    Netgate XG-7100-DT PWD LED remains red
    27 Posts 5 Posters 3.1k Views 5 Watching
      stephenw10 Netgate Administrator @andrew_cb
      @andrew_cb said in Netgate XG-7100-DT PWD LED remains red:
      Talk is cheap... Shall we make this interesting?
      200 internet points says the eMMC has failed.
      Ha, well I'd love to know for sure. I'm good for those points. 😉
      But as long as the fan controller has power the fan should always come on initially at full speed. One thing we have seen on the 7100 is a failed fan controller. Hence my recommendation to try the other fan socket. That's a pretty long shot though.
      • E Offline
        Expletive1500 @stephenw10
        Hello, thank you all for your continued input, I just tried the other fan controller however the fan does still not spin up.
        @andrew_cb @w0w
        The plan is to try and get the eMMC removed as the unit is headed for the scrap pile anyways, so there's no harm in trying.
        I'll update the thread with the results if I manage to get it removed.
        E 1 Reply Last reply Reply Quote 2
        • E Offline
          Expletive1500 @Expletive1500
          Hello, @w0w @andrew_cb @stephenw10
          I managed to remove the eMMC chip using a heatgun (I did try a hairdryer cause YOLO but not nearly enough power 😆). However the appliance is unfortunately still refusing to power on, the PWR LED still remains red.
          So I guess it's destined for the scrap heap now unless anyone has other suggestions? (sacrificing a goat in the name of Netgate?)
          So 200 internet points goes to @stephenw10 :)
            Feels like a hollow victory. 😶
              marcosm Netgate
              Have you tried a different power supply? I've had similar issues with other appliances which were fixed with a new power supply.
              E 1 Reply Last reply Reply Quote 1
                Mmm, it's an external power brick on the DT but I guess it could be low output.
                • E Offline
                  Expletive1500 @marcosm
                  @marcosm @stephenw10
                  Yes, I tried a power brick with a similar power rating as an initial troubleshooting step.
