    NUT with Riello Sentinel Pro 2200 USB connection cant make it work
    Scheduled Pinned Locked Moved UPS Tools
    66 Posts 3 Posters 19.9k Views 3 Watching
      ha11oga11o @dennypage
      Hello all,
      i can confirm that like this works on mine side too with rather old SEP2200. All it needed is extra argument user = root.
      So, NUT package needs some tweaking not to work at root privileges i guess?
      At least we manage to connect UPS to device. many thnx! Finally some progress on this subject.
      Cheers!
      H 1 Reply Last reply Reply Quote 1
        ha11oga11o @ha11oga11o
        @ha11oga11o said in NUT with Riello Sentinel Pro 2200 USB connection cant make it work:
        Hello all,
        Cheers!
        yeah, that was short live; I got initial data, an next refresh interval it says UPS need attention.
        Nov 10 10:39:58 	upsmon 	20183 	Communications with UPS RielloSEP2200 established
        Nov 10 10:39:58 	upsd 	33371 	User local-monitor@127.0.0.1 logged into UPS [RielloSEP2200]
        Nov 10 10:39:55 	upsd 	33371 	Connected to UPS [RielloSEP2200]: riello_usb-RielloSEP2200
        Nov 10 10:39:55 	riello_usb 	33500 	Startup successful
        Nov 10 10:39:54 	upsd 	33371 	Startup successful
        Nov 10 10:39:54 	upsd 	32400 	Can't connect to UPS [RielloSEP2200] (riello_usb-RielloSEP2200): No such file or directory
        Nov 10 10:39:54 	upsd 	32400 	listening on 127.0.0.1 port 3493
        Nov 10 10:39:54 	upsd 	32400 	listening on ::1 port 3493
        Nov 10 10:39:53 	upsmon 	20183 	Communications with UPS RielloSEP2200 lost
        Nov 10 10:39:53 	upsmon 	20183 	UPS [RielloSEP2200]: connect failed: Connection failure: Connection refused
        Nov 10 10:39:53 	upsmon 	19414 	Startup successful
        Nov 10 10:39:53 	php-fpm 	50287 	/nut_settings.php: Starting service nut
        Nov 10 10:39:53 	riello_usb 	58720 	Signal 15: exiting
        Nov 10 10:39:53 	upsd 	28635 	Signal 15: exiting
        Nov 10 10:39:53 	upsd 	28635 	mainloop: Interrupted system call
        Nov 10 10:39:53 	upsd 	28635 	User local-monitor@127.0.0.1 logged out from UPS [RielloSEP2200]
        Nov 10 10:39:53 	upsmon 	27914 	Signal 15: exiting
        Nov 10 10:39:53 	php-fpm 	50287 	/nut_settings.php: Stopping service nut
        Nov 10 10:39:53 	check_reload_status 	484 	Syncing firewall
        Nov 10 10:39:53 	php-fpm 	50287 	/nut_settings.php: Configuration Change: admin@192.168.1.210 (Local Database): Updated UPS settings
        Nov 10 10:37:41 	upsmon 	27914 	Communications with UPS RielloSEP2200 established
        Nov 10 10:37:40 	upsd 	28635 	Connected to UPS [RielloSEP2200]: riello_usb-RielloSEP2200
        Nov 10 10:37:38 	riello_usb 	58720 	Startup successful
        Nov 10 10:37:36 	upsmon 	27914 	UPS RielloSEP2200 is unavailable
        Nov 10 10:37:36 	upsmon 	27914 	Poll UPS [RielloSEP2200] failed - Driver not connected
        Nov 10 10:37:36 	upsd 	28635 	User local-monitor@127.0.0.1 logged into UPS [RielloSEP2200]
        Nov 10 10:37:32 	upsd 	28635 	Startup successful
        Nov 10 10:37:32 	upsd 	28603 	Can't connect to UPS [RielloSEP2200] (riello_usb-RielloSEP2200): Connection refused
        Nov 10 10:37:32 	upsd 	28603 	listening on 127.0.0.1 port 3493
        Nov 10 10:37:32 	upsd 	28603 	listening on ::1 port 3493
        Nov 10 10:37:30 	upsmon 	27914 	Communications with UPS RielloSEP2200 lost
        Nov 10 10:37:30 	upsmon 	27914 	UPS [RielloSEP2200]: connect failed: Connection failure: Connection refused
        Nov 10 10:37:30 	upsmon 	27623 	Startup successful
        Nov 10 10:37:30 	php-fpm 	50287 	/nut_settings.php: Starting service nut
        Nov 10 10:37:30 	upsd 	13922 	Signal 15: exiting
        Nov 10 10:37:30 	upsd 	13922 	mainloop: Interrupted system call
        Nov 10 10:37:30 	upsd 	13922 	User local-monitor@127.0.0.1 logged out from UPS [RielloSEP2200]
        Nov 10 10:37:30 	upsmon 	13197 	Signal 15: exiting
        Nov 10 10:37:30 	php-fpm 	50287 	/nut_settings.php: Stopping service nut
        Nov 10 10:37:30 	check_reload_status 	484 	Syncing firewall
        Nov 10 10:37:30 	php-fpm 	50287 	/nut_settings.php: Configuration Change: admin@192.168.1.210 (Local Database): Updated UPS settings
        Nov 10 10:37:01 	check_reload_status 	484 	Syncing firewall
        Nov 10 10:37:01 	php-fpm 	97711 	/index.php: Configuration Change: admin@192.168.1.210 (Local Database): Widget configuration has been changed. (User admin)
        Nov 10 10:37:00 	sshguard 	28889 	Now monitoring attacks.
        Nov 10 10:37:00 	sshguard 	91620 	Exiting on signal.
        Nov 10 10:36:48 	check_reload_status 	484 	Syncing firewall
        Nov 10 10:36:48 	php-fpm 	83476 	/index.php: Configuration Change: admin@192.168.1.210 (Local Database): Widget configuration has been changed. (User admin)
        Nov 10 10:32:58 	upsmon 	13197 	Communications with UPS RielloSEP2200 established
        Nov 10 10:32:58 	upsd 	13922 	User local-monitor@127.0.0.1 logged into UPS [RielloSEP2200]
        Nov 10 10:32:56 	upsd 	13922 	Connected to UPS [RielloSEP2200]: riello_usb-RielloSEP2200
        Nov 10 10:32:56 	riello_usb 	13928 	Startup successful
        Nov 10 10:32:54 	upsd 	13922 	Startup successful
        Nov 10 10:32:54 	upsd 	13777 	Can't connect to UPS [RielloSEP2200] (riello_usb-RielloSEP2200): No such file or directory
        Nov 10 10:32:54 	upsd 	13777 	listening on 127.0.0.1 port 3493
        Nov 10 10:32:54 	kernel 		uhid0: detached
        Nov 10 10:32:54 	kernel 		uhid0: at uhub3, port 1, addr 3 (disconnected)
        Nov 10 10:32:54 	upsd 	13777 	listening on ::1 port 3493
        Nov 10 10:32:53 	upsmon 	13197 	Communications with UPS RielloSEP2200 lost
        Nov 10 10:32:53 	upsmon 	13197 	UPS [RielloSEP2200]: connect failed: Connection failure: Connection refused
        Nov 10 10:32:53 	upsmon 	12733 	Startup successful
        Nov 10 10:32:53 	php-fpm 	86594 	/nut_settings.php: Starting service nut
        Nov 10 10:32:53 	check_reload_status 	484 	Syncing firewall
        It looks, for me, did it once and stopped. This log is since NUT is actually started. And its filling it constantly. But it looks that reading data because i see load changes.
        I have multiple USB units and all of them acting totally same.
        Anyone have any thoughts about this?
        It looks it works, but that error bugs me. Is it conflicting maybe, dropping connection,... ?
        Thanks in advance.
          ha11oga11o
          This is what im getting with debug mode 6:
          Nov 10 10:54:00 	sshguard 	35724 	Now monitoring attacks.
          Nov 10 10:54:00 	sshguard 	19247 	Exiting on signal.
          Nov 10 10:51:29 	upsmon 	18266 	Communications with UPS RielloSEP2200 established
          Nov 10 10:51:29 	upsd 	21661 	User local-monitor@127.0.0.1 logged into UPS [RielloSEP2200]
          Nov 10 10:51:27 	upsd 	21661 	Connected to UPS [RielloSEP2200]: riello_usb-RielloSEP2200
          Nov 10 10:51:27 	riello_usb 	27207 	Startup successful
          Nov 10 10:51:25 	upsd 	21661 	Startup successful
          Nov 10 10:51:25 	upsd 	21547 	Can't connect to UPS [RielloSEP2200] (riello_usb-RielloSEP2200): No such file or directory
          Nov 10 10:51:25 	upsd 	21547 	listening on 127.0.0.1 port 3493
          Nov 10 10:51:25 	upsd 	21547 	listening on ::1 port 3493
          Nov 10 10:51:24 	upsmon 	18266 	Communications with UPS RielloSEP2200 lost
          Nov 10 10:51:24 	upsmon 	18266 	UPS [RielloSEP2200]: connect failed: Connection failure: Connection refused
          Nov 10 10:51:24 	upsmon 	17701 	Startup successful
          Nov 10 10:51:24 	php-fpm 	50287 	/nut_settings.php: Starting service nut
          Nov 10 10:51:24 	riello_usb 	33500 	Signal 15: exiting
          Nov 10 10:51:24 	upsd 	33371 	Signal 15: exiting
          Nov 10 10:51:24 	upsd 	33371 	mainloop: Interrupted system call
          Nov 10 10:51:24 	upsd 	33371 	User local-monitor@127.0.0.1 logged out from UPS [RielloSEP2200]
          Nov 10 10:51:24 	upsmon 	20183 	Signal 15: exiting
          Nov 10 10:51:24 	php-fpm 	50287 	/nut_settings.php: Stopping service nut
          Nov 10 10:51:24 	check_reload_status 	484 	Syncing firewall
            ha11oga11o
            Sorry guys for spamming subject, but im trying to troubleshoot issue. I noticed that driver sees my ups in
            Summary status: On line, Bypass, Charging
            Is it possible that driver sees it as some sort of error because its in bypass mode and notifies about it?
            And its not spamming disconnect in log anymore. But notice stays. Refreshing fine too. Actually it works, but notice is there and i dont dare to turn on mail notification in case of spamming error.
            If more data is needed i will provide.
            UnoptanioU 1 Reply Last reply Reply Quote 1
            • UnoptanioU Offline
              Unoptanio @ha11oga11o
              @ha11oga11o
              hi,
              i have generated a Quirk for Riello VST1100
              https://forum.netgate.com/topic/183961/nut-package-2-8-1-and-above/15?_=1699613439488
              I also own UPS Riello Sentinel Pro 2200 and Riello Sentinel Dual SDU 6Kw.
              As soon as I have time I'll check if the quirk also applies to this other UPS or if it has a different one
              pfSensePlus24.11 2U BareMetal Asrock Industrial IMB-X1314MicroATX
              CPU: i7-13700@5.2GHz, RAM:32GB ECC, n°2 Samsung 870EVO SATA 2.5” SSD 1TB (ZFS) Raid1
              n°3 Intel i225-LM 2500/1000/100Mbps, n°1 NIC Intel i350-T4V2 10/100/1000 Mbps 4*GLAN, n°1 Intel X520-DA2
              UnoptanioU 1 Reply Last reply Reply Quote 0
                Unoptanio @Unoptanio
                @Unoptanio
                test in progress
                I disconnected the USB cable from the Riello VST 1100 UPS and connected it to the USB port of the Riello Sentinel Pro 2200. On pfsense everything works in the UPS panel
                Quirk for Riello VST1100 also works on Riello Sentinel Pro 2200
                What parameter configuration do you recommend setting in the other text boxes?
                H dennypageD 2 Replies Last reply Reply Quote 0
                  ha11oga11o @Unoptanio
                  @Unoptanio
                  Did you encounter issue as i did? That it works actually but print error like on pictures above? And actually i dont have anything NUT related in logs anymore. It works, but error persist.
                  Any chance to get that upsmon.conf line txt formatted for copy paste? Please:)
                  Cheers!
                  UnoptanioU dennypageD 2 Replies Last reply Reply Quote 0
                    @ha11oga11o
                    My system
                    pfsense 2.7.0
                    nut 2.8.0_2
                    do we have different versions of pfsense and nut?
                    Try another USB cable that isn't too long
                    • dennypageD Offline
                      dennypage @Unoptanio
                      @Unoptanio You should remove all the NOTIFYFLAG lines from the Additional configuration lines for upsmon.conf. Notification flags are automatically handled with Enable notifications. If you look in the actual generated configuration files, you will see that they are duplicates.
                        Unoptanio @dennypage
                        @dennypage
                        OK
                          dennypage @ha11oga11o
                          @ha11oga11o The error you are showing above indicates that you are missing a quirk. See my post "Notes on USB quirks" and @Unoptanio's post "for my RIELLO model Vision VST1100" in the NUT Support thread.
                            @dennypage
                            @ha11oga11o
                            nano /boot/loader.conf
                            add the last line
                            hw.usb.quirk.0="0x04b4 0x5500 0x0000 0xffff UQ_HID_IGNORE"
                              @Unoptanio
                                @Unoptanio said in NUT with Riello Sentinel Pro 2200 USB connection cant make it work:
                                then reboot with reroot
                                I would generally recommend performing a "Normal" reboot. I have not tested adding quirks with the "reroot" approach.
                                  @dennypage
                                  The first time I start pfsense the riello Sentinel PRO 2200 doesn't work for me.
                                  Then it starts working after I press on "restart service"
                                    @Unoptanio Btw, you probably want to remove the debug_min now that you are done with USB diagnostics.
                                    UnoptanioU 2 Replies Last reply Reply Quote 1
                                      @dennypage
                                      In your opinion, why doesn't it start when pfsense is started for the first time?
                                        @Unoptanio All that stuff from upsd and upsmon simply indicate that your driver (usbhid-ups) is not running.
                                        You need the log entries for usbhid-ups. Those are the ones you care about.
                                          If you do a normal reboot (not reroot), does it work at startup?
                                          If not, please post the log entries for usbhid-ups.
                                            @dennypage
                                            with normal reboot same problem
