/usr/local/etc/rc.d/radiusd.sh stop' returned exit code '1', the output was 'radiusd not running?'
                            Feb 5 11:25:31	php: : The command '/usr/local/etc/rc.d/radiusd.sh stop' returned exit code '1', the output was 'radiusd not running?'
                            Feb 5 11:25:32	php: : The command '/usr/local/etc/rc.d/radiusd.sh stop' returned exit code '1', the output was 'radiusd not running?'
                            Feb 5 11:25:33	php: : The command '/usr/local/etc/rc.d/radiusd.sh stop' returned exit code '1', the output was 'radiusd not running?'
                            Feb 5 11:25:34	php: : The command '/usr/local/etc/rc.d/radiusd.sh stop' returned exit code '1', the output was 'radiusd not running?'
                            Feb 5 11:25:36	php: : The command '/usr/local/etc/rc.d/radiusd.sh stop' returned exit code '1', the output was 'radiusd not running?'
                            Feb 5 11:25:37	php: : The command '/usr/local/etc/rc.d/radiusd.sh stop' returned exit code '1', the output was 'radiusd not running?'
                            Feb 5 11:25:38	php: : The command '/usr/local/etc/rc.d/radiusd.sh stop' returned exit code '1', the output was 'radiusd not running?'
                            Feb 5 11:25:39	php: : The command '/usr/local/etc/rc.d/radiusd.sh stop' returned exit code '1', the output was 'radiusd not running?'
                            Feb 5 11:25:40	radiusd[47567]: rlm_sql (sql): Driver rlm_sql_mysql (module rlm_sql_mysql) loaded and linked
                            Feb 5 11:25:40	radiusd[47567]: rlm_sql (sql): Attempting to connect to radius@192.168.10.10:3306/radius
                            Feb 5 11:25:40	radiusd[47567]: rlm_sql (sql): Attempting to connect rlm_sql_mysql #0
                            Feb 5 11:25:40	radiusd[47567]: rlm_sql_mysql: Starting connect to MySQL server for #0
                            Feb 5 11:25:40	radiusd[47567]: rlm_sql (sql): Connected new DB handle, #0
                            Feb 5 11:25:40	radiusd[47567]: rlm_sql (sql): Attempting to connect rlm_sql_mysql #1
                            Feb 5 11:25:40	radiusd[47567]: rlm_sql_mysql: Starting connect to MySQL server for #1
                            Feb 5 11:25:40	php: : The command '/usr/local/etc/rc.d/radiusd.sh stop' returned exit code '1', the output was 'radiusd not running?'
                            Feb 5 11:25:41	php: : The command '/usr/local/etc/rc.d/radiusd.sh stop' returned exit code '1', the output was 'radiusd not running?'
                            Feb 5 11:25:43	radiusd[60380]: rlm_sql (sql): Driver rlm_sql_mysql (module rlm_sql_mysql) loaded and linked
                            Feb 5 11:25:43	radiusd[60380]: rlm_sql (sql): Attempting to connect to radius@192.168.10.10:3306/radius
                            Feb 5 11:25:43	radiusd[60380]: rlm_sql (sql): Attempting to connect rlm_sql_mysql #0
                            Feb 5 11:25:43	radiusd[60380]: rlm_sql_mysql: Starting connect to MySQL server for #0
                            Feb 5 11:25:43	php: : The command '/usr/local/etc/rc.d/radiusd.sh stop' returned exit code '1', the output was 'radiusd not running?'
                            Feb 5 11:25:44	php: : The command '/usr/local/etc/rc.d/radiusd.sh stop' returned exit code '1', the output was 'radiusd not running?'
                            Feb 5 11:25:45	php: : The command '/usr/local/etc/rc.d/radiusd.sh stop' returned exit code '1', the output was 'radiusd not running?'
                            Feb 5 11:25:46	radiusd[75792]: rlm_sql (sql): Driver rlm_sql_mysql (module rlm_sql_mysql) loaded and linked
                            Feb 5 11:25:46	radiusd[75792]: rlm_sql (sql): Attempting to connect to radius@192.168.10.10:3306/radius
                            Feb 5 11:25:46	radiusd[75792]: rlm_sql (sql): Attempting to connect rlm_sql_mysql #0
                            Feb 5 11:25:46	radiusd[75792]: rlm_sql_mysql: Starting connect to MySQL server for #0
                            Feb 5 11:25:46	radiusd[75792]: rlm_sql (sql): Connected new DB handle, #0
                            Feb 5 11:25:46	radiusd[75792]: rlm_sql (sql): Attempting to connect rlm_sql_mysql #1
                            Feb 5 11:25:46	radiusd[75792]: rlm_sql_mysql: Starting connect to MySQL server for #1
                            Feb 5 11:25:46	radiusd[75792]: rlm_sql (sql): Connected new DB handle, #1
                            Feb 5 11:25:46	radiusd[75792]: rlm_sql (sql): Attempting to connect rlm_sql_mysql #2
                            Feb 5 11:25:46	radiusd[75792]: rlm_sql_mysql: Starting connect to MySQL server for #2
                            Feb 5 11:25:46	radiusd[75792]: rlm_sql (sql): Connected new DB handle, #2
                            Feb 5 11:25:46	radiusd[75792]: rlm_sql (sql): Attempting to connect rlm_sql_mysql #3
                            Feb 5 11:25:46	radiusd[75792]: rlm_sql_mysql: Starting connect to MySQL server for #3
                            Feb 5 11:25:46	radiusd[75792]: rlm_sql (sql): Connected new DB handle, #3
                            Feb 5 11:25:46	radiusd[75792]: rlm_sql (sql): Attempting to connect rlm_sql_mysql #4
                            Feb 5 11:25:46	radiusd[75792]: rlm_sql_mysql: Starting connect to MySQL server for #4
                            Feb 5 11:25:46	radiusd[75792]: rlm_sql (sql): Connected new DB handle, #4
                            Feb 5 11:25:46	radiusd[75792]: Loaded virtual server <default>Feb 5 11:25:46	radiusd[76076]: Ready to process requests.
                            Feb 5 11:25:47	radiusd[76076]: Signalled to terminate
                            Feb 5 11:25:47	radiusd[76076]: Exiting normally.
                            Feb 5 11:25:47	radiusd[76076]: rlm_sql (sql): Closing sqlsocket 4
                            Feb 5 11:25:47	radiusd[76076]: rlm_sql (sql): Closing sqlsocket 3
                            Feb 5 11:25:47	radiusd[76076]: rlm_sql (sql): Closing sqlsocket 2
                            Feb 5 11:25:47	radiusd[76076]: rlm_sql (sql): Closing sqlsocket 1
                            Feb 5 11:25:47	radiusd[76076]: rlm_sql (sql): Closing sqlsocket 0
                            Feb 5 11:25:47	php: : The command '/usr/local/etc/rc.d/radiusd.sh stop' returned exit code '1', the output was 'radiusd not running?'
                            Feb 5 11:25:48	radiusd[84135]: rlm_sql (sql): Driver rlm_sql_mysql (module rlm_sql_mysql) loaded and linked
                            Feb 5 11:25:48	radiusd[84135]: rlm_sql (sql): Attempting to connect to radius@192.168.10.10:3306/radius
                            Feb 5 11:25:48	radiusd[84135]: rlm_sql (sql): Attempting to connect rlm_sql_mysql #0
                            Feb 5 11:25:48	radiusd[84135]: rlm_sql_mysql: Starting connect to MySQL server for #0
                            Feb 5 11:25:48	radiusd[84135]: rlm_sql (sql): Connected new DB handle, #0
                            Feb 5 11:25:48	radiusd[84135]: rlm_sql (sql): Attempting to connect rlm_sql_mysql #1
                            Feb 5 11:25:48	radiusd[84135]: rlm_sql_mysql: Starting connect to MySQL server for #1
                            Feb 5 11:25:48	radiusd[84135]: rlm_sql (sql): Connected new DB handle, #1
                            Feb 5 11:25:48	radiusd[84135]: rlm_sql (sql): Attempting to connect rlm_sql_mysql #2
                            Feb 5 11:25:48	radiusd[84135]: rlm_sql_mysql: Starting connect to MySQL server for #2
                            Feb 5 11:25:48	radiusd[84135]: rlm_sql (sql): Connected new DB handle, #2
                            Feb 5 11:25:48	radiusd[84135]: rlm_sql (sql): Attempting to connect rlm_sql_mysql #3
                            Feb 5 11:25:48	radiusd[84135]: rlm_sql_mysql: Starting connect to MySQL server for #3
                            Feb 5 11:25:48	radiusd[84135]: rlm_sql (sql): Connected new DB handle, #3
                            Feb 5 11:25:48	radiusd[84135]: rlm_sql (sql): Attempting to connect rlm_sql_mysql #4
                            Feb 5 11:25:48	radiusd[84135]: rlm_sql_mysql: Starting connect to MySQL server for #4
                            Feb 5 11:25:48	radiusd[84135]: rlm_sql (sql): Connected new DB handle, #4
                            Feb 5 11:25:48	radiusd[84135]: Loaded virtual server <default>Feb 5 11:25:48	radiusd[84242]: Ready to process requests.
                            Feb 5 11:25:52	login: login on ttyv0 as root
                            Feb 5 11:25:52	sshlockout[91168]: sshlockout/webConfigurator v3.0 starting up
                            Feb 5 11:40:47	dhclient[13939]: DHCPREQUEST on em0 to 192.168.86.254 port 67
                            Feb 5 11:40:47	dhclient[13939]: DHCPACK from 192.168.86.254
                            Feb 5 11:40:47	dhclient: RENEW
                            Feb 5 11:40:47	dhclient: Creating resolv.conf
                            Feb 5 11:40:47	dhclient[13939]: bound to 192.168.86.132 -- renewal in 900 seconds.
                            Feb 5 11:45:39	php: /diag_logs.php: Successful login for user 'admin' from: 192.168.10.118
                            Feb 5 11:48:59	check_reload_status: Syncing firewall
                            Feb 5 11:49:00	syslogd: exiting on signal 15
                            Feb 5 11:49:00	syslogd: kernel boot file is /boot/kernel/kernel
                            Feb 5 11:49:00	kernel: pflog0: promiscuous mode disabled</default></default></aborted></ready,error></vmware></vmware></acpi></generic></system></isa></floppy></parallel></printer></plip></parallel></parallel></ps></at></keyboard></at></ac></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></acpi></intel(r)></intel(r)></acpi></acpi></vga-compatible></bridge></ata></ata></intel></isa></pci-isa></acpi></acpi></acpi></acpi></acpi></intel></software></version></ptltd></lahf></nx,lm></sse3,ssse3,cx16,x2apic,hv></fpu,vme,de,pse,tsc,msr,pae,mce,cx8,apic,sep,mtrr,pge,mca,cmov,pat,pse36,dts,mmx,fxsr,sse,sse2,ss>
                              athurdent
                              Hmm, then you might be facing a different problem or my first entry is unrelated to remote syslogging. I always get:
                              • O Offline
                                Ocid
                                Yes, it's something diffrent, because now my test server is sending events to remote syslog.
                                Last events from this server before today were at 2013-01-25 10:55:43, so after that time I might have abused my test server too much…
                                • E Offline
                                  elgo
                                  I have the same problem with 2.1 (02 feb build).
                                  My syslog server is directly attached to a static NIC of the pfsense box, not using IPv6 but it's not globally disabled. WAN link is pppoe though, if that matter.
                                  After a fresh reboot of the pfsense box:
                                  • nothing on syslog server.
                                  • if I do some modification on the pfsense syslog parameters page and click on save, I get in remote syslog:
                                  Feb Ā 8 17:04:02 192.168.10.254 syslogd: restart
                                  Feb Ā 8 17:04:02 192.168.10.254 syslogd: kernel boot file is /boot/kernel/kernel
                                  Feb Ā 8 17:04:02 192.168.10.254 kernel: pflog0: promiscuous mode disabled
                                  Feb Ā 8 17:04:02 192.168.10.254 pf:
                                  • if I go into a shell on pfsense box, stop syslogd process and restart it, issue is fixed.
                                  Additionnal data:
                                  • Seeing the "syslogd: sendto: Network is unreachable" message in pfsense logs.
                                  • no package installed
                                  • Config:
                                  Ā  Ā  Ā  Ā  <syslog><nentries>50</nentries>
                                  Ā  Ā  Ā  Ā  Ā  Ā  Ā  Ā  <logall><remoteserver>192.168.10.1</remoteserver>
                                  Ā  Ā  Ā  Ā  Ā  Ā  Ā  Ā  <remoteserver2><remoteserver3><enable><reverse><nologdefaultblock></nologdefaultblock></reverse></enable></remoteserver3></remoteserver2></logall></syslog>
                                  • jimpJ Offline
                                    Try editing this file on your firewall and remove the if statement and closing bracket, so it just runs system_syslogd_start(); no matter what.
                                    See if that helps.
                                      athurdent
                                      Hi jimp,
                                      which file should we edit?
                                      • jimpJ Offline
                                        Whoops there should have been a link in there.
                                        http://redmine.pfsense.org/projects/pfsense/repository/revisions/25ed9cf8a4c1bd4155ee4e1881821b9e10501916/diff/etc/rc.bootup
                                          athurdent
                                          Fine, that works for me.
                                          • jimpJ Offline
                                            So that change fixes the problem?
                                            Or you're OK with testing the change?
