    Multi Gateway same interface
    21 Posts 4 Posters 5.3k Views 3 Watching
      If you want to keep using the resolver, Unbound, you can switch that to forwarding mode instead. That allows you to use DNDBL for example.
      Or in 2.4.4+ you can set a failover gateway group as the default gateway (cannot be a load-balancing group) and keep using Unbound in resolving mode.
