    Simple fan speed control for the Firebox X750e
    87 Posts 12 Posters 38.5k Views
      MacUsers
      And it does't work after the v2.2 upgrade. Does anyone have any update. The fan noise is driving me crazy. Best!
        power_matz
        I have a clean install of 2.2. After this I installed the fan speed control with latest version of all the dan stuff. It is working!
          MacUsers
          Well, intact I did a clean install as well. Could you send me the link to fan control that you have used. There a few I think. Best!
            power_matz
            Just the code from seven replies above: https://forum.pfsense.org/index.php?action=dlattach;topic=66129.0;attach=55565
            And of course the latest version of Stephens WGXep.
            And then I modified the min temp.
            Voila
            Matthias
              MacUsers
              Thanks Matt! It worked on the fresh 2.2 install. I can hear my heartbeats now  :D
                MacUsers
                I cannot auto-start that at boot though. This is where I have those files:
                [root@wg550 ~]# for ix in $(find / -name 'fanctrl*'); do ls -l ${ix}; done
                -rwxr-xr-x  1 root  wheel  1624 Apr 24 16:15 /usr/local/sbin/fanctrld
                -rwxr-xr-x  1 root  wheel  339 Apr 24 13:45 /etc/rc.d/fanctrld.sh
                [root@wg550 ~]# ls -l $(which WGXepc)
                -rwxr-xr-x  1 root  wheel  13762 Nov 28 12:51 /usr/local/bin/WGXepc
                and fanctrld is enabled in the rc.conf.local:
                [root@wg550 ~]# grep fan /etc/rc.conf.local
                fanctrld_enable="YES"
                What am I still missing? I can start fan-control manually though. Any one can help please? Best!
                  MacUsers
                  Sorry guys, found the problem: fanctrld.sh should be in "/usr/local/etc/rc.d/" not in /etc/rc.d. Working fine now.
