    ONLINE LOW BATTERY message
    Scheduled Pinned Locked Moved UPS Tools
    29 Posts 5 Posters 7.8k Views 5 Watching
    • w0wW Offline
      w0w @netboy
      @netboy
      It's the same for the back series UPS.
        netboy @w0w
        @w0w Ok shall try it
          netboy @netboy
          @netboy The procedure did not work
          w0wW 1 Reply Last reply Reply Quote 0
          • w0wW Offline
            w0w @netboy
            @netboy
            Do the 16hrs already have been passed?
            If yes then you should try what @provels recommended to do.
              netboy @w0w
              @w0w No... that is my next milestone
              N T 2 Replies Last reply Reply Quote 0
                netboy @netboy
                @dennypage This is what worked for APC battery ES 750G FYI
                • Installed powerchute software in windows machine. Connected the APC
                • Ran self test
                • Changed battery date (battery date not possible to change using NUT command line upsrw)
                dennypageD 1 Reply Last reply Reply Quote 3
                  tedquade @netboy
                  @netboy Your UPS battery fun caused me to take a look at the array of UPS devices I have and found the unit on my wife computer had a dodgy battery (aborted self test). Installed new battery and it now passes.
                  I have two others that I still need to dig into.
                  Thanks for prompting me to look at my own stuff!
                  Ted
                    netboy @tedquade
                    @tedquade said in ONLINE LOW BATTERY message:
                    Ted
                    I wanted to document my experience so that it will help others if they encounter similar problems. Many folks in this forum helped me a lot and I am very thankful.
                    • dennypageD Offline
                      dennypage @netboy
                      @netboy Glad you got it sorted.
