    Simple fan speed control for the Firebox X750e
    87 Posts 12 Posters 38.5k Views
      Steve Evans
      Mine's sat at the minimum as per the constants at the top of the /usr/local/sbin/fanctrld.sh script
      target=64
      min_temp=40
      gain=5
      delay=2
      min_fan=15
      thus:
      [2.1-RELEASE][root@pfsense]/root(8): /usr/local/bin/WGXepc -f
      Found Firebox X-E
      Fanspeed is f
      It does rise during activity.
      I'm nervous about setting min_fan any lower as I don't really want to stop the fans altogether.
        Steve Evans
        I should explain that min_fan setting. There are three fans in the box, two of which primarily cool the CPU, but both those and the third fan also exhaust warm air drawing cooler air over all the other components. I therefore thought it best to keep some airflow even when the CPU was below the target temperature on 64 degC. It doesn't take much airflow to provide noticeable cooling.
          Ah interesting, F is really quite slow.
          Does your script use decimal conversion, F=15?
            Steve Evans
            The lines that write the value do the conversion thus:
            # Adjust the fan speed
            /usr/local/bin/WGXepc -f `printf "%x\n" $fan` > /dev/null
            The machine isn't under much load most of the time, but even when doing big downloads it still runs quite cool. Accessing the web interface, most notably the RRD Graphs causes a speed up of the fans.
              Ah. I managed to mangle my hex and decimal values a few times when writing the WGXepc program (I'm no programmer!) with 'interesting' results.  ::)
              I was also concerned about cooling the rest of the box, the PSU seemed to run particularly hot. I measured it using a pyrometer since I'm pretty sure parts of it could kill you. The cooling provisions on the box in general don't seem that great especially if it's in a rack, I'd like to see some vents in the front panel to allow cool air in. I have my boxes set to fan speed 32, none have stopped working yet. It really is a shame they didn't spend the extra pennies required to put in a SuperIO chip that had auto fan control.
                power_matz
                Hi Steve,
                I installed your scripts and the modified toll from Steve with the temperatue option.
                After reboot I noticed that the fans slow down but after some time the temperature reads 35 C and the fans are up at speed FF.
                The fans are always running at this speed. I noticed no change here. What is wrong? I also tried the corrected call with the start option
                Matthias
                  power_matz
                  OK, found the error by myself. The min temperature is set to 40. Mine its 35. So the if-statement is not correct. I set the min temp to 30, now it is running!
                  Maybe it is a good idea to refactor the if statement…
                  Matthias
                    Steve Evans
                    Hi Matthias,
                    I saw your first post emailed to my phone and thought that looked like the script had taken the safety bailout. This is there to protect from erroneous temperature readings I'd been warned of, and too high a fan speed in the safe response to that.
                    Interesting that your box is running so cool. I've never seen mine below 50 degC. By the time its booted to the point the script starts the CPU is normally up to that kind of temperature.
                      power_matz
                      Hi Steve,
                      my box is in a network cabinet. There is not much space at the back for the air to come out (approx. 5 cm to the rear of the cabinet.
                      I am wondering myself why it is so cool! Now with your script it runs with speed f at temp 40 C.
                      It is ok, I think.
                      Bye
                      Matthias
                        What CPUs are you running? Is the cpu sensor touching the bottom 9f the CPU? I can't actually remember if it has a spring loaded sensor or not.  :-\
                          Steve Evans
                          Intel(R) Pentium(R) M processor 2.13GHz
                          I don't have PowerD enabled though. That could well explain it. I should probably enable that as I'm sure the CPU will "wake up" to a higher power state quite quickly on demand.
                          The temperature diode is part of the CPU die, not an external sensor.
                            Ah, in which case the diode values can vary between CPU models so the real temperature may be different.
                            I seem to remember reading that they are actually an offset from the CPU maximum temperature so you have allow for that. No idea if mbmon is doing that. I don't think it is because I just read out the register in WGXepc. If you read the docs for the superio chip there is quite a bit about configuring it for the correct sensor type.
                              power_matz
                              I am using an Intel(R) Pentium(R) M processor 1.70GHz with PowerD enabled.
                              Matthias
                                Steve Evans
                                That explains it then. I'm being power mad again! :D
                                An interesting comparison for anybody trying to build a lower power router then. I went for the more powerful option as I wanted to be future proofed should my broadband speed increase again, and also as I didn't know if I'd want to be using squid etc when I started.
                                  bmatic586
                                  @Steve:
                                  This has been working reliably for some time, so having just updated to 2.1 and re-applied this fix I though I might as well post a complete set of files.
                                  Rename the attachment to lose the .png suffix and decompress. You'll find the following files. Copy them to the directory shown. Ensure that the sh files and WGXepc are executable.
                                  | Filename | Target Directory |
                                  | fanctrl.sh | /usr/local/etc/rc.d |
                                  | fanctrld.sh | /usr/local/sbin |
                                  | functions.inc.php | /usr/local/www/includes |
                                  | system_information.widget.php | /usr/local/www/widgets/widgets |
                                  | WGXepc | /usr/local/bin |
                                  Start the fan control thus, or simply reboot:
                                  # /usr/local/etc/rc.d/fanctrl.sh
                                  You should hear the fans slow considerably. The daemon will try to maintain the set temperature of 64 degC. After some experimentation I found this to work well.
                                  Credit is due here to stephenw10 for the WGXepc utility. Note that he's produced a couple of versions, and you need this one as it reports temperature.
                                  The php scripts will read the CPU temperature and display it on the dashboard as the attached image.
                                  For us n00bs… :) can you tell us how to copy these files to the pfSense file system? how do you change the permissions?
                                  I guess I'm kind of looking for a step by step on how to do this. I just recently got a 1250e and it works great, but I'd like to quiet it down a bit and change the red LED.
                                  Thanks.
                                    One way of doing it is explained here:
                                    https://doc.pfsense.org/index.php/PfSense_on_Watchguard_Firebox#Controlling_hardware_with_WGXepc
                                    I've just noticed though that my Google site still has version 0.8 which doesn't read the temperature. I'll get that updated. (Edit: done)
                                    You can also use SCP to move files onto the pfSense box. I use WinSCP for that.
                                      bmatic586
                                      @stephenw10:
                                      Got it. I think it's working…  I can see the temperature now being displayed in the status screen.
                                      When I run WGXepc -f it shows me a value of bb... is that the lowest it'll go?
                                      Thanks again for your help.
                                      My temperature shows 45 deg. C.
                                        BB is the lowest speed you can run the fans where the speed sensors work. The fans can run much slower though.  The value is a two digit hexidecimal number so anything between 00 and FF. I wouldn't go below, say, 16 though.
                                        If you're using the script it should be going lower than bb anyway.
                                          bmatic586
                                          @stephenw10:
                                          when I ran
                                          it didn't really slow down, and when I checked the fan speed by running WGXepc -f, it just said bb, so I manually set it to 20. Temp is not going above 50 C, but it would be nice to have it automatically control the fan instead of me manually configuring it.
                                          Any other thoughts as to why it's not working?
                                          • chpalmerC Offline
                                            chpalmer
                                            Where did you get your files?
                                            https://forum.pfsense.org/index.php/topic,66129.msg366219.html#msg366219
