• Running NUT drivers with debugging
    Pinned
  • USB quirks and NUT
    Pinned
    5 Votes
    6k Views
    @dennypage ah that’s probably the case then. Thank you!
  • Remote access to NUT
    Pinned
    2 Votes
    7k Views
    N
    I am aware this topic is old - I do have such an implementaitons. I have several UPS's and have a container app that clubs all the UPS and shows them in one dash board in my local server. I then use cloudflare to view this dashboard using ups.mydomain.com - [image: ee31d9bf-fe6c-4f08-91bf-2f65b7df0aff-CleanShot 2025-12-29 at 18.25.33.png] [image: f5f41f86-3298-4336-9cfd-db187b4a1d19-CleanShot 2025-12-29 at 18.25.57.png]
  • Cyberpower UPS event log?
    dennypageD
    @pulsartiger It's difficult to provide a definitive answer since I don't know the UPS model and what it considers an "event", but most Cyber Power units are supported by NUT and the NUT package provides logging and notifications. The simplest way to find out for sure is to hook it up and try it.
  • Advanced conf in clinet mode
    dennypageD
    @Urbaman75 Taking shutdown actions based on OB is almost always a bad idea, especially with remote server/client. Just let NUT and the UPS manage things as intended based on LB.
  • UPS ups on battery - appers often now
    22
    N
    @dennypage said in UPS ups on battery - appers often now: I have no idea. The information that has been provided is insufficient for me to offer any conclusion. fair enough - i am going to get rid of UPS and buy power station with UPS functionality
    dennypageD
    @DomV said in NUT server - After power is turned back on, pfsense shut's down sockets without warning for no reason: Because I think that this is the default value for this UPS. And I still really don't understand why with the pi it works correctly even with this setting. The default for low battery on APC UPSs is 10%. 97% would not make sense to use as a default setting on any UPS. As to the Pi, there are any number of configuration reasons that would result in a change of behavior. If you want to explore that further, I recommend the NUT Users mailing list.
  • NUT and Goldenmate UPS
    dennypageD
    @moosport said in NUT and Goldenmate UPS: Thank you @dennypage ! Welcome
  • pfSense 2.8.1, NUT 2.8.2_5 package, EcoFlow UPS
    dennypageD
    @Rahzadan said in pfSense 2.8.1, NUT 2.8.2_5 package, EcoFlow UPS: Is there a way to upgrade NUT to a newer version in pfSense? I expect it will be updated in the next pfSense release cycle.
  • Notification: UPS ups battery is low
    9k Views
    @dennypage Nicely done sir!
  • Docker container for nut server?
    17
    6k Views
    Well I got my synology to be monitored. But not having any luck getting win-nut working on my windows machine.. I found a later version that suppose to work 2.8.4, and it finds my ups via nut-scanner.. But can't seem to get it to run, says no listening interface, etc. etc.. I think just going to throw some money at it, I can get the personal panel version to show up in cloud, so just going to their cloud card, found on amazon for 68$ Their cloud interface is not horrible - and the cost is like 10$ a year for lic per ups, and if you buy a card you can get 3 year lic for 1 card.. The only unit I have that doesn't support the cloud card is the one behind my tv. But that is one I have linux working on, and can use cyberpowers software vs nut to connect it to the cloud. found a slick little docker, @netboy looks a bit more what I would like.. But - just going throw some money at vs dicking with the windows machine and nut. And just put them all up on the cloud. https://github.com/Brandawg93/PeaNUT
  • NUT fails to start after 2.7.2 -> 2.8.0 upgrade
    8k Views
    dennypageD
    @jhg said in NUT fails to start after 2.7.2 -> 2.8.0 upgrade: Interesting. I would have thought the initial reboot, which occurred as part of the upgrade, would have done the trick, but it took a second reboot, just now, to get things working. Glad you have it sorted. There was no difference in the output of usbconfig show_ifdrv at any point -- before or after unplugging/replugging the USB cable, nor after rebooting. ... Question: What would tell me whether or not a driver was loaded? If there were an attached driver, it should have shown up with the show_ifdrv command. If you use the command and look at the other usb devices, I think they will show attached drivers. I don't expect to see a driver attached to the ups, because there is a quirk that tells the OS to ignore that device (and not attach a driver). Look for idVendor and idProduct in the above output. The Vendor ID for your device is 0764, which corresponds to Cyber Power Systems, and the Product ID for your device is 0601, which is registered as "PR1500LCDRT2U UPS" (don't sweat an exact match for the name). You can see the quirk with the following command: [25.07-RC][root@fw]/root: usbconfig dump_device_quirks | grep 0764 VID=0x0764 PID=0x0005 REVLO=0x0000 REVHI=0xffff QUIRK=UQ_HID_IGNORE VID=0x0764 PID=0x0501 REVLO=0x0000 REVHI=0xffff QUIRK=UQ_HID_IGNORE VID=0x0764 PID=0x0601 REVLO=0x0000 REVHI=0xffff QUIRK=UQ_HID_IGNORE [25.07-RC][root@fw]/root: Your device is third on the list. The HID_IGNORE quirk says to ignore the device and not attach a driver. @jhg said in NUT fails to start after 2.7.2 -> 2.8.0 upgrade: You might consider adding this resolution to the release notes for 2.8. LOL... sorry, I don't have input to the release notes (I don't work here). While I wrote and maintain various packages, including NUT, I'm still just a volunteer. Most packages are actually written by volunteers.
  • Advanced Settings for Client to attach
    K
    @provels Thanks for your reply and help. I'm now able to have unraid connect to the NUT server.
  • pfSense NUT Client-Mode
    K
    @elvisimprsntr thanks for your suggestion. I will give it a try.
  • NUT suddenly stops working every app. 6 minutes
    46
    18k Views
    @dennypage said in NUT suddenly stops working every app. 6 minutes: Okay, that is entertaining to say the least. Does "66da6bc012db26058161" happen to be the locally generated password for local-monitor? I have not the slightest idea! Never seen this before!!!! Rest: Will be delighted to do so! Thanks for the instructions.
  • apcupsd causes restart
    @viragomann Yes it definitely is rebooting, but not immediately. I was able to try it 3 more times before putty quit responding. Here is what shows in putty... Select function number: 10 This test instructs the UPS to perform a battery calibration operation and reports the result when the process completes. The battery level must be at 100% and the load must be at least 10% to begin this test. Battery level is 100% -- OK Load level is 14% -- OK Clearing previous self test result...CLEARED The battery calibration should automatically end when the battery level drops below about 25%. This process can take minutes or hours, depending on the size of your UPS and the load attached. Initiating battery calibration...INITIATED Waiting for calibration to complete... To abort the calibration, press ENTER. CALIBRATION COMPLETED Result of last self test: ABORTED Test kill UPS power Perform self-test Read last self-test result View/Change battery date View manufacturing date View/Change alarm behavior View/Change sensitivity View/Change low transfer voltage View/Change high transfer voltage Perform battery calibration Test alarm View/Change self-test interval Q) Quit Select function number: 10 This test instructs the UPS to perform a battery calibration operation and reports the result when the process completes. The battery level must be at 100% and the load must be at least 10% to begin this test. Battery level 99% is insufficient to run test. Test kill UPS power Perform self-test Read last self-test result View/Change battery date View manufacturing date View/Change alarm behavior View/Change sensitivity View/Change low transfer voltage View/Change high transfer voltage Perform battery calibration Test alarm View/Change self-test interval Q) Quit Select function number: 10 This test instructs the UPS to perform a battery calibration operation and reports the result when the process completes. The battery level must be at 100% and the load must be at least 10% to begin this test. Battery level 99% is insufficient to run test. Test kill UPS power Perform self-test Read last self-test result View/Change battery date View manufacturing date View/Change alarm behavior View/Change sensitivity View/Change low transfer voltage View/Change high transfer voltage Perform battery calibration Test alarm View/Change self-test interval Q) Quit Select function number: 10 This test instructs the UPS to perform a battery calibration operation and reports the result when the process completes. The battery level must be at 100% and the load must be at least 10% to begin this test.
  • Issues after upgrade to 2.8.0
    dennypageD
    @JonesTech I recommend removing all the excess config you have put in. There are far too many copy/paste magic recipes for NUT on the internet that mislead people. The best approach with NUT is to start with the default configuration, and let NUT and your UPS take care of business as designed. You should only add directives to NUT if you are doing so to address a specific problem, and even then be very minimalist. And with every OS or NUT upgrade, you should retest/reconfirm that the directives are actually still necessary. ignorelb, while commonly recommended on the internet in various recipes derived from 10 or 15+ year old information, is almost always a very bad idea. It should ONLY be used if you have one of those very unfortunate old UPSs that declare Low Battery immediately on mains fail. On a modern UPS, you simply don't want to ignore the UPS saying "Hey, the battery is low, I'm about to shut down..." interruptonly is not pertinent to the initial connection of the driver, and should only be done if necessary to address constant disconnects with your UPS. Usually this is used to work around bugs in the USB or driver layer. If you do need to put this in, you should retest this with every OS or NUT upgrade to see if it is still required. Increasing pollinterval will make it longer before the system knows you are on battery. Almost certainly not what you want. override.battery.charge.warning has no meaning with the pfSense configuration. override.battery.charge.low will cause NUT to initiate a shutdown even though you have over a third of your run-time remaining. While this is a meaningful directive, are you sure this is what you want? And are you sure your UPS will work correctly this case?
  • SNMP UPS inconsistent connection
    GertjanG
    @Laxarus said in SNMP UPS inconsistent connection: DNS failure is one of the suspects No need to keep the "suspect" waiting, as you can consult the proof right away. Go here : Status > System Logs > System > DNS Resolver and see if you can find : [image: 59c728e4-a985-4222-b07d-e0d394cb1ebb-image.png] If you find them, match the related time stamp info with the NUT UPS events (main system log). If they match, and it happens to often, get yourself this mission : Figure out why unbound restarts, then evaluate the conditions that made it restart. The final goal is (always) : make DNS as accessible as possible. For example : a default, "clean" pfSense install won't restart unbound for days, even weeks. Start plugging in and moving network cables into pfSense, or power down and power up devices attached to pfSense directly by cable, and every time packages get restarted. Install pfBlockerng and according its settings it can restart unbound many time per day. Depending how you use pfSense, what you've installed extra can make live hard for your DNS ... for yourself. Your mission as an admin : find the right balance.
  • ups shutdown pfsense after 30 seconds
    dennypageD
    @firefox said in ups shutdown pfsense after 30 seconds: Could this be an incorrect setting in the SNMP card's graphical interface? I took the SNMP card from another UPS that is from the same manufacturer as my UPS. this is the model of my ups AON1500-2 this is the model of the ups i took the card from top v pro 6 When I connected the snmp card to the ups it seemed to recognize that it was a different ups I assume this is the same UPS as you were asking about last December? I do not have familiarity with that UPS manufacturer, so I really can't answer your question. You can either reach out to the manufacturer and ask them about NUT SNMP support for their UPSs, or go down the path of learning about SNMP and diagnose the issue yourself. Unless you happen to find someone with the exact same UPS and SNMP card, already working with NUT, this is going to require some effort. FWIW, the odds are that either the SNMP driver is incorrect, or the MIB is incorrect. For me, the first step would be to learn about the available MIBs, and begin exploring the SNMP interface with snmpwalk.
  • NUT Package (2.8.1 and above)
    Locked Moved
    296
    5 Votes
    395k Views
    dennypageD
    There is now a UPS Tools section, so I ask everyone to use problem specific threads rather than continuing this thread. Thank you.
