    Simple fan speed control for the Firebox X750e
    87 Posts 12 Posters 38.5k Views
      bmatic586
      @chpalmer:
      Where did you get your files?
      https://forum.pfsense.org/index.php/topic,66129.msg366219.html#msg366219
      yes… that's where I downloaded them from and put them in the directories as outlined below.
      Filename                                         Target Directory
      fanctrl.sh                                         /usr/local/etc/rc.d
      fanctrld.sh                                   /usr/local/sbin
      functions.inc.php                         /usr/local/www/includes
      system_information.widget.php   /usr/local/www/widgets/widgets
      WGXepc                                         /usr/local/bin
      I also did a chmod 0755 on fanctrl.sh, fanctrld.sh and WGXepc and then executed```
      /usr/local/etc/rc.d/fanctrl.sh
      Also, when I executed the above code, the LED that normally red, didn't turn green like it was supposed to as described in this thread.
      Thanks guys.
        bmatic586
        @bmatic586:
        @chpalmer:
        Thanks guys.
        Just an update… I rebooted the FW today and it's working the way it should now.
        Thanks for all the help.
        • chpalmerC Offline
          chpalmer
          @bmatic586:
          I was coming here to mention that I had to reboot when I installed, according to my notes.  Glad you got it working!  :)
            power_matz
            @Steve:
            Intel(R) Pentium(R) M processor 2.13GHz
            I don't have PowerD enabled though. That could well explain it. I should probably enable that as I'm sure the CPU will "wake up" to a higher power state quite quickly on demand.
            The temperature diode is part of the CPU die, not an external sensor.
            Hi Steve,
            have you enabled PowerD?
            I got an Intel Pentium M with 2.13 GHz and I enabled PowerD. But the display shows max speed of 1592 Mhz.
            Do you think this is incorrect and the speed is 2.13?
            Matthias
              Well that's obviously wrong somewhere.  ;)
              Did you switch both sets of jumpers? It looks like it's running a 400MHz FSB and should be 533MHz.
              Which model Pentium-M exactly did you fit?
              The 2.13GHz models are all 533MHz FSB and as such are not hard coded into the est(4) driver. I've not seen powerd work correctly with any 533MHz pentium-m. Usually it just doesn't start because there is no freq controlling driver loaded, there would be something in the logs to that effect.
                power_matz
                Hi Steve,
                I set one jumper array: two DIP switches changed like the picture shows. Is there's another DIP array?
                The speed is changing, so PowerD is doing something…
                Matthias
                  There are two sets of DIP switches, one set of two and another set of 4(?). The larger set are between the CPU and the PSU. Both must be switched.
                  Interesting that powerd is working, perhaps it has mistaken the CPU for one that it knows about. Be interesting to find out what happens when you set the second DIP switches.
                    power_matz
                    after changing the other jumpers accordingly everything runs like expected.  ;D
                    Damn, I've done this to my X750e some time ago. I couldn't remember….  :-[
                    Thanks a lot!
                    Matthias
                      Steve Evans
                      @bmatic586:
                      @stephenw10:
                      BB is the lowest speed you can run the fans where the speed sensors work. The fans can run much slower though.  The value is a two digit hexidecimal number so anything between 00 and FF. I wouldn't go below, say, 16 though.
                      If you're using the script it should be going lower than bb anyway.
                      when I ran
                      it didn't really slow down, and when I checked the fan speed by running WGXepc -f, it just said bb, so I manually set it to 20. Temp is not going above 50 C, but it would be nice to have it automatically control the fan instead of me manually configuring it.
                      Any other thoughts as to why it's not working?
                      Thanks again for your help.
                      The fanctrl.sh script should be passed an argument of either start or stop. Unfortunately I omitted the start in my original instructions. I can no longer edit that post. To save further confusion could a moderator please amend my post, reply #34, to state:
                      /usr/local/etc/rc.d/fanctrl.sh start
                      Thanks,
                        dwfa
                        I liked the idea of the script file to monitor the temps.  I think using cron to kick of a script to check the temps and react accordingly is also a good idea.  This will ensure the temps are always checked; default 1 min if you use default cron entries.  If the daemon script fails it may not restart; just my $0.02.  I added this to crontab
                        #crontab for root
                        # Format is
                        # min hour dayOfMonth month dayOfWeek command2Execute
                        # backup home every 3 days starting from the 1st @ 2:05 am
                        # the first of every 3rd month purge
                        # min hour dom month dow
                           *   *    *    *    *  /usr/local/bin/adjustFanSpeed.sh
                        use this command to edit the cron entries
                        crontab -e
                        The script I wrote looks like this
                        #! /bin/tcsh
                        set currentTemp = `/usr/local/bin/cpuTemp -t | sed '1,2d'`
                        if ( $currentTemp > 70 ) then
                          /usr/local/bin/fanspeed -f ff > /dev/null
                          /usr/local/bin/setLED -l red_flash > /dev/null
                          foreach indx (1 1 1 1 1)
                            /usr/local/bin/beep -p 500 50
                          end
                        else if ( $currentTemp > 65 ) then
                          /usr/local/bin/fanspeed -f ee > /dev/null
                          foreach indx (1 1 1 1)
                          end
                        else if ( $currentTemp > 60 ) then
                          /usr/local/bin/fanspeed -f dd > /dev/null
                          foreach indx (1 1 1)
                          end
                        else if ( $currentTemp > 55 ) then
                          /usr/local/bin/fanspeed -f bb > /dev/null
                        else if ( $currentTemp > 50 ) then
                          /usr/local/bin/fanspeed -f aa > /dev/null
                        else if ( $currentTemp > 45 ) then
                          /usr/local/bin/fanspeed -f 90 > /dev/null
                        else if ( $currentTemp > 40 ) then
                          /usr/local/bin/fanspeed -f 80 > /dev/null
                        else
                          /usr/local/bin/fanspeed -f 50 > /dev/null
                          /usr/local/bin/setLED -l off  > /dev/null
                        endif
                        fanspeed and cpuTemp are just links to WGXepc (thanks Stephen).
                          Steve Evans
                          My script hasn't failed yet and it provides proportional response. From a control theory perspective, much better. :)
                            power_matz
                            after some time the display of the temperate in the dashboard gets corrupted. Please see screen shot.
                            The fans are running at low speed. But the green LED is blinking. Any idea?
                            Matthias
                            ![Bildschirmfoto 2014-04-28 um 16.57.35.jpg_thumb](/public/imported_attachments/1/Bildschirmfoto 2014-04-28 um 16.57.35.jpg_thumb)
                            ![Bildschirmfoto 2014-04-28 um 16.57.35.jpg](/public/imported_attachments/1/Bildschirmfoto 2014-04-28 um 16.57.35.jpg)
                              Steve Evans
                              It's corrupted because the temperature is being read as 255 degC and the bar is only meant to be in the range 0 to 100. This, and the fact that the fan speed is not rising suggests a problem with WGXepc.
                                Indeed this was a problem with mbmon too. Interesting that it has taken this long for the error to occur. Any idea how long the script had been running before it defaulted to 255C? It may be possible to reset the SuperIO chip using some set of registers.
                                An alternative is the new BIOS from the SSL box has correct DSDT tables that pass the CPU temp via ACPI. If you're running B8.X then the temperature is reported by:
                                sysctl dev.cpu.0.temperature
                                I think. Something close to that anyway.  ;) Of course that is also just reading the superio chip so I don't know if that might be any better.
                                  Steve Evans
                                  Before the recent 2.1.1/2.1.2 upgrades my box had been up for 82 days and the fan control was still working OK.
                                    power_matz
                                    @stephenw10:
                                    This sysctl is not listed on my system…
                                    I am running the B8 version. My uptime is at this moment only 6 days.
                                    Matthias
                                      Hmm. Perhaps ACPI is not enabled in the BIOS by default or the setting carried over from a previous bios version. Check your bios setting.
                                      I'll have to check the default values but that's become a lot more difficult now that I no longer have a Win XP box to run modbin6 on.  ::)
                                        Steve Evans
                                        Virtual machine!
                                          power_matz
                                          I flashed Version 8.1 of the XEOS BIOS.
                                          Still no entry in sysctl for this.
                                          While booting pressing the TAB key doesn't bring me in the BIOS setup anymore.
                                          Should I reset BIOS setting (jumper)?
                                          Matthias
                                            If you flashed it using flashrom from within pfSense then the CMOS will not have cleared which could be causing an issue.
                                            I'm going to have review the changes I made. Fortunately it occurred to me the modbin6 is actually a DOS program so I should be able to fire up FreeDOS and run it.  ::)
