    4100/6100 Base or Max
    81 Posts 10 Posters 27.2k Views 10 Watching
      Stef93 @Cabledude
      @Cabledude
      4-6s
        Cabledude @Stef93
        @Stef93 thank you. Then my 11 seconds is likely to be considered normal for the much lesser specc'ed CPU of the SG-2100.
        Still curious that your 6100 takes 4-6 seconds where my friend's 4100 takes only 2 seconds. His widget list is:
        • System Information, pfBlockerNG, Gateways, Interfaces, Services Status and Traffic Graphs
        Good chance your 6100 has more widgets or some other kind that waits for info to load ("spinning")
        Pete
        Home: SG-2100 + UniFi + Synology. SG-1100 retired
        Parents: SG-1100 + UniFi + Synology
        Testing: SG-1100 w/ 120GB SSD via ext USB (eMMC dead). Works great
          Stef93 @Cabledude
          @Cabledude
          System Information, pfBlockerNG, Gateways, Interfaces, Services Status, Traffic Graphs x5
          OpenVPN, Dynamic DNS Status, Ipsec, Disks
          • stephenw10S Online
            There is a specific fix coming for the 6100/8200 that speeds up the dashboard loading if you have the interfaces widget there and don't have any SFP modules loaded.
            It's in 23.09: https://redmine.pfsense.org/issues/13911
            C 1 Reply Last reply Reply Quote 2
            • RobbieTTR Offline
              RobbieTT @Cabledude
              @Cabledude
              My 6100 with Optane takes 1.91 seconds to load the dashboard over wifi.
              My Xeon-D, also with Optane, takes 1.71 seconds over wifi:
              I have a pretty busy dashboard and with live graphing, so it never really stops. Of course, with caching enabled and on a wired connection it will be quicker. My LAN uses SFP+ in both cases above.
                Cabledude @stephenw10
                @stephenw10 Hi Steve, can you confirm SG-2100 dash load time being as high as mine given these widgets:
                System Information: 3,5 seconds
                Disks: + 1.5 seconds
                pfBlockerNG: + 0.75 seconds
                Gateways: + 0.3 seconds
                Interfaces: + 1.5 seconds
                Services Status: + 2 seconds
                ZFS: + 1 second
                Traffic Graphs: +0.5 seconds
                Pete
                  Cabledude @RobbieTT
                  Thanks @RobbieTT . I don't recognize your screen shot as resembling a pfSense dashboard though.
                  Pete
                    If the box itself is busy then it can take a while to open the dash on the 2100. That does seem quite extreme though.
                    • RobbieTTR Offline
                      RobbieTT @Cabledude
                      @Cabledude said in 4100/6100 Base or Max:
                      No, it's a timeline graph showing how long the page takes to load. The top of my dashboard looks like this:
                        @stephenw10 said in 4100/6100 Base or Max:
                        No the unit is close to idle while doing these measurements.
                        When I simultaneously do an ISP speed test (400 down, 50 up) the dashboard will take 16 seconds to load.
                        Pete
                        • JonathanLeeJ Offline
                          JonathanLee @Cabledude
                          @Cabledude to log in and get to a dashboard it takes mine 8-9 seconds depending on how much it is being used. However, with the ath0 driver built for the expansion WiFi card enabled it's a lot faster. With that being said I assume the AP also factors into this. I am using a 5ghz Wi-Fi.
                          I have a Wi-Fi card inside the 2100
                          I also use a external AP most of the time because I can't access my printer or NAS with that card enabled. Again it's much more responsive when I am accessing it over the Wi-Fi on PfSense when juxtaposed to the external AP.
                          Try to disable ClamAV Tac support recommended it for me as it uses a lot of memory.
                          Make sure to upvote
                          C S 2 Replies Last reply Reply Quote 1
                            Cabledude @JonathanLee
                            Thank you @JonathanLee. 8-9 seconds is in the same ballpark as 10-11. maybe I have more widgets than you, can't really tell from your screen shots, though the paintings are exceptionally spectacular.
                            I don't have a WiFi module inside the SG-2100, all cabled connections, which can't be slower than WiFi, probably faster. But I get the same dash loading times on my iPhone (connected to my LAN) so I suppose WiFi or cabled doesn't make a difference.
                            Could you list the widgets that you use?
                            Pete
                              Stef93 @JonathanLee
                              @JonathanLee
                              Can you please tell me the model or better photo of the wifi module?
                                Compex WLE200NX. That's the only card I'm aware of that works in the 2100.
                                  JonathanLee @Stef93
                                  @Stef93 like @stephenw10 said, it is the Compex card
                                  Make sure to upvote
                                    @Cabledude for widgets I use . . .
                                    2 ART
                                    1 NTP
                                    1 System information
                                    1 Services Status
                                    1 Installed Packages
                                    1 Gateways
                                    Make sure to upvote
                                      @JonathanLee said in 4100/6100 Base or Max:
                                      2 ART
                                      1 NTP
                                      1 Services Status
                                      1 Gateways
                                      So with these 5 widgets you use (I didn’t select the two ART ones) I get 7 seconds. So I suppose our units perform similarly.
                                      Pete
                                        Stef93 @stephenw10
                                        is this adapter suitable for netgate 6100?
                                        I don’t know if it’s a different version or model, but I found Compex WLE200NX 7A
                                          @Stef93 said in 4100/6100 Base or Max:
                                          Compex WLE200NX 7A
                                          Probably. Though without actually testing it I can't be sure. The 2100 has very specific limitations for the PCIe slot.
                                          That appears to have the same fcc-id so I'd expected it to be close to identical.
                                            JonathanLee @Stef93
                                            @Stef93 the AR5BXB112 card works with the 6100 also and can use three antenna 📡 I think @stephenw10 I remember someone said it did, however it does not work with the 2100MAX
                                            Make sure to upvote
