    Notification: UPS ups battery is low
    Scheduled Pinned Locked Moved UPS Tools
    22 Posts 3 Posters 6.2k Views 4 Watching
    • F Offline
      fjmp24
      I receive the notification "UPS ups battery is low" and I don't understand why.
      I changed the battery without success.
      I changed UPS (EATON ELLIPSE PRO 850) to a more powerful one without success.
      Do you have an idea ? Sorry I'm newbie Thanks.
      My UPS status:
      Summary status = On line
      Runtime (H:M:S) = 0:36:47
      UPS Load = 13%
      Battery charge = 100%
      Input voltage = 225.0
      Input frequency =50.0
      My UPS details:
      battery.charge = 100
      battery.charge.low = 20
      battery.runtime = 2207
      battery.runtime.low = 1200
      battery.runtime.warn = 1800
      battery.type = PbAc
      device.mfr = EATON
      device.mode = Ellipse PRO 850
      device.serial = G357P05206
      device.type = ups
      driver.debug = 0
      driver.flag.allow_killpower = 0
      driver.flag.ignorelb = enabled
      driver.name = usbhid-ups
      driver.parameter.override.battery.runtime.low = 1200
      driver.parameter.override.battery.runtime.warn = 1800
      driver.parameter.override.ups.delay.shutdown = 600
      driver.parameter.pollfreq = 30
      driver.parameter.pollinterval = 2
      driver.parameter.port = auto
      driver.parameter.synchronous = auto
      driver.state = updateinfo
      driver.version = 2.8.0.1
      driver.version.data = MGE HID 1.46
      driver.version.internal = 0.52
      driver.version.usb = libusb-1.0.0 (API: 0x1000102)
      input.frequency = 50.0
      input.transfer.high = 285
      input.transfer.low = 165
      input.voltage = 225.0
      input.voltage.extended = no
      outlet.1.desc = PowerShare Outlet 1
      outlet.1.id = 2
      outlet.1.status = on
      outlet.1.switchable = no
      outlet.2.desc = PowerShare Outlet 2
      outlet.2.id = 3
      outlet.2.status = on
      outlet.2.switchable = no
      outlet.desc = Main Outlet
      outlet.id = 1
      outlet.switchable = no
      output.frequency = 50.0
      output.frequency.nominal = 50
      output.voltage = 227.0
      output.voltage.nominal = 230
      ups.beeper.status = enabled
      ups.delay.start = 30
      ups.firmware = 01.18.0022
      ups.load = 13
      ups.mfr = EATON
      ups.model = Ellipse PRO 850
      ups.power = 98
      ups.power.nominal = 850
      ups.productid = ffff
      ups.realpower = 73
      ups.serial = G357P05206
      ups.status = OL
      ups.timer.shutdown = -1
      ups.timer.start = -1
      ups.vendorid = 0463
      My UPS Extra Arguments to driver
      ignorelb
      With the EATON ELLIPSE PRO 850, I have less notification.
      The UPS powers a Synoloy NAS and a PC (I7)
      My UPS load graphic:
      My UPS time left graphic:
      F dennypageD 2 Replies Last reply Reply Quote 0
      • F Offline
        fjmp24 @fjmp24
        Nobody have an idea ?
        • dennypageD Offline
          dennypage @fjmp24
          @fjmp24 said in Notification: UPS ups battery is low:
          You indicated that you have 3 systems powered by the UPS, however your post does not include the notification that you are referring to, nor any information about the circumstance when the notification occurs or which system it originates from.
          Btw, unless you are trying to address a very specific problem, you should not have the items in the "Extra Arguments to driver" section. Specifically, setting "ignorelb" and specifying runtimes is almost always a mistake, although a commonly made one. Likely the only one that should be there is the shutdown delay, but that only if you need more than 20 seconds to completely a shutdown on one of the systems. My expectation is that would probably only apply if you are running the Synology as a remote client to pfSense.
          F 2 Replies Last reply Reply Quote 0
          • F Offline
            fjmp24 @dennypage
            • F Offline
              fjmp24 @dennypage
              @dennypage Thanks I deleted override.battery.runtime.low and override.battery.runtime.warn and I don't receive notifications anymore. But I have another questions.
              1. When I cut power to my NUT, pfsense sends a shutdown when my NUT have :
              • runtime is equal to 0:01:41
              • battery charge is equal to 19%
                Why doesn't it send the message when runtime is equal to 0:05:00 ? I set override.ups.delay.shutdown = 300
              1. Once my devices have been shutdown, the NUT runs for about 1 minute and displays the runtime. Then it doesn't display runtime and works about 0:02:49. I don't understand how it works.An idea ?
              Below my configuration:
              battery.charge	9
              battery.charge.low	20
              battery.runtime	355
              battery.type	PbAc
              device.mfr	EATON
              device.model	Ellipse PRO 650
              device.serial	P354L18GBN
              device.type	ups
              driver.debug	0
              driver.flag.allow_killpower	0
              driver.flag.ignorelb	enabled
              driver.name	usbhid-ups
              driver.parameter.override.ups.delay.shutdown	300
              driver.parameter.pollfreq	30
              driver.parameter.pollinterval	2
              driver.parameter.port	auto
              driver.parameter.synchronous	auto
              driver.state	quiet
              driver.version	2.8.0.1
              driver.version.data	MGE HID 1.46
              driver.version.internal	0.52
              driver.version.usb	libusb-1.0.0 (API: 0x1000102)
              input.frequency	50.0
              input.transfer.high	285
              input.transfer.low	165
              input.voltage	225.0
              input.voltage.extended	no
              outlet.1.desc	PowerShare Outlet 1
              outlet.1.id	2
              outlet.1.status	on
              outlet.1.switchable	no
              outlet.2.desc	PowerShare Outlet 2
              outlet.2.id	3
              outlet.2.status	on
              outlet.2.switchable	no
              outlet.desc	Main Outlet
              outlet.id	1
              outlet.switchable	no
              output.frequency	50.0
              output.frequency.nominal	50
              output.voltage	227.0
              output.voltage.nominal	230
              ups.beeper.status	enabled
              ups.delay.start	30
              ups.firmware	01.16.0020
              ups.load	7
              ups.mfr	EATON
              ups.model	Ellipse PRO 650
              ups.power	49
              ups.power.nominal	650
              ups.productid	ffff
              ups.realpower	18
              ups.serial	P354L18GBN
              ups.status	OL LB
              ups.timer.shutdown	-1
              ups.timer.start	-1
              ups.vendorid	0463
              Thank you for your help and sorry for my newbie's questions.
                dennypage @fjmp24
                NUT initiates a shutdown when the UPS declares that the battery is low (LB). The decision regarding a low battery is made by the UPS itself. Some UPSs have configurable LB levels, and some have fixed LB levels. If your UPS has a configurable LB level, this is configured by the battery.charge.low variable. 20% is a common default.
                When performing a shutdown, one of the last steps is for the OS (pfSense) to instruction the UPS to cut the power. After receiving that command, the UPS waits a short period of time before it actually turns off the power. The purpose of this delay is to allow the OS to complete its shutdown before power is cut. Some UPSs have configurable delays, and some have fixed delays. If your UPS has a configurable delay, this is configured by the ups.delay.shutdown variable. 20 seconds is a common default.
                • stephenw10S stephenw10 moved this topic from pfSense Packages on
                • F Offline
                  fjmp24 @dennypage
                  @dennypage Thank you for your help
                  • F Offline
                    fjmp24 @fjmp24
                    I did a test to see if my UPS is working properly. I could see that it wasn't :-(
                    The UPS cuts the power very quickly (about 1 minute), which means, for example, my NAS doesn't have time to shut down properly.
                    My setup was working before. I updated pfSense. The problem might be coming from there.
                    UPS Detail
                    Variable 	Value
                    battery.charge	100
                    battery.runtime	1417
                    battery.type	PbAc
                    device.mfr	EATON
                    device.type	ups
                    driver.debug	0
                    driver.parameter.override.ups.delay.shutdown	90
                    driver.state	updateinfo
                    driver.version	2.8.2
                    driver.version.internal	0.53
                    input.voltage	229.0
                    outlet.1.id	2
                    outlet.1.status	on
                    outlet.2.id	3
                    outlet.2.status	on
                    outlet.id	1
                    output.voltage	230.0
                    ups.delay.start	30
                    ups.load	19
                    ups.mfr	EATON
                    ups.power	114
                    ups.productid	ffff
                    ups.realpower	76
                    ups.status	OL
                    ups.timer.start	-1
                    ups.vendorid	0463
                    ignorelb
                    override.ups.delay.shutdown = 90
                      dennypage @fjmp24
                      @fjmp24 How old is the battery? Have you done a calibration test?
                      • F Offline
                        fjmp24 @dennypage
                        @dennypage I changed the battery this year. I don't understand : "Have you done a calibration test" ?
                          dennypage @fjmp24
                          Most UPSs have a "battery calibration test", "runtime calibration test", etc. You are looking for a test that runs the load off of the battery (without cutting mains) to see how the battery behaves under actual load.
                          Btw, you should remove the ignorelb directive from the Extra Arguments to driver section. Unless you have a very old UPS that signals low battery whenever the UPS is on battery. You almost certainly do not have such a UPS.
                          • F Offline
                            fjmp24 @dennypage
                            @dennypage My UPD indicate runtime: 18:21
                              dennypage @fjmp24
                              Yes, but that may be completely inaccurate, especially with bad batteries. That's why you run a calibration test.
                              • F Offline
                                fjmp24 @dennypage
                                @dennypage I can't run the test. But there's an automated system that does it every week. I tested it without override.ups.delay.shutdown. My UPS shuts down after 30 seconds, compared to 1 minute with the override.ups.delay.shutdown.
                                I don't understand anything :-((
                                  dennypage @fjmp24
                                  I didn't say you should remove the override.ups.delay.shutdown directive, I said you should remove the ignorelb directive.
                                  Also, you do not have anything in the Advanced settings section, correct?
                                  As to running a calibration test, consult your UPS manual or support from the manufacturer of your UPS.
                                  • F Offline
                                    fjmp24 @dennypage
                                    Ok, I will test without ignorelb directive.
                                    Yes
                                    I find anything I will search tomorow
                                    • F Offline
                                      fjmp24 @fjmp24
                                      If I remove ignorelb directive, my UPS shuts down after 16 seconds
                                      • F Offline
                                        fjmp24 @fjmp24
                                        My UPD do an automatic battery test regularly to warn when a replacement of the current battery needs to be carried out.
                                          dennypage @fjmp24
                                          This means your UPS is signaling a low battery. Either your battery is bad, or your UPS is bad. Most likely battery, but you never know. I suggest reaching out to Eaton support.
                                          F 1 Reply Last reply Reply Quote 1
                                          • F Offline
                                            fjmp24 @dennypage
                                            @dennypage I tested it with a new UPS and I no longer have the problem. It was the UPS that wasn't working properly.
                                            Thanks for your help.
                                            dennypageD 1 Reply Last reply Reply Quote 1
