    IPv6 DHCP-PD – radvd dies after interface reset - dhcpv6 does not reaquire addr
    166 Posts 21 Posters 77.5k Views
      priller
      @BrianPlencner:
      I know why the service is gone, as it said it removed it!  Of course, why it got removed I have no idea.
      From what I have seen, radvd stops after the IPv6 addressing is lost due to the renewal problem carried on this bug:  http://redmine.pfsense.org/issues/2919
      I see radvd stopping as being "collateral damage".  It's not the initial trigger of the problem.
      • E Offline
        eri--
        Can any of you run dhcp6c with -d -D options to have the logging of what is happening and paste that here?
        That would explain what is happening here.
        The diff is something liek this
        diff --git a/etc/inc/interfaces.inc b/etc/inc/interfaces.inc
        index 9b97131..69aed12 100644
        --- a/etc/inc/interfaces.inc
        +++ b/etc/inc/interfaces.inc
        @@ -3483,7 +3483,7 @@ function interface_dhcpv6_configure($interface = "wan", $wancfg) {
                $rtsoldscript .= "if [ -f {$g['varrun_path']}/dhcp6c_{$wanif}.pid ]; then\n";
                $rtsoldscript .= "\t/bin/pkill -F {$g['varrun_path']}/dhcp6c_{$wanif}.pid\n";
                $rtsoldscript .= "fi\n";
        -       $rtsoldscript .= "/usr/local/sbin/dhcp6c -d -c {$g['varetc_path']}/dhcp6c_{$interface}.conf -p {$g['varrun_path']}/dhcp6c_{$wanif}.pid {$wanif}\n";
        +       $rtsoldscript .= "/usr/local/sbin/dhcp6c -d -D -c {$g['varetc_path']}/dhcp6c_{$interface}.conf -p {$g['varrun_path']}/dhcp6c_{$wanif}.pid {$wanif}\n";
                /* Add wide-dhcp6c shell script here. Because we can not pass a argument to it. */
                if (!@file_put_contents("{$g['varetc_path']}/rtsold_{$wanif}_script.sh", $rtsoldscript)) {
                        printf("Error: cannot open rtsold_{$interface}_script.sh in interface_dhcpv6_configure() for writing.\n");
          priller
          @ermal:
          Ugh, put pfSense back online and made that change.  Not even pulling an address now.
          dhcp6c[49192]: client6_init: skip opening control port
          dhcp6c[49192]: client6_init: failed initialize control message authentication
          dhcp6c[49192]: dhcp6_ctl_authinit: failed to open /usr/local/etc/dhcp6cctlkey: No such file or directory
          dhcp6c[83]: client6_send: transmit failed: Can't assign requested address
          Same behavior as another user was reporting:  http://www.broadbandreports.com/forum/r28333764-
          I only had a short window to work with this, will try again tonight or tomorrow.
            razzfazz
            Works fine here:
            root   30031  0.0  0.1  5780  1472  ??  INs   3:12PM   0:00.01 /usr/local/sbin/dhcp6c -d -D -c /var/etc/dhcp6c_wan.conf -p /var/run/dhcp6c_re0.pid re0
            As a side note, while preparing to make these edits, I noticed that I actually had two instances of dhcp6c running, with identical parameters and all. This is on a machine that was last rebooted earlier today, and before I had made any changes. I'm assuming that shouldn't normally happen?
              razzfazz
              Where does the additional logging go? /var/log/system.log?
                priller
                Ok, I'm up and running with the -D option now.
                I'm also seeing two instances:
                root  43632  0.0  0.0  5780  1448  ??  Is    7:21AM  0:00.00 /usr/local/sbin/dhcp6c -d -D -c /var/etc/dhcp6c_wan.conf -p
                root  43762  0.0  0.0  5780  1436  ??  INs  7:21AM  0:00.00 /usr/local/sbin/dhcp6c -d -D -c /var/etc/dhcp6c_wan.conf -p
                  priller
                  It only ran for about 50 minutes and then all IPv6 address was lost and radvd silently died.  The only thing in the logs is:
                  Jun 6 08:32:16 dhcp6c[43632]: client6_timo: all information to be updated was canceled
                  Jun 6 08:31:29 dhcp6c[43632]: client6_timo: all information to be updated was canceled
                  Jun 6 08:13:00 dhcp6c[43632]: client6_timo: all information to be updated was canceled
                  Jun 6 08:11:11 dhcp6c[43632]: client6_timo: all information to be updated was canceled
                  Jun 6 07:22:03 radvd[26213]: version 1.9.1 started
                  Jun 6 07:21:56 radvd[57345]: Exiting, failed to read config file.
                  Jun 6 07:21:56 radvd[57345]: error parsing or activating the config file: /var/etc/radvd.conf
                  Jun 6 07:21:56 radvd[57345]: syntax error in /var/etc/radvd.conf, line 2:
                  Jun 6 07:21:56 radvd[57345]: version 1.9.1 started
                  • johnpozJ Online
                    Part of the problem is that .conf is blank - i posted this before
                    [2.1-RC0][admin@pfsense.local.lan]/root(1): cat /var/etc/radvd.conf
                    Automatically Generated, do not edit
                    [2.1-RC0][admin@pfsense.local.lan]/root(2):
                      priller
                      @johnpoz:
                      Sure is.
                      I used to be able to pull IPv6 addressing and it would only go away after the lease expired after 4 days.  Something has made the problem much worse since the mid-May build I was running.
                      I've been trying repeatedly.  At times addressing will appear for a short time then go away.  Most of the time I can't get any IPv6 addressing.
                      radvd.conf is blank.
                      Jun 6 13:13:47 radvd[60869]: Exiting, failed to read config file.
                      Jun 6 13:13:47 radvd[60869]: error parsing or activating the config file: /var/etc/radvd.conf
                      Jun 6 13:13:47 radvd[60869]: syntax error in /var/etc/radvd.conf, line 2:
                      Jun 6 13:13:47 radvd[60869]: version 1.9.1 started
                      I have added the -D option ( /usr/local/sbin/dhcp6c -d -D -c ) and there is no additional output that I can find.
                      It's not a Comcast problem.  If I fire up m0n0wall or Mikrotik ROS, it works fine, all the time.
                      2.1-RC0 (amd64)
                      built on Thu Jun 6 09:07:25 EDT 2013
                      FreeBSD 8.3-RELEASE-p8
                      • johnpozJ Online
                        Yup same here - I fired up m0n0wall, bing bang zoom everything working for ipv6.  Now with pfsense if you do get an address its only there for a very short time.
                        I would think this should be a high priority issue - is there just something odd with the way comcast is going it that pfsense does not like?  Or is this an issue across the board with other native ipv6 providers?
                        But I have to say that ipv6 is currently broken in pfsense - at least with comcast as isp in chicagoland area.
                        edit:
                        Be more than happy to let someone in to my pfsense install to do any sort of troubleshooting they would like to do..  Just PM me and can setup access.
                        • jimpJ Offline
                          @johnpoz:
                          But I have to say that ipv6 is currently broken in pfsense.
                          DHCPv6+PD may be broken, but that is not true of "ipv6" in general. My ALIX has a completely different issue in that it refuses to get DHCPv6+PD at bootup, but if I edit/save/apply the WAN, it comes up and stays up indefinitely. It gets DHCPv6+PD from my "main" home router, though, not an ISP.
                          My main home router does IPv6 via HE.net tunnels and it works fine.
                          Do not Chat/PM for help!
                            maurer
                            @jimp:
                            same here - but my ISP is RCS & RDS Romania - one of the biggest IPv6 ISP and no.1 in Ro - nationwide availability
                            • dotOneD Offline
                              dotOne
                              Unfortunately, for me it's more or less the same.
                              But even the first offer is not accepted.
                              Normally the link local address is used to aquire a lease.
                              I have a virtual IPv6 address that is used by haproxy to hide multiple servers behind a single IPv6 address.
                              now the DHCP6 client uses this ip as the interface IP so every offer is rejected with a XID mismatch.
                              When I remove the virtual IP the initial lease is accepted but when the lease is expired the renew is denied.
                              /Andre
                                razzfazz
                                Interesting… I'm on Comcast, and my 2.1-RC0 box (June 4 snapshot) passed the four-day uptime mark today without losing IPv6 connectivity (and with rc.newwanip6 entries in the system log earlier today). Could this issue have been resolved?
                                • johnpozJ Online
                                  I am still having issues..  Maybe I will try a clean install?
                                  Just updated too
                                  2.1-RC0 (i386)
                                  built on Sun Jun 9 18:28:57 EDT 2013
                                  Jun 10 04:24:31 radvd[9391]: Exiting, failed to read config file.
                                  Jun 10 04:24:31 radvd[9391]: error parsing or activating the config file: /var/etc/radvd.conf
                                  Jun 10 04:24:31 radvd[9391]: syntax error in /var/etc/radvd.conf, line 2:
                                  Jun 10 04:24:31 radvd[9391]: version 1.9.1 started
                                  Jun 10 04:24:25 radvd[97175]: Exiting, failed to read config file.
                                  Jun 10 04:24:25 radvd[97175]: error parsing or activating the config file: /var/etc/radvd.conf
                                  Jun 10 04:24:25 radvd[97175]: syntax error in /var/etc/radvd.conf, line 2:
                                  Jun 10 04:24:25 radvd[97175]: version 1.9.1 started
                                  Jun 10 04:24:08 radvd[8125]: Exiting, failed to read config file.
                                  Jun 10 04:24:08 radvd[8125]: error parsing or activating the config file: /var/etc/radvd.conf
                                  Jun 10 04:24:08 radvd[8125]: syntax error in /var/etc/radvd.conf, line 2:
                                  Jun 10 04:24:08 radvd[8125]: version 1.9.1 started
                                  So I get a ipv6 global and link local on wan..  But not seeing anything on lan side..  I have tried resetting back to none none for wan and lan, then back to dhcp6 and track..  I have rebooted, etc.  Seems like some progress was having issues grabbing global ipv6 on the wan before, etc.
                                    netkeys
                                    I'm on Concast, and was unable to get it to work on beta versions.  I upgraded to the RC0 dated June 8 Saturday and it's been up and running since.  Hasn't been 4 days yet so I don't know if it will stick. Not sure if it's fixed but it's working for the 1st time.  I had been running M0n0wall because of the problems.
                                    @razzfazz:
                                    • E Offline
                                      eri--
                                      I have put some more fixes for radvd wrong config error.
                                      Please try a today snapshot.
                                        priller
                                        Nope.  I did a fresh install of …
                                        2.1-RC0 (amd64)
                                        built on Tue Jun 11 06:04:26 EDT 2013
                                        ...  The 1st time it booted, it successfully got IPv6 addressing.  I let it run a couple of hours and rebooted.  Now there is nothing I can do to get it to pull IPv6 addressing again.
                                        dhcp6c[68545]: dhcp6_ctl_authinit: failed to open /usr/local/etc/dhcp6cctlkey: No such file or directory
                                        dhcp6c[68545]: client6_init: failed initialize control message authentication
                                        dhcp6c[68545]: client6_init: skip opening control port
                                        Also, radvd doesn't even show up as a stopped service, it does not appear on the services screen.
                                          netkeys
                                          I tried the update from today and it broke the working IPv6.
                                            catfish99
                                            I'm on comcast service. Zoom Modem is IPv6 enabled. PFsense, well can't keep a ipv6 address.
                                            I'll stay at the latest beta that I have and update when there's a consensus that the IPv6 is working again.
