    NUT with Riello Sentinel Pro 2200 USB connection cant make it work
    Scheduled Pinned Locked Moved UPS Tools
    66 Posts 3 Posters 19.9k Views 3 Watching
    • dennypageD Offline
      dennypage @Unoptanio
      @Unoptanio As noted, you need the log entries for usbhid-ups. You do not need to post any log entries for upsd or upsmon.
      UnoptanioU 1 Reply Last reply Reply Quote 0
      • UnoptanioU Offline
        Unoptanio @dennypage
        @dennypage said in NUT with Riello Sentinel Pro 2200 USB connection cant make it work:
        usbhid-up
        can't find anything for usbhid-up
          @Unoptanio said in NUT with Riello Sentinel Pro 2200 USB connection cant make it work:
          Well, that's a problem. 😕
          If you have anything left in the Extra Arguments to driver section or the Additional configuration lines for upsmon.conf section, please remove it and try again.
          Also, if you have a bunch of stuff filling your logs, it might be easier to log into the system and execute this command instead:
          grep usbhid-ups /var/log/system.log*
            @dennypage
            null
              Unoptanio @Unoptanio
              @Unoptanio
              I clicked on SAVE now it goes. but the next reboot same problem
              Very strange it only happens with this Riello Sentinel Pro 2200
                @Unoptanio
                You still have debug_min = 6 in the Extra Arguments to driver section. Please remove it.
                  ncora debug_min = 6 nella sezione Argomenti aggiuntivi al driver. Per favore rimuovilo.
                  Rispondi al preventivo 0
                  ok. removed debug_min = 6 Save and now i reboot one moment....
                  same problem
                    click on restart.....now work
                    When I first start pfsense it never works
                    all empty
                      @Unoptanio We still need the log entries for usbhid-ups. I suggest that you log into the system and use the grep command show above to get the entries.
                      If you can't find anything for usbhid-ups, then post the entire log for the first two minutes following a reboot. If you are worried about sensitive information, you can PM me instead.
                      While you are there, can you also get the content of these two files please:
                      /usr/local/etc/nut/ups.conf
                      /usr/local/etc/rc.d/nut.sh
                        @dennypage
                        ups.conf
                        #!/bin/sh
                        # This file was automatically generated
                        # by the pfSense service handler.
                        rc_start() {
                        	echo starting NUT
                        	/usr/bin/killall -q -9 upsmon
                        	/usr/bin/killall -q -9 upsd
                        	/usr/bin/killall -q -9 upsdrvctl
                        	/usr/bin/killall -q -9 riello_usb
                        	/usr/local/sbin/upsmon
                        	/usr/local/sbin/upsdrvctl start &
                        	sleep 1
                        	/usr/local/sbin/upsd -u root
                        	return 0
                        rc_stop() {
                        	echo stopping NUT
                        	/usr/bin/killall -q upsmon
                        	/usr/bin/killall -q upsd
                        	/usr/bin/killall -q upsdrvctl
                        	/usr/bin/killall -q riello_usb
                        	return 0
                        rc_restart() {
                        	rc_stop
                        	rc_start
                        case $1 in
                        	start)
                        		rc_start
                        	stop)
                        		rc_stop
                        	restart)
                        		rc_restart
                        esac
                        nut.sh
                        [SentinelPro]
                        driver=riello_usb
                        port=auto
                        UnoptanioU dennypageD 2 Replies Last reply Reply Quote 0
                              riello_usb
                              Well, there's the first issue. My bad. I was telling you to look for usbhid-ups, but your driver is riello_usb.
                              Sorry about that!
                                @Unoptanio The full logs were very insightful.
                                NUT is being started twice in quick succession at boot. It looks like all packages are being stopped and restarted due to high initial packet loss on the WAN immediately after startup.
                                It's not clear clear to me why the riello driver unable able to properly communicate with the UPS on the second attempt. The first connection takes ~1 second, while the second takes ~9. Definitely not normal. Perhaps the USB connection is lingering somehow, or perhaps the UPS is overly stateful and isn't in a welcoming state for the second connection. I don't know--those are just guesses.
                                There are a couple of things I can suggest:
                                1. If you haven't already installed the 2.8.1 test version discussed in the main NUT support thread, I would recommend doing so. There are a lot of changes in the riello driver post 2.8.0.
                                2. You can try adding maxretry=10 to the Extra Arguments to driver section. This will instruct the driver to retry the initial connection to the riello up to 10 times, with a 5 second delay between each attempt.
                                In bocca al lupo
                                UnoptanioU 2 Replies Last reply Reply Quote 0
                                  @dennypage
                                  whit
                                  maxretry=10
                                  it never works
                                  I'll try changing the USB port and also the USB cable
                                  OK thanks for the support.
                                  Do you know when there will be an automatic update of the Nut 2.8.1 package in pfsense?
                                  I saw that the official stable version of free BSD 14 should be released soon. (14 november)
                                  I think that after November 14th a new version of Pfsense will be released accordingly
                                  https://redmine.pfsense.org/projects/pfsense/roadmap
                                  https://docs.netgate.com/pfsense/en/latest/releases/versions.html
                                  https://www.freebsd.org/releases/14.0R/schedule/
                                  https://networkupstools.org/
                                    @dennypage
                                    Can you take care of reporting the Riello VST1100 UPS quirk to freeBSD to automatically insert it into the operating system?
                                    hw.usb.quirk.0="0x04b4 0x5500 0x0000 0xffff UQ_HID_IGNORE"
                                      We are in testing now.
                                      Usually a new release of FreeBSD does not push a new release of pfSense. pfSense has it's own release schedule and updates the kernel as appropriate when it releases.
                                        @Unoptanio Yes, I will register quirks that I know have been developed and tested. I will need detail on the UPS units that you have tested it with.
                                          @Unoptanio Please let me know if you can try 2.8.1. Thanks.
                                            @dennypage
                                            Mine is a working production environment.
                                            I can't afford to have system crashes.
                                            At the moment I have to stick with the Pfsense 2.7.0 version. stable
                                            Can nut 2.8.1 be installed on pfsense 2.7.0?
