    Not your average "internet speed" problem...
    33 Posts 7 Posters 3.5k Views 6 Watching
      Except it did the same thing with a Netgear switch in there instead and with OpenWRT on the AP we can't even blame them there. ๐Ÿ˜‰
        Panja @stephenw10
        Can you elaborate?
        I donโ€™t quite understand what you mean. Sorry!
          Sorry I was replying to @JKnott but my reply ended up out of order.
          You might need a packet capture to see what's happening there. Seem like something low level, and IP/MAC conflict maybe.
          No errors logged anywhere? On any of those devices?
            Panja @stephenw10
            Ahhhh ok. I see now. ๐Ÿ˜‚
            I will try to do some more (error) testing tomorrow and also look if I can find anything in the logs.
            • ? Offline
              A Former User
              @Panja
              Is the OpenWRT in router mode or did you set it up in AP
              mode?
                Panja @Guest
                @dobby_
                AP mode.
                Also disabled Firewall, DNS and DHCP on the OpenWRT device.
                  Panja
                  What I tested today:
                  • Port 4 from Archer C7 directly into my laptop: full speeds
                  • Cable from pfSense directly in the TP link switch and port 8 (vlan 40) directly to my laptop: full speeds
                  • Port 4 from Archer C7 into new Netgear switch (factory defaults, no setup): internet speed problem
                  • Port 4 from Archer C7 into new Netgear xx (factory defaults, no setup), unplug port 2 (so eliminating the TP link switch): internet speed problem
                    Mmm, that's got to be something really low level.
                    You see latency and low speeds but not packet loss?
                    I would be running packet captures to try to identify what's happening.
                      Panja
                      @mcury @Dobby_ @Gertjan @stephenw10 @JKnott @SteveITS
                      And LOW LEVEL is was!
                      Finally fixed the problem...
                      I've tested my problem with 3 different laptops.
                      Surface Laptop, Surface Pro and HP Probook.
                      All do not have an internal LAN port so I used an USB3.0 to LAN adapter (MS Surface Ethernet Adapter). And the 2 Surface devices I tried also on a Microsoft Surface Dock (with ethernet port). Continues problems, either with the dongle or on the dock.
                      If it was only with the dongle I would have thought the dongle would be f*ck3d.
                      But the problem was there with the dock as well...
                      Yesterday I tried that same dongle on a PopOS (Linux) device and to my suprise I was getting full speeds. That made me think it could not be the dongle itself.
                      I took a look at the driver settings for both the dongle and dock and they both use the same chip: Realtek RTL8153.
                      Both were installed with the MS Surface drivers and are recommended/installed by MS.
                      I've downloaded the latest RTL8153 drivers from the Realtek site. Manually updated the drivers and choose a different brand ethernet adapter. Voila problem solved!!
                      Finally full speed now.
                      Many thanks for all your help guys!
                        mcury Rebel Alliance @Panja
                        @panja Nice..
                        I tried to use one of those USB NIC once in my life.. never will again.. :)
                          Gertjan @mcury
                          @mcury
                          Yep, @Panja resumed it well enough : " the dongle would be f*ck3d. ".
                          Ethernet over USB : even if you could, you shouldn't. Added to that : Realtek hardware/drivers ...
                            Panja @Gertjan
                            @gertjan
                            Totally agree, that's why I have a dock when working at my desk.
                            (which did have the same chipset as the dongle).
                            But when I'm on the road and I need ethernet what options do I have...
                              Gertjan @Panja
                              @panja said in Not your average "internet speed" problem...:
                              One : you deal with what you have, and you made it work for you !!
                              To rephrase what I said above : it might work, as is was sold to you with the idea that it would work.
                              I've been using Realteks half my live and wasn't really bothered with them. I did have several NICs in advance, as they just don't 'live' very long.
                              These days, I always disable build in NIC's, and add quad Intel branded NIC in systems.
                              When I buy material, I always check what the used hardware is. The price, shape and colour details comes next.
